Question about Fisher and Paykel Ovens
Need to remove control panel on a Fisher & Paykel BI601X wall oven
Need to replace soft touch buttons on F&P wall oven model BI601X - how do I remove the front of the control panel?
5 Suggested Answers
  • 1891 Answers
SOURCE: fisher paykel double soft touch oven just came up
shut off the power for 5 min and try again . you will find inside the control panel a tec sheet with this code . it should help / thanks mm
Posted on Dec 02, 2009
tbirdfan1
  • 3051 Answers
SOURCE: F3 fault code on fisher & paykel wall oven.
hELLO THERE:
on these ovens the f-3 can sometime be incorporated with the f-4 error code also so here is the code and the things to look for both ok ?
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Posted on Jul 14, 2010
KevinWhite
  • 1902 Answers
SOURCE: Fisher & Paykel double wall
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Feb 03, 2011
rickead1
  • 1998 Answers
SOURCE: When changing seal on Fisher
Yes it is suggested as well to shut off the electrical breaker that provides power going to the oven. If you have any further questions message me back Thanks Rick
Posted on Jul 05, 2011
How do I replace the fan in a Fisher & Paykel 60cm oven
ill assume your referring to the cooking fan you see inside the oven and not the outer cooling fan, you will need to turn the breaker off outside to cut power to the oven then you will have to take the oven out of the wall and remove the back cover then its normally just 3 screws and the nut on the inside of the oven that holds the fan blade on (which is reverse threaded by the way) and it should come out
Sep 27, 2014 | Fisher and Paykel Ovens
I have DCS single wall oven model WO127 SS. Display is dim, again. Was repaired in '08 with part #211708. When I look for this part again, it says it fits WO130 with no mention of WO127. Genuine...
Good Morning Mr Villa!
FixYourBoard has repairs what youre experiencing in 2-3 business days. They'd remanufacture your part, and replace your dimming display, fully test the unit.. and back their work with a 2 year warranty. http://www.fixyourboard.com
Mar 30, 2017 | DCS Ovens
I have a fisher & paykel paprika and i cant get
Hi - Are you able to provide model number of the oven - or describe the front controls as they have about 6 different types of controls regardless of the brand name 'paprika'
cheers
Jul 01, 2011 | Fisher and Paykel Ovens
Hi, I have a wo570xd double oven and the controller is playing up, ihave had F& P send me a new controller (572942p), this controller did not work so contacted them again and they have sent out a new...
fisher & paykel oven model WO570XD seems to be no power from source to the wall oven however range top works fine. Power light on switch to oven is illuminated indicating there is power however there is no lighting on digital display unit. Any help appreciated
May 31, 2011 | Fisher and Paykel Ovens
Fisher and paykel oven door wont close, there is a gap at the top of the door. The seal seems to be intact. The door feels loose to the touch.
you need to either replace - or get the door hinges replaced, the spring in the hinges has weakened over time, if it is still in warranty, then they should replace them for free, if not, then take the model number to your local f&P dealer and buy new hinges. Remove the door and dismantle the door to gain access to the hinges, undo the 2 screws holding each hinge in place, clean the inside of the glas while apart, reassemble in reverse order.
May 17, 2011 | Fisher and Paykel OS302SS, Stainless Steel...
Fisher & Paykel double wall oven, bottom oven will not heat to set temp. Stops a 75 degrees
Kevin
Feb 03, 2011 | Fisher and Paykel Titan OD301M Electric...
I have a Fisher & Paykel double wall oven that I purchased in 2005. The top oven which was used most often stopped heating up to temperature in normal time. What used to take 5 minutes to get up to 250...
Google searches report that after running the self cleaning cycle this can happen. I am experiencing this issue with my Fisher&Paykel AeroTech Double OD302 but with the BOTTOM oven. I'm concerned as Thanksgiving is coming up and I need this baby working!
Nov 08, 2010 | Fisher and Paykel AeroTech Double OD302...
hELLO THERE:
Jul 14, 2010 | Fisher and Paykel Ovens
Fisher paykel double soft touch oven just came up with c2 and wont stop beeping
Dec 02, 2009 | Ovens
Ovens Logo
71 people viewed this question
Top Fisher and Paykel Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Joseph Hoffmann
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
