Question about Frigidaire FAFW4011LW Washer
Frigidaire affinity water will not enter the washer during Normal mode. FAFW4011LW
The selections on spin speed or auto temp are also not available. The time also shows 57 on start up instead of 45. I appears to be working fine on bulky and heavy modes. We already took out the drain hose and cleaned the filter which did not fix the issue. Any ideas?
3 Suggested Answers
esbee0522
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Posted on Jun 19, 2008
richroth
  • 9472 Answers
SOURCE: my Frigidaire affinity front load washer will not fill with water on bulky,heavy and normal wash modes but works fine on delicate setting
What is the model number of your unit?
Posted on Nov 01, 2012
I have a 1997 Fiesta auto, runs fine apart from a slight gearbox issue. When starting from cold and selecting Drive the car will sit there for upto 5 seconds before moving away and will stall if the brakes...
I would be looking for a vacumn hose leaking. The cold engine needs a rich mixture and braking uses the vacumn booster causing the mixure to lean. A warm engine races with the extra air.
Feb 27, 2015 | Cars & Trucks
My treadmill runs for 9 secons and stops and shows E1
Ok. So the first thing to try is to calibrate the speed.
You do this by doing the following:
  • With the SAFETY KEY in place, hold the ELEVATION UP and SPEED DOWN buttons for five seconds. The console will beep twice, "ENG0" will appear in the Distance window, and a number will appear in the Elevation window.
  • Press SELECT until "ENG3" appears; this is for Auto-Calibration.
  • Press START to Auto-Calibrate.
  • The treadmill will calibrate minimum and maximum speed, and minimum and maximum elevation. When Auto-Calibration is complete, the treadmill will reset to User's start screen. This process takes three to five minutes.
Make sure there are no errors. . .and that the speed goes from super slow to super fast and then stops. . .. if it stays slow. . or stays fast. .or error code appears during calibration, there is a problem.
If after a good calibration sequence, if it still does the stopping and E-1 after 10 seconds. ., then you need to (Power off and disconnect treadmill). . .then unplug the speed sensor from the lower power board, blow into the connector on the wire, and add a little contact cleaner spray to the connector on the board.
Recap: If it actually runs. . .but stops after a few seconds. . but the calibration runs and passes fine. .. .more than likely it is a speed sensor misread or a faulty speed sensor.
Sep 30, 2014 | Triumph 400T Treadmill
Frigidaire fafw4011lw error code 1.30
Hello warnerperry6 - Based on the symptoms you are describing the unit could possibly either have a faulty User Interface Board or Main Control Board. You may try and reset the washer by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Apr 19, 2013 | Frigidaire Affinity ATF7000E Front Load...
My Washing Machine is not spinning all the water out of my clothes.
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Frigidaire FAFW3517KN Affinity Series...
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
Washer won't spin on spin cycle but spins during other cyles
Hello rylee1966 - From what you are describing, it sounds like the washer agitates, but it will not enter a high speed spin. If that is correct, more than likely there is a door switch failure. I will personally recommend contacting a professional to move forward accurately and to assist with the repair(s).
Feb 23, 2013 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire FAFW4011LW front loader washer only select causal mode only. Please help. Thanks
Reset the unit by unplugging or turning breaker off to the unit for about 10 minutes. Then turn the unit back on. This is a hard reset. If this does not show any improvements you need a professional to diagnose the control panel/board for repairs.
Dec 21, 2012 | Frigidaire FAFW4011LW Washer
No heat just cold air
Is the gauge showing the engine is warming up to normal temp ?
Are the heater hoses getting hot ?
If the heater core is getting hot, it could be a blend door problem. The blend doors direct air thru the heater core and the ac evaporator among other things.
Dec 06, 2012 | 2005 GMC Yukon
Frigidaire FAFW4011LW Washer Logo
87 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
