Question about Apple Macbook Computers & Internet
ITunes will not burn disk
Instructs me to insert a blank disk when one has just been inserted and then ejects dusk. one notification said there had been a medium write error.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 1,099 Answers
A few thoughts have you tried to burn the disk using another application other than itunes. Have you tried a different disk or a different brand of disk? If the problem still exists it would rule out problems with the application and the disks. However it would probably mean that the disk drive is not working properly, you could try using a dvd head cleaner, but mac DVD drives do not have a great history with regards reliability. If it is still under warranty arrange an appointment at the genius bar at the local apple store and you will be able to get it replaced. The only other thing to do would be to purchase an external dvd drive, make sure it is mac compatible. Hope this helps.
Posted on Feb 23, 2012
Testimonial: "This advice was helpful and my options were to replace the internal disk drive (costly and the computer is already more than five years old) or purchase an external disk drive (less costly and the option I chose."
Burn project ejects blank DVD-r
If you are prompted to insert a CD/DVD blank disc into the Burner, you must have the proper UNUSED CD or DVD blank disk. You must use the SIZE disc that corresponds to the Size of the Data to be burned. A CD is 700 Megs thus anything greater than 700 Megs needs a larger disc such as a DVD that is 4.7 Gigs. If the data you are trying to copy to a disc is over 4.7G you need a Dual Layer DVD or BluRay that accepts 25Gigs.
Dec 16, 2013 | Roxio Computers & Internet
Why does my macbook keep ejecting CDs and DVDs out whether they are blank, burnt, or regular?
The unit is fubar and needs to be replaced since repair is not cost effective.. You might open up unit to see if there is any debris in the path of the tray that could be interfering in its operation. If all is ok,time to go shopping.
Sep 02, 2017 | Apple MacBook Pro Notebook
I try to burn a audio cd from my itune and media player but it seems like it not burn it, show a massage says insert a blank cd and it just eject....i try everyting but it still not working. is there a...
Have you used different brands of CD-R's and you got the same result - the disk isn't accepted? if yes then your optical unit is defective and must be replaced. Take your laptop to a repair shop , this is a big job that must be done by an experienced person.
Nov 24, 2010 | Toshiba Satellite Pro L300 Notebook
I have had to replace my hard drive on my pc how can i get my music back on to pc from my ipod and back into i tunes
Backing up your iTunes library to a CD or DVD To burn a CD (CD-R or CD-RW), your computer must have a compatible CD burner. To burn a DVD (DVD-R or DVD-RW), your computer must have a compatible DVD burner. Check in iTunes Preferences to see if a drive is compatible. See below for steps.
To create your backup disc
  1. Choose File > Library > Back up to Disc.
  2. Select the option you want from the resulting dialog and click Back Up.
  3. The two options you can select from are:
    • Back up entire iTunes library and playlists
    • Back up only iTunes Store purchases
    Whichever of these two options you choose, note that you can also choose "Only back up items added or changed since last backup" to perform an incremental backup.
  4. Insert a blank disc (CD or DVD) into your computer's optical drive. iTunes will scan the disc and begin burning.
  5. Note: If the disc you insert does not have enough space to hold all of the content you will be backing up, a dialog will appear asking whether you wish to backup to multiple discs. You can click Data Discs to continue.
iTunes burns the number of items that fit on one disc and then asks you to insert subsequent discs to continue burning the remaining files. Don't eject a disc while a backup is in progress.
Spoken programs purchased from the Audible.com website are not backed up.
Discs you create using the iTunes backup feature can be used only to restore; they can't be played in a CD or DVD player.
Restoring from a backup disc
  1. Open iTunes.
  2. Insert your backup disc.
  3. iTunes will ask whether you want to restore from this disc. Click Restore.
Check drive compatibility
  1. Choose a playlist on the left side of the iTunes window.
  2. Click the Burn Disc button on the bottom right corner of iTunes.
  3. If the drive is listed, it's compatible.
Aug 16, 2010 | Apple iTunes
Does not recognize disk
Either:
* the disk you're inserting is not "empty" -- try it on a different computer;
* you should try a different manufacturer of "blank" disks;
* you need to upgrade the "firmware" inside your CD-writer, to recognize more brands of "blank" media;
* the CD-reader is malfunctioning -- when you "cancel" the burn-attempt, and insert a commercially-produced program CD or commercially-produced audio CD, can those disks be properly read?
* you have two CD/DVD devices in your computer, and you're inserting the "blank" disk into the "wrong" device.
Jul 18, 2010 | Yamaha CRW 2200E CD-RW Burner
Burning music from itunes
this is just itunes its perfectly normal
Jul 21, 2009 | Apple iTunes
CD stuck in Dell Studio 15.
you have to insert a needle in the hole located near to the eject button...
Feb 19, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Can not burn cd on windows media player.
Try to use another blank CD
if it is not fixed u can use nero which is a good burning software
Thank U
Dec 27, 2008 | Microsoft Windows Media Player
Trying to burn music from iTunes onto a blank CD: the CD ejects and iTunes says "please insert blank CD". Have tried this with a couple of CD brands (verbatim, magmedia) but still the same...
Try
Memorex or Sony CD - R media and use the slowest Burn speed for the best results.
Good luck and let us know your result so we can provide alternate solutions if this doesn't Fixha?
Jul 19, 2008 | Computers & Internet
Computers & Internet Logo
162 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
