AUTO SREACH TO PUT CHANNELS BACK ON LINE
NEED TO FIND AUTO SREACH TO PUT CHANNELS BACK ON TRACK
  • cobrafreak Oct 28, 2008
    channels wont go past 36 and is supposed to got to 110
    Problem Solver:
  • 7 Answers
Adjust the vco coil near the tuner.
Posted on Oct 29, 2008
I need help my Olevia 42in Flatscreen wont pickup channels it just goes back to tuner even if I put up my cable line.Wont even auto search channels please help me..
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/
Dec 01, 2016 | Olevia Televison & Video
I have an Element ELEFT502 50 HD Digital tv. I am trying to connect my cable line to the TV but cannot get the past the auto scan screen
put the co axel cable in the back , bypass this tv programming stuff put your tv on channel 3 or 4 and use the cable remote , no tv channels just cable
Feb 26, 2015 | Element Televison & Video
I have power windows!when i put window down all the way then back up it popps off the track
Thanks for choosing FixYa. More then likely, your track is broken. It will need replaced for the window to operate correctly. You will need to take off the panel and any material inside the door out, such as foam or plastic. The track bar needs changed. If you have other questions, please let me know. Thanks for using FixYa.
Mar 29, 2011 | 1996 Chevrolet Monte Carlo
Olevia 232 s12 Accidentally hit factory reset. now no channels in list. how do I get my channels back?
You'll need to reprogram the channels.
Typically this is found under the settings in some sort of auto program section of the menu.
On most newer televisions, the setting is found under a 'Channel' section.
Just select auto program and your source, whether it be an antenna or a cable source.
When the auto program is completed, you'll have your channels back.
Mar 05, 2011 | Olevia Televison & Video
What size screwdriver do i use to put a window back on track in a 2005 dodge caravan
remove the track, the u will have to get window track tape from a parts store and reset the window in the track, u will also need a rubber mallet to tap the window back into the track, the tape I mentioned will most likely be carried by an automotive body shop supply, look under automotive paint suppliers in your area, also lube the window channels with spray silicone to prevent this from happening again, soak then good.
Jan 06, 2009 | 2005 Dodge Caravan
Cant put back seat back in grand voyager
Here's what you need. Put the seat in the back, about where it was before you removed it. behind the seat by the floor you have a latch handle on the left and right side behind the seat close to the floor. click the release buttond on the handles, and push them to the down position, hinging them to the floor. Good, now the seat should roll on the track that is attatched to the floor. line the seat up to the holes on the track and lift the latch handles back up. that should do it
Good Luck!
Dec 14, 2008 | 2000 Chrysler Grand Voyager
Ilo dvd player wont search high channels
At a guess the device will only find channels it can detect. So what is your connection antenna or cable If antenna then all TV is line of sight and directional If cable - only the channel's the cable co supply will come down the wire.
Sep 17, 2007 | iLO DVDRH04 DVD Recorder
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
