Question about ASUS Computers & Internet
How to remove fan in ul80j laptop - ASUS Computers & Internet
My fan on my laptop as stoped working what dol do
Step 1:
CPU cooling is an integral part of your system's health and performance. An overheated CPU can cause damage to itself, the motherboard and other components. Your CPU's fan is the primary cooling system for your processor in your laptop computer and helps regulate its temperature. One of the primary reasons for CPU fans malfunctioning is that they collect dirt and dust particles. Repairing any internal component of a laptop can be difficult, but if you follow specific instructions you will be able to fix your laptop's fan.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the faceplate of your laptop by unlatching the plastic hinges; these are usually found on the sides of the base of your laptop. If you are having trouble locating these hinges, consult your laptop's instruction manual. Remove the keyboard from your laptop by removing the four screws located at the corners. Some laptops may have five or more screws, so if you run into resistance, double-check to make sure all of the screws are removed. Remove the screws near the base of your display and gently remove the display from the base of your laptop. Make sure you unplug the video and Wi-Fi cables when removing your display to ensure they are not damaged. Unscrew and remove any fasteners holding the outer shell of your laptop in place. You should now be able to see the internal components of your laptop. Locate your CPU fan; it is the large fan located in the upper left-hand corner of your laptop. Blow compressed air into the CPU fan to expel dust or dirt particles that have collected there. If compressed air does not work, use a cotton swab and gently clean the blades of the fan. Reassemble your laptop.
b>
Apr 01, 2013 | Acer Computers & Internet
Guide how to properly clean a dirty fan that overheats in acer aspire notebook
Remove the fan from laptop, and remove the dust build up from the fan blades. Next remove outer cover of fan and clean inner section of fan case. Reattach outer cover of fan case. Next clean surrounding area in laptop and than re insert fan in laptop.
Unless you know how to take a laptop apart and put it together again, I do not recommend trying this.
As for the Playtex Diaper Disposal gene problem I need more information on the problem before I can help with that one.
Feb 13, 2013 | Playtex Diaper Genie II Elite Diaper...
How to clean the fan of my computer
Regular maintenance of your Compaq Presario laptop helps to keep the machine running properly.
Keeping the fans clean is especially important, because the fans blow out hot air and bring in fresh air to cool down the laptop.
Fans attract dust, however, which can slow them down, resulting in a hot laptop.
If the laptop overheats, vital parts can cease functioning altogether.
Consequently, keeping your laptop's fans clean is crucial.
or you might want to remove it to get it clean
HP Presario C500 is a laptop that, like most other laptops, requires a clean, functioning fan in order to work properly.
If your fan is too full of dust to function properly or needs to be replaced because it is no longer working, then your computer could be in danger of overheating and crashing.
Instead of having to purchase a new laptop because your C500's fan has failed, remove it and clean the fan or replace it with a new one.
Turn off your computer and unplug all the cords and cables from it, even the power cable.
Turn the laptop over and remove the battery, then remove all the screws at the bottom of the computer with a Phillips-head screwdriver.
Remove the two face plates from the bottom of the computer and you'll see the hard drive and RAM below.
The face plates will come out easily once the screws are removed.
Remove the two screws holding the hard drive in place and then lift the hard drive out.
Remove the screw found directly below the hard drive.
Turn the laptop over again and pop off the keyboard.
If all the screws at the bottom of the computer where removed, then the keyboard will come right out.
Remove all the screws underneath the keyboard and case and then lift the case enough to access the fan assembly in your HP Presario C500.
Unhook the cable coming from the fan into the motherboard and remove the screws holding the fan in place, then pop the fan out of the computer.
Hope this helps
Oct 20, 2012 | Compaq PRESARIO C500 COMPATIBLE LAPTOP LCD...
How to clean the fan air
or Remove an HP Presario C500 Fan Assembly to clean it
Hope this helps
How to change the cooling fan in a toshiba laptop model p200d-139
Instructions
Shut down your Toshiba laptop, and then disconnect all cables. Close the LCD lid, and then place the laptop face down on a flat surface. Position the laptop with front edge facing you.
Locate the battery pack near the top section of the laptop's bottom casing. Press on the battery release button. Remove the battery from the laptop.
Locate the cooling fan compartment cover. Its location varies from laptop to laptop, but it will be the only hardware cover with a vent in it. Remove the Phillips-head screws securing the fan's cover in place. Remove the cover from the laptop.
Disconnect the fan's cable from its connector on the motherboard. Remove the Phillips-head screws securing the fan in place. Lift the old fan out of the fan compartment and set it aside. Removing the old fan will reveal the processor chip. Apply a thin coat of thermal grease to the processor's surface using a clean paper towel. This will prevent your new processor from frying once you power on your laptop.
Place the new cooling fan assembly inside the fan compartment. Align the screw holes on the new fan with the screw holes inside the compartment. Replace the four retaining Phillips-head screws, and then reconnect the fan's power cable to the motherboard. Replace the fan compartment's plastic cover, and its retaining Phillips-head screws.
Replace the battery pack and reconnect all power cables and external devices. Turn on your laptop to test the new cooling fan
Jul 28, 2012 | Toshiba Computers & Internet
How do i get my asus model ul80j to switch from integrated graphics to nvidia
From my years of working with computers most of them only work with one video card at a time. If you have two video cards on the computer and if you have them both connected, a lot of computers get confused and can't handle that.
I've seen computers where there is a VGA Port (that normally comes with most computers) and the user goes out an purchases some heavy duty graphics video card and installs it. When they try use the VGA port, the computer refuses to switch to it as long as that other video card that they purchased is in the computer.
I've down countless of house calls to repair a computer where the purchased video card has gone bad and the customer thinks they are up the creek without a paddle until they get a new video card. Not so, I just remove the bad video card and plug into the vga video port that came with the computer.
Mar 30, 2012 | ASUS UL80JT-A2 Notebook
How do you replace the fan on a Fujitsu s2210 laptop?
How to Replace a Fujitsu LifeBook S2210 Fan
1. Follow your laptop owner's manual and assembly guide carefully as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, DVD drive , Ac adapter and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive, screen sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the laptop keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the Fujitsu LifeBook S2210 CPU Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and cpu cooling fan. Replace the screws, plug the Fujitsu LifeBook S2210 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new Fujitsu cpu cooling fan running and feel warm air blowing from the vent on the side of the laptop. A Fujitsu LifeBook S2210 Fan does not run continuously, so don't be concerned if the Fujitsu LifeBook S2210 Fan shuts off periodically.
Jun 26, 2011 | Fujitsu LifeBook A series AH550 NoteB......
My fan on my Acer Aspire 3000 laptop does not work. I purchased a new fan, but I am having a problem removing the existing fan. How do I remove the existing cooling fan?
You have to tear down the laptop to get to the cpu fan. You have to remove the cpu heatsink also to get to the fan. It is allot of work.
Feb 25, 2011 | Computers & Internet
Laptop fan has a noisy and pc is shutdown after some time ..so can I replace the fan ? pavilion dv3-2175ee
How to Replace a HP Pavilion dv3 Fan?
1. Follow your laptop owner's manual and assembly guide carefully you can download this from HP web site as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, CD/DVD drive and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive sled.
4. Remove the screws that hold the keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the HP Pavilion dv3 Fan Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and fan. Replace the screws, plug the HP Pavilion dv3 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new fan running and feel warm air blowing from the vent on the side of the laptop. A HP Pavilion dv3 Fan does not run continuously, so don't be concerned if the HP Pavilion dv3 Fan shuts off periodically.
Jan 10, 2011 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
