Question about Ruud UBHC Air Conditioner
Always running I just bought this house with an existing Ruud system installed and have noticed that the air is ALWAYS running. It never pushes the heat past the set temp to make it turn itself off it just runs at the set temp forever. Needless to say this is a killer on the electric bill and I am seeing if I can fix it hear before having to call in someone to service it.
  • 499 Answers
Some newer high efficiency units using variable speed DC motors are designed to maintain a temp and wonrt shut off by design. Does it maintain a temp you desire ? It may be normal hard teling without seeing it.
Posted on Feb 25, 2012
Exterior fan motor replacement
i would replace its run capacitor first.
Jul 04, 2013 | Ruud UAMB Air Conditioner
Air is blowing cold but wont keep up temp
If the system is actually doing everything it can, which I do occasionally run into, then it's time to start looking at other factors like the heat loads. Number one problem I run into is either attic insulation or attic ventilation. One thing that really sticks out in your post though is the square footage and tonnage. Now, to be honest, what the square footage is from the home owner to actual living space always varies. Home owners always get the square footage like a realtor, but includes the garage and other unconditioned rooms. What your looking for is the square footage of only the rooms that have a vent. It is 400cfm per ton, 1 cfm per square foot. So if you have a 2.5 ton system, it is capable of doing 1000 square feet of living space. You said 1500 square feet, which would need a 3.5 to 4 ton system. Hope this helps and gets you to cooler days!
Jul 01, 2012 | Ruud UBHC Air Conditioner
I want to replace a system
Hello
Tons of cooling is in btus.12000 btus is one ton,24000 is 2 tons.
Somewhere on your unit is the cooling capacity in btus,take that number and divide it by 12000.
Usually a 2000 sf house will need 3 to 4 tons of cooling,more is always good.
Im sending a link to do an easy calculation that should be helpful.
http://www.consumerreports.org/cro/appliances/heating-cooling-and-air/air-conditioners/sizing-worksheet/
Jun 01, 2010 | Ruud UBHC Air Conditioner
I have Ruud Silhouette ii, about 5-6 yrs old...heater will work for a while, then it shuts down, house gets cold, I'd bang on the heater box, it comes back on..why does it do that? It does that every...
Rob, the blower always blows into the furnace therefore the arrow should always point to the furnace. As far as the unit failing at times, you may have a lose wire. Inspect all wires and reconnect them after cleaning if they look suspicious. Turn off the power to the unit prior to this. Your Ruud may have a diagnostic light that may help you troubleshoot the furnace next time it fails to operate. Check on the wiring diagram that is pasted on the reverse side of one of the panels. If it indicates a flashing or blinking light, you may be able to get a starting point where to look.
Feb 20, 2010 | Ruud UBHC Air Conditioner
Aux heat always comes on in heating (Ruud heat pump)
what type of system is it, if it's it Rheem the o/b needs to be set for B, if not check the freon charge, or thermostat, there will be a point where the aux. heat comes on when you turn it up, poss. only 4 degrees, is it a mercury stat or digital ?
Feb 01, 2010 | Ruud UAMB Air Conditioner
This is our second Ruud, bought in 2006. It is
Do you think you may have water in the inducer fan? Really. There may be a drain hose connected to the fan housing that allows the condensate to be drained away. Remove the hose and check for debris blocking the hose. While you are looking at it, make sure your venting slopes to either the outside or back to the furnace, you may have a build-up of water in the horizontal length of the vent pipe. Hope I helped!
Dec 02, 2009 | Ruud Heating & Cooling
My goodman gaspack has had two incidents of cracked heat exchangerS within 18 months apart. Could something be cAUSING THIS TO HAPPEN?
Things to watch for when your heat exchanger is cracking....
1.Always kee the filter clean
2.Make sure the return air vents are clean and clear of obstructions
3.Your furnace could be Oversized for your house thereby running too hot.
4.The furnace can be "Overfired" basically burniing more gas and running hotter than it's supposed to be
5.It's always best to have your furnace taking fresh air for combustion from outside...basically you should have 2 pipes on your furnace ..one for Air Intake and the other for Exhaust
6.Sometimes some furnaces have a Bad Design and are prone to failure...Some Goodman have "Rings" basically large rivets that pop...this was a bad design however all the suggestions above should help but may not eliminate your problem
Oct 31, 2009 | Ruud UPMC036 Air Conditioner
Unbalanced cooling or heating
You need to balance the system. It's a matter of adjusting the dampers or registers so that you have a little less air flow near the T-stat and more to the other end of the house. Likely you have a return vent near the T-stat. That return draws air to it and likewise the T-stat. If you are getting a lot of air out of the registers on that end of the house damper them to force more air to the other end of the house. Do not close them entirely though. You may have to play with it a little to get it right. I hope this helps. Please remember to rate Fixya rate me.
Feb 23, 2009 | Ruud Central System Air Conditioner
I have a york hvac system that is 5 years old. I have the thermostat set at 74 and when it turns on only the fan runs circulating the existing air in the house about 20 percent of the time. The a\c works...
It sounds to me like you have a delay on start timer on the compressor that possibly is starting to fail or someone may have adjusted the time band up on it. I myself would remove it and install a delay on break timer and a 5 minute setting would be ample time.
Hope this helps Ya
Jul 13, 2008 | Heating & Cooling
Buzzing on unit
Is the buzzing in the outdoor half of the system? If so
your possibilities are.
buzzing could be the contactor. In the control compartment on the side of the unit there is a small brown component that has wires to one side and the other . There are contacts in the center like points on a car. If the points are pulled in look for ants in between the contacts. Always secure power to the outdoor unit before touching anything inside. If the points are pulled in check your breaker to the outdoor unit. Turn the breaker off then back on. Breakers sometimes trip but look ok.
Buzzing could be thee coil to the contactor itself, sometimes with age the coil will breakdown and cause noise.
if you give me more information I can focas in closer to a solution
May 16, 2008 | Ruud UAKA030 Air Conditioner
Ruud UBHC Air Conditioner Logo
42 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
