Question about Ricoh Aficio 250 Copier
Lanier 5227 add toner message - Ricoh Aficio 250 Copier
  • Ricoh Expert
  • 1,326 Answers
I take it you have installed a new toner???? Do oyu know the last time the drum & developer unit was replaced?? It is sold as a unit with the developer in the unit. It is a customer part to replace. If these parts were replaced resently, the problem could be in the toner holding unit that you put the toner bottle into... There has been some up dates to that unit > they improved the fin's that moves the toner into the developer unit... Good Luck
Posted on Feb 24, 2012
Lanier 5235
The waste toner is contained inside the belt unit that is mounted on the inside of the right hand door. Remove the screws that hold it together and dump it. Very messy so be careful. The message will go away by itself.
Jul 02, 2014 | Lanier 5235 Printer
Lanier LP235c display says Add Yellow toner
Try removing the toner cartridge and gently cleaning the electrical contacts for the sensor. Sometimes they get toner residue on them and give false readings.
Aug 04, 2012 | Lanier 5235 Printer
Lanier 5227 scanner error
Eenter in the service mode press yellow key - 107 - red key(stop) keep press for 5 seconds,enter in the SP mode open the front door,turn OFF the main switch,wait 15 seconds close the front door,turn ON the power switch.
Jan 22, 2012 | Lanier Office Equipment & Supplies
I have a lanier ld122 copier/fax. It told me to add toner, i did, and nothing happened...still says add toner. what do i do now/
First of all check if the doors are well closed.
If everything is well closed you can have several problems:
1º Toner supply defective.
2º TD sensor defective
3º Development unit defective.
If you don't have technical training i advise you to call the provider.
Feb 28, 2011 | Lanier Office Equipment & Supplies
My lanier is making dark copies
One of the most common reasons for a Lanier 5222 or 5227 to make dark copies is a problem with the drum unit or developer. Fortunately on those machines, the drum unit and developer are all self-contained in one easily-replacable unit, called the PCU (photoconductor).
If you don't have a new PCU handy, you can order one from the same company you get your toner from. The PCU should generally be replaced every 60,000 copies, but sometimes it may need to be replaced sooner (especially if you run a lot of dark copies or make a lot of copies of images) and it can often run longer than 60,000.
Replacing the PCU is easy -- it sits right next to the toner bottle, and all you have to do is slide the old PCU out and slide the new PCU in (once you remove all of the tape and other trappings from it). Instructions will be included in the box with the new PCU.
Please rate the effectiveness of this solution. Thank you!
Oct 10, 2010 | Lanier 5222/27 Laser Printer
Lanier LW324 waste toner bottle full
Open the machine and to the right under the drum you should see the the black powder (toner) going down into container the right lower side  cover must come off. probably a service call will be needed
Apr 20, 2009 | Lanier Office Equipment & Supplies
I have a lanier lp-138c that is giving me a black toner low message on brand new cartridges... Tried 3 different cartridges and at first they register and then to the toner low...
It could be that the black developer unit is clogged. The toner low sensor is located in the black developer unit. A trained copier tech may be needed to troubleshoot this.
Apr 14, 2009 | Lanier Office Equipment & Supplies
Full Waste Toner Bottle in Lanier LD040
Hello sir; I believed you talking about LD045, am I right? In this model it doesn't have waste toner bottle, the only place you can clean is imaging transfer unit, after you cleanup the message will be disappear.
Apr 10, 2009 | Lanier Office Equipment & Supplies
Ricoh Aficio 250 Copier Logo
139 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
