Question about Dell Latitude D600 Laptop Computer - Intel Pentium M 725 1.60GHz, 802.11b Wireless, 512M PC Notebook
Can't find USB ports
When I plug in my flash drive the light does not flash on it and I can not find it on my drives. I have uninstalled and reinstalled the USB ports many times and even downloaded repair software from the web. Nothing seems to help. Is this a motherboard problem or is there a way to test this?
  • tim lantz Feb 25, 2012
    I have tested he flash drive on my desktop computer and it works normally. I have also tried a different flash drive and that does not work on the laptop either. What would you recommend I do next?
  • Jeffrey McDaniel Feb 28, 2012
    Back up everything that is important, and do a complete factory restore of the system. This will take the software back to a fresh install like it was the first day you purchased the computer. If you flash drive still will not work in the laptop at this point, there is an issue with the connection from the mother board to the port.
  • 669 Answers
If you have another flash drive or something else like a mouse that plug in USB try that. If these work then the flash drive you are trying to use has gone bad. If they don't then the computer has an issue.
or
Take the flash drive you are trying to use and plug it in to another computer. If it reads on that computer then your laptop has an issue. If not its the flash drive.
Posted on Feb 23, 2012
After connecting the flash drive into usb port. whats the next thing to click to download
insert flash drive into USB port...click on my computer and it'll show you the drives that are running and the flash drive you have plugged in right click to open drop down click open to access contents.. hope it helps :-)
Feb 07, 2012 | SanDisk Cruzer Titanium 2GB USB 2.0 Flash...
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I didn't find a port in ma laptop in which i can plug n play b'coz it didn't plug in into usb ports
These are the minimum system requirements of the flash drive you bought.
• Computer with a USB port • Latest version of Windows XP, Windows Vista® , Windows 7 • Mac® OS X 10.4, 10.5, 10.6 • Minimum free disk space: 600MB recommended
Any way back to the question, there is a protective plastic clip for the gold contacts have you tried removing it before using, it might be the reason you cant stick it to any USB port. Any way don't lost the cap so it can lessen dirt on the gold contacts.
Hopefully this information helps.
Thank you for using FixYa.
Aug 15, 2011 | LaCie CooKey USB flash drive - 16 GB USB...
How to install a USB flash drive
Just plug your USB flash drive into the USB port of your computer or other USB-equipped device and drag the files you want to take with you into the folder that appears on your screen. Your files are instantly transferred to your USB flash drive. To transfer the items on your USB flash drive onto another computer, simply plug your USB flash drive into the computer that you want the files transferred to, open the folder that appears on your screen, and drag the desired files onto the computer's desktop.
1.) Insert Flash Drive into the USB Port of your computer.
-Where is my USB port? It is usually found in newer model computers in a hidden compartment on the front of the hard drive and in the back of the hard drive on older computers. The port for laptops is found on the side or back of the computer.
2.) Wait for the hardware to automatically install on your computer.
After the hardware is installed, it is ready to use!
3.) In most cases, an Options Window will automatically open. Select "Open folder to view files" Click "OK."
Jul 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Your new hardware might not work properly error will appears
This error message comes up when you plugged in your USB Flash drive into a lower version of a USB port. Try using another port in your machine, ports that are USB 2.0 compatible and you shouldn't see this error again.
By the way, there are old motherboards which does not have ports for USB 2.0. You might want to check your motherboard user guide and see which ports runs at 2.0. If there is none, I'm afraid that the only way around it is to upgrade into a better motherboard.
Hope this help.
Apr 27, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I purchased a flash drive/key. I can not find an open port for which this key fits into. Why?
im not sute what you mean you cant find where to plug your flash drive into just plug it into a USB port or maybe your computer does not have a usb port
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Jan 20, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
HP Pavilion zv6000: USB ports are inop. USB port on rear of computer works fine. USB port on left/front will power my flash drive, but the light stays on constantly. The flash drive is does NOT show up in...
After reading the description, I think you need to try updating BIOS and latest device drivers for USB. Because USB are getting power on that means there would not be any fault to from the motherboard.
So please try updating latest BIOS for your notebook.
If you can provide me the product no for your notebook and the operating system which you are using currently then I can find the one for you.
Otherwise you can also do the same.
Type in the product no. on www.hp.com. Then go to software and driver download page, select the proper OS and search in BIOS ROM pack available for your notebook.
I hope this will help.
Jun 11, 2010 | HP Pavillion ZV6000 Notebook
When i plug the hard drive in, a blue light flashes but the dard drive doesn't turn on.
First check your usb port of computer and usb csable are working fine.
Then go to my computer proeprty then hardware then device manager then uninstall all usb drivers then restart the computer then check
Aug 20, 2009 | Western Digital Elements powered by WD 320...
Simpletech 160mg pinifarina wont work
sounds like a corrupt driver. Go to device manager, and see if the USB tree has a yellow exclamation, if yes, uninstall USB driver and reboot.
Jul 25, 2009 | SimpleTech SimpleDrive 160 GB External USB...
The computer doesn't read the flash drive when i plug it into the USB port
go to my computer property then hardware then device manager then uninstall usb drivers and install again
if u find unknown device u must have to install proper flash drive driver
May 22, 2009 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
Dell Latitude D600 Laptop Computer  - Intel Pentium M 725 1.60GHz, 802.11b Wireless, 512M  PC Notebook Logo
62 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
