Question about Cuisinart DGB Coffee Makers & Espresso Machines
My cuisinart DGB-625 is missing rubber plug from grinder lid. Is there any replacement that can be found in hardware store etc?
I had an earlier model cuisinart which had the same plug. They come out fairly easily during cleaning. It's either a design flaw or "built-in obsolescence.
SOURCE: Cuisinart Grind & Brew Thermal Coffeemaker DGB-600
i cant find the directions for the cuis.griend and brew coffee maker, can any one email them to eccoboot@yahoo.com
Posted on May 10, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart dgb-500 automatic grind & brew
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
SOURCE: Cuisinart DGB-300 coffee maker brew pause valve
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Posted on Feb 03, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart DGB-650BC instruction manual
Here's a link to the manual:
http://www.cuisinart.com/share/man/1013_man.pdf
-Tha Mp3 Doctor
Posted on Mar 22, 2009
skyblue67
  • 71 Answers
SOURCE: Cuisinart DGB-300 need Grinder Basket Lid. Where
Hi There
Firstly I found you a user manual located here http://lib.store.yahoo.net/lib/cuisinart/DGB300.pdf
Also I located this customer care and spare parts site for you, direct to cuisinart and they have a customer care help line im sure they can get your part for you
http://www.cuisinart.co.uk/
Tel 0870 240 6902
they are open Monday - Friday 9am - 5pm
Hope that is helpful
Posted on Jul 20, 2009
Continue to get beeping after taking out basket, emptying water, re-inserting basket and making certain lid is clicked shut. Thoughts?
All the parts have to be in place, including both the removable grinder unit and its clear cover, even if you're using pre-ground coffee.
It also requires that both the top lid and the front "door" (to the basket area) are clicked shut, and that the basket and its cover are both in place.
One thing to check carefully is the clear cover to the grinder unit. There's a rubber-like "nub" that seems to actually control the switch, which tells the machine that the grinder unit is properly installed. If that rubber-like nub is missing (and unfortunately it IS possible to remove it, particularly during cleaning) ... that could be causing your problem. If you see a hole in the top of that clear cover... you're missing that "nub".
Sep 14, 2010 | Cuisinart DGB-600 Coffee Maker
DGB-600 won't stop beeping and is missind grinder
The grinder cover has a white pin as a part of the cover that acts as a go between for the plastic molded post on the cover and a contact switch in the unit. Without the cover in place the molded post is not long enough to reach the contact switch and "tell" the machine it's o.k. to brew. It will beep incesssantly and do nothing. Get a replacement cover, or jury rig something to act as a replacement for the grinder cover pin. You can manually push in the switch to get it to stop beeping, but it will spring back out as soon as you release it.
Dec 19, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Where can I get a replacement grinder filter basket holder for a Cuisinart DGB 300 coffee maker
Go to this link to order directly from Cuisinart for items for your coffee maker. Just copy and paste into your web browser.
http://www.cuisinart.com/parts/coffee_bar/dgb-300.html
Hope this helps, let me know if I can help you with anything else.
JimmyC
Sep 30, 2009 | Cuisinart DGB-300 Coffee Maker
I've triggered some alarm and I cant turn it off! I'm using a Cuisinart DGB 600 Coffeemaker, that is. I pressed "Program" thinking that was how to set the tine; held it down for a long time; and now it...
OK, here's the owner's manual for your coffee maker. I've got to run out for dinner, otherwise I'd give you the step-by-step, but the manual contains all the info you need to resolve this.
Also, it's nice to have a manual for any other issues you might come across, (programming auto brewing, cleaning, etc.)
Print and download a copy to save on your PC for future use and reference too.
http://www.cuisinart.com/share/pdf/manuals/dgb-600bc.pdf
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Cuisinart DGB-600 Coffee Maker
No cofee just beeping
Make sure every piece is in place. Usually the culprit behind the beeping is an out of place or damaged Grind Basket Lid - if it is in its proper place and you still get beeping even after unplugging the machine, then I would suspect that it is damaged - call Cuisinart for a replacement lid.
Jul 31, 2009 | Cuisinart Thermal DGB-600 Grinder
Cuisinart DGB-300 need Grinder Basket Lid. Where can I purchase this part??
Hi There
Tel 0870 240 6902
Jul 20, 2009 | Cuisinart DGB-300 Coffee Maker
DGB 500 Grinder
You may try opening the front cover first and removing the filter then after opening the top lid, remove the clear grinder cover and lift the grinder from the rear. After you get it out be sure to clean the motor drive shaft and the bottom of the grinder. then use a trace of vegetable oil to lubricate the motor shaft where is attaches to the grinder.
We are on our second coffee maker and it makes great coffee.
Jan 19, 2009 | Cuisinart DGB-500 Coffee Maker
Thermal carafe clogged
I was once able to disassemble the top of the carafe and clean it thoroughly. I've had these clogging problems before, and it has not been the filter chamber that is the problem, but the vent in the carafe being clogged. When the air from the inside of the carafe can't be displaced faster than the coffee is draining in, the coffee stops draining into the carafe, fills the top, and spills over the side.
Will probably end up buying a replacement lid, as I can't figure out how to open the top without destroying it. I must have gotten lucky the time I was able to take it apart.
Jan 03, 2009 | Cuisinart Thermal DGB-600 Grinder
Coffee Makers & Espresso Machines Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
