Question about HP Computers & Internet
How to fix hp pe1245 17-lcd color monitor
Model PE1245 product number P9620A rev.P(1) serial # CNK51000
I have a hp monitor hp pavillion f1703 where is the plug in on the monitor? can not find one. is it hidden or does it not need one?
Posted on Feb 10, 2013
dodgecharger
  • 254 Answers
SOURCE: BenQ LCD 17 inch Monitor
I wonder if this has a backlight in it. Most/or all LCD flatpanel displays use a backlight in them, namely a small florescent tube (a tiny version of the office florescent lights). If this is burn't out, or the little power supply which runs it dead, you will have a black display. The image is actually there, you just can't see it, except perhaps faintly when external light hits it just right. The display must be disassembled to check this light. If you have tech savvy, and some equipment, voltmeter, maybe an oscilloscope, you could check it out. Where to get a replacement lamp? Google it... perhaps the manufacturer.
Posted on Sep 17, 2007
  • 16 Answers
SOURCE: for lg monitor warranty
this monitor having 3 yr warranty
according to the serial no it have warranty till April 2008.
Posted on Feb 06, 2008
  • 191 Answers
SOURCE: no white color on my hp lcd monitor
check the output of your power pack .you are having voltage drop in your output supply
Posted on Oct 19, 2008
RCtech
  • 55 Answers
SOURCE: Issue with my 17" Viewsonic VA1716w LCD monitor
If all the buttons on the front don't work I would beleive it was a cable that is not connected correctly. I've seen things like this happen on otherwise perfectly good equipment. It's probably an easy fix however, monitors have enough power to KILL YOU (dead not a little bit very dead) if your not sure what your doing find someone who is most things I encourage you to open up and play with but not monitors. (did I mention you could die)
Be careful
Rob
Posted on Dec 10, 2008
How do I fix my hp 2031 monitors flicking problem
well... this monitor comes to existence if memory serves about 2010, beginning of 2011. it is tired...
check it for the warranty here, you will need model and serial number, serial number is located on the back on silver label:
http://h20565.www2.hp.com/portal/site/hpsc/public/psi/mostViewedResults?sp4ts.oid=5056942&ac.admitted=1422622494153.876444892.492883150
select serial number and type it, this will provide you with warranty status, if it is still under warranty - follow instructions, if it is out of warranty - bin it, it is not worth repairing! new one 20" hp price start from about $100.00 on amazon...
of course you can choose to repair it... flickering after some time of use (warming up) suggest that capacitors are leaking, if you know bit of electronic, just replace leaking caps and you will be happy again for few years.
if you find this info helpful - do not forget to vote...
Jan 30, 2015 | HP S2031 LCD Monitor
How do i get a port number
HP products have a sticker with a product number and serial number.
How Do Find My Model Number or Product Number
Aug 05, 2014 | HP Computers & Internet
Small rectangle in the middle of the screen with the letter i in the left corner, the buttons are lockeder la hello 17
If the picture disappears from the screen and the
1 (power) indicator is green
Turn off the 1 (power) switch and disconnect the
video signal cables from the monitor.
Turn the monitor on by pressing the 1 (power)
switch.
If all four color bars appear (white, red, green, blue), the monitor
is working properly. Reconnect the video signal cables and check
the condition of your computer(s).
If the color bars do not appear, there is a potential monitor failure.
Inform your authorized Sony dealer of the monitor's condition.
Be sure to note the model name and serial number of your
monitor. Also note the make and model of your computer and
graphics board.
Mar 18, 2014 | Sony SDM-HS75 17" LCD Monitor
Which model of Inverter Board does HP pavilion f1503 uses? My backlight keeps on dimming after 10 secs of start up. please be spefic with the model number
The part is a "ribbon cable" for an lcd monitor...ribbon made by Youngshin (AWM 2896 30V 80C VW-1).
2 ribbon cables for a hp pavilion f1503 LCD monitor (the two from the AD board to the TCP)
The LCD panel is made by HannStar (HSD150SX84).
Also, looking for other LCD parts, particularly:
the AD board for a Proview Pro-576 (I assume Sylvania PL-576 & Mag LT576s are similar); Board #: 200-100-AS576 Rev: B MV5-S2?
It uses a sampo inverter (QPWBGL8621DG) & a AU Optronics M150XN05 LCD.
Jun 20, 2012 | HP Pavilion F1503 15" LCD Flat Panel...
Need a hp part number for a lcd display for a HP Pavilion dm4t-1200 laptop.
I would like you to try using HP's Part Surfer.
1) Put your Product Number, or Serial Number in the Quick Search box,
(P/N = Product Number.
S/N = Serial Number.
{DO NOT give out the serial number on a public forum such as this. Only on the HP website}
2) Then click the blue down arrow on the right side of the - Select a country or region - box, and click on your country.
3) Finally go back to the Quick Search box, and click on the side arrow to the right.
Post back in a Comment as to your findings.
We'll go from there.
On the back of the LCD screen is the HP part number.
http://www.screentekinc.com/HP_Pavilion_DM4T--14-inch--1366x768-wxga_hd-laptop-lcd-screen.shtml
{Scroll the page down, and see if any of the 36 part numbers may be a match}
Display LCD screen replacement instructions,
http://www.insidemylaptop.com/disassemble-hp-pavilion-dm4-laptop/
http://www.insidemylaptop.com/replace-lcd-screen-hp-pavilion-dm4-laptop/
Awaiting additional questions. Please post in a Comment.
Regards,
joecoolvette
[ P.S.
You can disconnect the LCD display, and use an external VGA monitor, while you wait for the replacement LCD screen.
1) Laptop off, VGA monitor off.
2) Connect the VGA monitor to the Left side of the laptop.
( External monitor port. The VGA connector resembles this one,
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
3) Turn the VGA monitor on. Wait for it to 'warm up'.
Turn the laptop on.
If the display does not automatically go to the external monitor;
Press, and hold down on the Fn key.
Tap the F4 key.
(The VGA monitor can be a CRT monitor, {Looks like a small TV}, or a flat LCD screen monitor that has a VGA connector, and a VGA cable ]
Sep 04, 2011 | Computers & Internet
I want to see my lcd monitor's waranty status from my serial no
Hi
you can call ViewSonic Customer Support: 800-688-6688 in the U.S. and 866-463-4775 in Canada, give them your product serial no and they would be able to give you the status on your product warranty.
In case you want to avail the warranty service they would also give you a RMA (Return Material Authorization number) number.
As mentioned on ViewSonic website "ViewSonic LCD computer display products carry a three (3) year limited warranty for parts, labor and LCD backlight. Optiquest products carry a limited warranty of one (1) year for parts, labor and backlight. In order to receive warranty service, proof of purchase of the ViewSonic product is required."
Hope this helps
Regards
KreativeGeek
Jun 23, 2010 | ViewSonic VA1912w 19" LCD Monitor
I recently had my screen crack on my Hp 550...How do I know if a LCD is compatable? Will any LCD made by HP work if it is the same size (15.4")? How do I find my model number
If you are referring to an external LCD monitor, any LCD monitor will work as long as the connectors are the same. VGA to VGA or DVI to DVI, otherwise you have to get an adapter.
To know what kind you have, if your display ports is 3 rows of 5, that is a VGA port. If it is 3 rows of 8 holes, that's a DVI.
Now to find the model number without turning it on, on the bottom of the laptop you can find a service tag. PRODUCT will tell you what the model number is. Also, you can find this info on the battery.
Hope this helps! Please don't forget to rate the answer. Thank you!
May 07, 2010 | HP Business Notebook 550
I want to know my product key number.Because I can't use all soft ware programs,like word,window,excell,accesse,etc. Then I try to use any software program the computer ask me my product key number, The...
Product Key always comes with the product package....if you need to use the genuine product of vendor you will need to buy the original version of software/program that you want to use. and With the package/disk you will get the key to unlock or register or open the product with full of it's features...
Thanks for joining fixya...
Have a nice day.
Dec 27, 2009 | Computers & Internet
Need the part number for the plug-in for the hp pavilion f1703
Assuming you mean the power adapter. Can't give you HP part number, but the one I've got is a Delta Electronics model ADP-50SH Rev. B, 100-240V 1500mA 50-60Hz input with 12V 4160mA output, positive center. Serial number is L6W0411009446. Hope that helps.
Sep 27, 2009 | HP Pavilion F1703 17" LCD Monitor
Power supply cord
Yes it is possible to get the product from HP(as now compaq is owned by HP). The part number of the product is 259055-001. You can ask for this product from HP by calling them at 1-800-227-8164. They may also give you a better alternative part number for the power cord. But according to me this particular part would be best for you monitor(259055-001). You can also buy this product online from hp.com. Yes in fact you can use sony pc tower to display on this monitor.
Aug 13, 2007 | Compaq FP 7020 17" Flat Panel LCD Monitor
Computers & Internet Logo
285 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
