Question about Panasonic CT2722H TV
Panasonic tv has white lines at top of screen
I have a panasonic ct 2701 tv that when turned on it has white lines on the screen that after awhile they go to the top of the screen sometimes therers 2 lines at the top and some times theres four or five lines how can i fix this problem and can you send me step by step pictures of the board and instructions on how to fix the problem the lines seem to be folding the rest of the screen is fine only aboye 1-1/2 to 2inches at the top of the screen has the problem thanks.
  • 4 more comments
  • TPComps May 02, 2008
    Panasonic C?-27D20B: About 15 white lines taking up the top 1 inch of the 16 vertical inches of screen. They seem to display up-side-down whatever goes to the top of the screen. Other than that, the TV and picture are fine. The manufacture date is June 2000. I don't know how to fix it other than not pay attention to the top inch.
  • exitwound Sep 08, 2008
    My 27" panasonic has the same problem , 3" of top picture folded down.
    The picture sometimes is shifted up during letterbox display, then it shows a blinking white band @ bottom of display.
    Question: does this set have a vertical centering and/or vertical height adjustment? I don't have a manual so details
    are appreciated!
  • megalou00 Oct 23, 2008
    Does this fix cost more than getting a new tv??????
  • Anonymous Dec 08, 2008
    i have lines that are on my tv when it starts up.they used to go away .but now they seem to last a long time,can you tell me what is causing this, and can it be fixed..thanks
  • kissmint Jan 10, 2009
    5 white lines at top of tv
  • Anonymous Mar 26, 2014
    tv wont turn on except with remote. turns off at 1 minute. if top 2 buttons held in manually then tv stays on
  • 119 Answers
Suspect it's 1 or a couple of bad capacitors in the vertical deflection circuit the caps are in the 400 series, c400,c401,c402, etc... check or replace c414,c418 & c417
Posted on Oct 31, 2006
10 fine white lines at top of tv screen
replace capacitor at vertical section
May 26, 2010 | Panasonic CT-27G14 27" TV
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Panasonic TV has a white line across it (No Picture, just a line)
The vertical output ic has loose solder joints. The back has to be removed to do this. The reference number for the ic is IC451. Thanks for using fixya.
Feb 21, 2010 | Panasonic Televison & Video
Panasonic CT-27L8SG displays gray screen and white hoizontal line
Is it still under warranty?
If not I would find a good TV Service Shop and have them check out the power supply as there more than likely a 'Capacitor' much like a battery that is going bad.
A/V Media Guy
Nov 22, 2009 | Panasonic CT-27SL14 27" TV
Black Screen with white line across the
the vertical IC most likely has failed
Jul 19, 2009 | Televison & Video
you need some caps changed in that set in vertical circuit
i usually change about 5 caps to cure the problem
caps go bad over time
Dec 27, 2008 | Panasonic CT-32G11 32" TV
Panasonic CT-36SL14J White screen
my Panasonic CT-36SL145J won't turn on
Dec 25, 2008 | Panasonic CT-36HL43 36" TV
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Horizontal white lines on top of screen
try to adjust the screen control in the flyback transformer. good luck
May 04, 2007 | Panasonic CT-27G14 27" TV
Panasonic CT2722H TV Logo
2,025 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
