Question about Franklin MWD-1470 Dictionary
How to add microsoft office in MWD-1470 - Franklin MWD-1470 Dictionary
Help me out
First, make sure the batteries are in the correct orientation and that there is no corrosion in the battery compartment. Then hold the CLEAR button and press the ON button. If that doesn't do it, straighten a paper clip and gently press the reset button located on the back in a pin-sized hole below the book card slot.
Nov 30, 2011 | Franklin MWD-1470 Dictionary and Thesaurus...
My device will not turn on even after changing battery, how can I fix this problem
First, make sure the batteries are in the correct orientation. Then hold the CLEAR button and press the ON button. If that doesn't do it, straighten a paper clip and gently press the reset button located on the back in a pin-sized hole below the book card slot.
Aug 04, 2011 | Franklin MWD-1470 Dictionary and Thesaurus...
How can I get a single product of microsoft office Word 2000, if so how.
To install product Help in one of the Office programs, follow these steps:
  1. Quit all Office programs. Click the Start button, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the Add/Remove Programs icon.
  3. For Microsoft Windows 95 or Microsoft Windows 98:
    1. On the Install/Uninstall tab, click to select Microsoft Office 2000 product, where Office 2000 product is the name of the specific Office product being used.
    2. If you are using a standalone version of one of the Office programs, click to select the appropriate product in the list.
    3. Click Add/Remove.
    For Microsoft Windows 2000:
    1. Click the Change or Remove Programs button in the Add/Remove Programs dialog box, and then click to select Microsoft Office 2000 product, where Office 2000 product is the name of the specific Office product being used.
    3. Click Change/Remove.
  4. In the Setup dialog box, click Add or Remove Features.
  5. In the Microsoft Office 2000: Update Features dialog box, click the plus sign (+) to expand the features list next to the program that requires product Help. If the sign is already a minus sign (-) the features list is already expanded.
  6. Click the symbol next to Help, and then click Run from My Computer in the list that appears. Click Update Now.
Please post your feedback as well.
May 19, 2010 | Microsoft Word 2000 for PC
I accidently deleted microsoft office
Uninstall the Microsoft Office from the Add Remove Program's then restart ur computer & install the Microsoft office again.
Nov 06, 2009 | Microsoft Office Standard for PC
Have MS Office 2007 but want MS Office 2003 toolbars
well. in this case the new look it the most problematic issue for any user taht previwsly had office xp, office 2003. you can't change the apparience. just the colors. if at least you want to use your favorite color. this is how !
You can customize the appearance of the Office Fluent Ribbon in Microsoft Office Access 2007, Microsoft Office Excel 2007, Microsoft Office Outlook 2007, Microsoft Office PowerPoint 2007, or Microsoft Office Word 2007 by selecting one of the available color schemes.
example
Word
  1. Click the Microsoft Office Buttondefault.aspx?assetid=za100771021033, and then click Word Options at the bottom of the window.
  2. Click Popular, and then click the Color scheme that you want.
Oct 10, 2009 | Microsoft Office 2007 Basic for PC
Trouble installing microsoft office 2007 on a dell laptop
That particular file cabinet that you really should find on a properly registered version of Microsoft Office for English in the US as a registration number will be necessary to fully install Office.
Call Microsoft, and tell them that it's not there, though it should be.
Supply them your C(ertificate O(f) A(uthencity) and you should be good to go.
Apr 25, 2009 | Microsoft Office Professional 2007 Full...
Scanner not detected by Microsoft Office Document Scanning
1) Install the Microsoft Office Document Imaging feature by following the steps
given below:
1) Go to Start -> Control Panel.
2) Click the Add or Remove Programs.
3) Select the Microsoft Office Professional Edition 2003 and click the Change
button.
4) Click the Add or Remove Features and click on Next.
5) Select the Choose advanced customization of applications checkbox and click
Next.
6) Click on the Office Tools -> Microsoft Office Document Imaging -> Scanning, OCR
and Indexing Service Filter.
7) Select Run all from My Computer, insert the Office installation CD, and the
feature is installed.
Jan 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Lost password to the data section & how to hard reset the device
just take out the batteries and leave them out for a minute or two and everything will reset.
Jan 10, 2009 | Franklin MWD-1470 Webster's Dictionary...
Franklyn DEB-1470
scroll arrows are on left side of case - well hidden.
Jun 02, 2007 | Franklin MWD-1470 Dictionary
Franklin MWD-1470 Dictionary Logo
20 people viewed this question
Top Franklin Office Equipment & Supplies Experts
Michael Vincent Cruz
Greg Cann
Greg Cann
Are you a Franklin Office Equipment and Supply Expert? Answer questions, earn points and help others
