Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Hoover Windtunnel carpet level adjustment
When I try to vacuum my oriental rugs (with the mat beneath) the vacuum is very difficult to push forward and seems to be grabbing the rug. It seems to vacuum okay on hard surfaces and regular carpet. The lever for the carpet height adjustment doesn't seem to have any effect. I haven't seen any problems addressed concerning this part of the machine. Does anyone know if this is a common problem and what the solution would be? Any help or suggestions is appreciated.
    Problem Solver:
  • 6 Answers
The suction is so great that it sucks up your carpet, then nothing works. I get my children to stand on the corners/edges of the rug so that it stays perfectly flat on the floor while I vacuum. Or, you can turn off the brush roller (set it to "hard floor" setting). Or, tip the vacuum cleaner's front up slightly while vacuuming, to reduce suction.
Posted on Nov 12, 2008
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
I have a Hoover Windtunnel vacuum cleaner and new high pile carpet. The vacuum cleaner will not move forward without extreme effort. I have been told that I need a vacuum without a beater bar and that...
you can adjust the height on some vacumes like for bare floors and medium nap it will adjust how far the beater bar is from the carpet see if your is adjustable
Apr 11, 2011 | Vacuums
I have a Hoover S3630 canister vacuum and the brush works on the bare floors but will not work on carpets.
does your vacuum have an adjuster knob on the front? if so try raising the unit so that the brushes don't bind up on the rug and burn out the belt
Dec 28, 2010 | Hoover S3630 WindTunnel Bagged Canister...
Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Dec 22, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
It seems when i am vacuuming it is very hard it move and the brushes does not rotate after the rug strings got into it.
Your belt is stretched or worn and therefore cannot turn against the resistance of the carpet. If you replace the belt it will fix the problem. You can get the belt you need here:
http://www.vacbelts.com/hoover-windtunnel-belt-.htm
Oct 24, 2009 | Hoover U6630-900 WindTunnel Bagless...
My vacuum goes backwards easily, but forward with GREAT effort..
I would look closely at the wheels; I suspect the rug let strings of material wrap around the axles, just inside the wheels. Get a knife in there to cut and remove the remnants.
Jan 20, 2018 | Hoover U6446-900 WindTunnel Bagged Upright...
Self-Propelled WindTunnel by Hoover U6445906
· Sometimes grabs the carpet for no reason.
· Comes back too fast when I push it back.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Self-Propelled WindTunnel by Hoover U6445906 Without knowing the brand name or model number you may have the height adjustment to low and the vacuum will say “bite down” on the carpet of which will make the belt burn and might leave marks on the carpet – and if you have a self-propelled vacuum it does come back fast if you because you have a transmission just like a car and you have to control the speed of the vacuum or because it may have a weak belt the vacuum will pull back easier – I really would like to know the brand name and model number so that I could accurately give a better answer . Recommended belt change for flat belt(s) are 4 to 6 months for better cleaning and one a year for a geared belt – both can stretch and lose their cleaning function
Apr 05, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover u6437
belt is stretched out try belt change all the level adjustment does is pushes out little wheels on bottom up and down roller has nothing to do with level adj roller should spin regardless
Dec 09, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Windtunnel U6425-900
have you tried raising the 'carpet level' adjustment?
Oct 15, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
670 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
