Question about Panasonic PT-47WX51 47" Rear Projection Television
Pt-47wxs1ce green wave at bottom of screen cannot adjust green convergence
I have a panasonic pt-47wxs1ce and at the bottom of the screen there is a big green wave that comes up about 4-6 inches up the screen.Just happened all of the sudden tried adjusting the convergence but green doesnt adjust anymore.Any ideas?? thanks Ted
  • Ted Lego Aug 31, 2006
    allso now when i go to adjust the convergence when trying o adjust green the tv shuts off
  • 80 Answers
You have bad convergence IC's and possable 1 bad resistor
let me know and i will help you find them in the set if your are a good solderer - or call a tech
thanks
scott
Posted on May 29, 2008
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more...
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
Sep 10, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic pt-61lcx65 green spot
This may be a main board issue if the green spot moves. This is repairable. This may be a panel issue if it does not move and it is present on the panasonic splash screen and if it affects the osd menu.
Jul 29, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
PT-47WX53G green convergence and wave on bottom of screen
Had same problem with Red. Could not adjust. Funny broken lines. Found this link:
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Replaced the ICs. Was disappointed at first 'cause it was still all bowed out, but then realized that the Convergence 2 "target" can be changed with the number keys. Working thru 1-9 and going back to readjust as necessary adjusted each one into perfect alignment.
Problem solved. TV works great.
I should add that while I am reasonable technically adept, I am a software geek and never soldered before... hardest part was getting up the courage to dive in and do it myself. Glad I did.
Sep 24, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-53TW53 53 in with bad picture
Sounds like you need new convergences ICs. There are two of them in your set sometimes you can get away with just replaceing one of them but I wouldn't recommend it. They are not too expensive are 15.00 each once you replace them you have to get into the service mode and adjust the convergence.
Sep 19, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-51DX80 - Problem
Sounds like you have some leaky resistors or you got a bad IC.
But did you go in to service mode to line things up start there first then follow the other paths.
Sep 17, 2008 | Panasonic PT-51DX80 51" Rear Projection...
Panasonic 52LCX65\PT Green Spot
Good Day;
It sounds like the DLP may have a bad light engine (optical block), if so call the factory's customer service rep and ask for a concession, it is a very costly repair and they will normally cover. Call a factory authorized service dealer to confirm your concern.
Good Luck, big irish.
Mar 29, 2008 | Panasonic PT-52LCX66 Projection Television
GREEN DOTS ON SCREEN PANASONIC PROJECTION HDTV 1080I
Ah, big no-no.
This is the result of the coloring being pulled to the front of the screen.
This is caused by magnets. Anything magnetic will cause this, even a small one.
Hopefully you have warrenty, this is pretty expensive to replace.
Jan 02, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt51hx40b
If the bottom 8 inches of the screen is black then you likely have a failed part in the vertical output circuits. If you can still see video clear to the bottom, then your convergence IC's (IC7001 and 7002) may have taken a dump on you. Worst case would be a failure in one or more of the 3 yokes in the set that attach to the CRT's. If the sets less than 10 years old, it may be worth repairing. Otherwise, a nice NEW HDTV would be in order.
Jan 02, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Panasonic PT-47WX51 47" Rear Projection Television Logo
134 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
