Question about Casio FX-115ES Scientific Calculator
Where is the change sign key???
Can't find the change sign or +/- key on this calculator.
  • winslowlady Oct 30, 2008
    This is not a solution for the change sign key. There is no change sign key on this calculator. 6+1=7 and to change sign of 7 after that entry, there is no key.
    New Friend:
Casio apparently omitted this key to facilitate its 'Natural Display' (textbook-like) entry capability. There is also no reciprocal key that returns a value with one press. You must use the x^-1 key and hit =.
Try the following:-
6+1=7. Now hit the ANS key. You can now backspace and insert the sign with the (-) key. This also works when changing from negative to positive.
A real nuisance, I agree. For many calculations I prefer my Casio fx-991d,
which must be almost 20 years old.
Posted on Jan 18, 2013
X + 1) = 7
Posted on Oct 30, 2008
Minus sign display problem
Calculators have two similar signs: the regular minus sign for subtraction, and the negation (change sign) sign. When applied, the latter changes the sign of the quantity to which it is applied. The minus sign - for subtraction is on the central line, the negation sign is smaller and somewhat raised above the center line.
The change sign key may be marked (-) , (+/-), or +/-
Nov 08, 2013 | HP 35s Scientific Calculator
Find sign change key
The change sign key is the one marked with (-), a minus sign between parentheses. It is on the last row of keys, to the right of the dot, and below the 3 key.
May 13, 2010 | Texas Instruments TI-84 Plus Calculator
Negative log
Use the log function (common logarithm). See screen capture for markings on key.
To evaluate the negative of a logarithm
Enter the number (argument) of the logarithm
Press the = key to have it calculated.
While result is still displayed, press the sign change key or (+/-).
Beware that -log(number) is not necessarily a negative value.
Another way to calculate -log is to use the relation
log(1/a)=-log(a) .
Your example
3 [EXP] [(] [+/-] 2 [) ] [LOG][=] [+/-]
[EXP] is the key to enter exponent of a power of 10 :It is a shortcut, so no 10 is entered. Respect the key sequence above.
[ (] left parenthesis to prevent ambiguity due to the negaticve exponent. Just a security.
[)] is the enclosing right parenthesis
[+/-] is the Sign Change key
May 06, 2010 | Casio FX-260 Calculator
What do i hit to make a number an negative
Do not use the main MINUS sign for subtraction. Rather, use the change sign key. The key may have a + and - with two arrows, one pointing left the other right. On some calculators the key is marked with (-)
Apr 14, 2010 | Texas Instruments TI-30X-IISTK Scientific...
Where is the negative button, I need to use negative numbers?
There is a key with a "+" sign, 2 arrows and a "-" sign. After you enter a number, hit this key to change it's sign. Hope this helps. Good luck!
Mar 04, 2010 | Texas Instruments TI-30XA Calculator
How to perform log and - log function
To use the log function you press the [LOG] key in the middle of the first row of keys.
To use it.
Enter the number the log of which you want to calculate (must be positive)
Press the [LOG] key
Result is displayed.
Ex log(33.54)
33.54 [LOG] result is 1.5255
Once a logarithm has been calculated, use the [+/-] key, the change sign key located between the [.] and the [=] keys, on the bottom row of keys. You must press the change sign after you have calculated the logarithm.
Mar 01, 2010 | Texas Instruments TI-30XA Calculator
How do i find the negative log on a TI-30Xa
Ex: calculate -log(15.32)
  1. Calculate the log 15.32 [LOG] [=] result 1.185258765
  2. Then press the change sign key (-) result -1.185258765
You can also try 15.32 [LOG] (-) [=]. Try to veriufy it on your calculator.
Hope it helps
Dec 13, 2009 | Texas Instruments TI-30XA Calculator
How do i put in 10 to the negative 14th power?
Hello Michelle,
Sorry, the answer was posted as a clarification request. Here it is again.
7625e6b.jpg1. Use the key that appears on the sixth line in the picture. 10 [Y to the x] [(+/-)] 14 : the (+/-) is the change sign/ negation sign, not the regular minus sign. This key can be used to calculate the power with any exponent ( negative, positive, integer, fraction, decimal, ..) 2. The procedure above is not efficient since the calculator has a short cut to 10 to the power., the key labeled [EE}. With this key you enter 1.[EE] (+/-) 14
Hope it helps.
Nov 01, 2009 | Texas Instruments TI-30XA Calculator
Using e on the BA II plus financial calculator
To use the exponential function, you must enter the number then press [2nd][e to the x] or [e^x] for short.
e^(-0.1) is entered as (-)0.1 [2nd][e^x], where (-) is the change sign key
You will need to use extra parentheses to avoid errors.
20 - 18*( (-)0.1 [2nd][e^x] ) [=]
The Minus sign between 20 and 18 is the regular one. The (-) before the 0.1 is the change sign key (-) or sometimes labeled +/-. The asterisk is the multiplication sign.
Hope it helps.
Oct 03, 2009 | Texas Instruments BA-II Plus Calculator
Change sign key? +/-
It is the key with a minus sign enclosed in parentheses (-)
Hope you find it.
Aug 25, 2009 | Texas Instruments TI-30X-IISTK Scientific...
Casio FX-115ES Scientific Calculator Logo
851 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
