Emerson NR303TT Record Player Not Playing Lead Channel
I have an Emerson NR303TT combo unit (record player, CD player, radio, cassette player). I'm having trouble with the record player portion. When you play a record the channel with the lead vocals doesn't play. You can hear the vocals being picked up at the needle, if you have good hearing such as I do. But It's not coming out of the speakers. Doesn't appear to be the speakers themselves, because the CD player plays all sound channels fine. It's NOT the record, because I've troubleshot with multiple records. And I've tested the records themselves on my other record player. I took a look at the insides and I can't see anything obviously unscrewed or disconnected at the record player end. It's hard to see because the CD player unit is in the way and I didn't want to disassemble the entire unit. I messed with the needle a bit the other day, pulling it down a bit, and all the channels played for a short bit. Does this sound like it's a needle issue? I want to sell the unit since I don't play CDs or Tapes anymore (iTunes is responsible for the one and water damage for the other).
  • chriss576
    chriss576 Feb 25, 2012
    Perhaps it might be an issue with the springs? There appear to be three springs that the record player deck 'floats' on. I noticed that my other record players just spin in a circle in a nice, flat pattern. But the platter on rotates in a slightly wavy way. Though, there's never any interruption of the sound. There's just that one channel that doesn't make it to the speakers.
    Could it be an issue with one of the wires going from the needle head being bad?
  • 218 Answers
SOURCE: Problem playing 45 Records to their entirety.
There is an adjustment on the tone arm that you use to set where the tone arm picks up at the end of the record. This adjustment is normaly at the back (pivot point) of the tone arm and will be on the side probably. By the way, the tone arm is the part that the stylus is mounted to that swings back and forth to reach all the surface of the record. Make your adjustment and then test and continue doing this until you get it just where you want it. It is a process of trial and error. Good luck.
Posted on May 21, 2007
SOURCE: Emerson NR303TT CD Shelf System
Tienes que llevarlo a un centro de reparaciones ya qur por lo que dices los ICs amplificadores de audio estan danados.
Posted on Apr 12, 2008
SOURCE: cD Player returns NO DISK code
had similar problem, first things first.........clean lens with isopropyl alcohol on a Q-tip. to do this, you will have to remove cover and likely the disc tray. worked for me.
Posted on Sep 21, 2008
  • 146 Answers
SOURCE: protection circuit trips a low audio output level MX-W50
When you unplug one speaker (from the back of the receiver) and the rec. works good, then the speaker that you unplugged is the bad one, or the wire that is hooked up to that speaker is bad. Repair the speaker or the wire.
Posted on Nov 19, 2008
  • 104 Answers
SOURCE: Emerson NR303TT Turntable won't work
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things. maybe something in the video will clear up exactly how to get the belt on right.
if motor won't spin, spin it with your fingers, sometimes a "dead spot" developes on these motors. if it then starts on it's own, just let it run for a few hrs and the problem may solve itself for a long long time.
Posted on Feb 12, 2009
I have a brand new emerson 3 speed record player, amfm radio, cd player combo. I am having trouble with the turntable rubbing even after we tighten the shipping screw down
Shipping screws are used the hold down the turntable during shipping.
These shipping screws need to be removed after shipping and installation.
Nov 19, 2012 | Emerson 3 Speed Vinil Classic Lp Turntable...
How do I get it to record a voice?
Many portable 'boombox' recorders do not include a microphone for recording ambient sound, but can only record from one internal source to another, like radio or CD to Cassettte. Some do include an input jack for microphones or other audio sources, but you'll need to check your device's specs/ports to be sure.
May 18, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
Power transformer appears bad. What is the ac voltage out of the transformer?
Check the part number on the transformer: the link at the bottom may help it if it is listed there..The transformer that i had. PN: E190246 Mfr: HF-4822L2TN (single in/output) (ie... two wires in and two wires out)
(Hang Fung Eletronic Ltd.) has a 42.2 vpk >15watts
(power supply for an Emerson 4 in one Entertainment system
(record, CD, cassett, radio)
Emerson Model: NR305TT 19watt
Found info here
I hope this helps somebody..
Jan 15, 2011 | Emerson NR303TT CD Shelf System
Nothing on Radio stereo system works. The power comes on nothing plays. There is also CD jamed in the player. Where do I go from here? Emerson NR303TT serial number 61100051 CA
check to see if the cd player has a little hole next to it if it does that is a release use a paper clip to push into the hole that should get your cd out.
Mar 28, 2010 | Emerson NR303TT CD Shelf System
How to record a cassette from cd on a sony xplod boombox cfd-g505
Insert a tape.
Select the program source you want to listen/record (CD).
Insert a cd, press stop.
Press record on the tape player.
Press play on the CD player.
The volume control or any audio emphasis buttons will not affect the record level.
Mar 17, 2010 | Sony CFDG505BLACK Xplod CD Radio Cassette...
I have an emerson euphoria am/fm stereo radio/cd player/cassette recorder. i want to record on cassette. there are 6 buttons with symbols on them. what are they and which do i use to record
the standard tape symbols are as follows.
triangle on side pointing right - play
filled dot - record these need to be pressed at the same time.
while recording
II symbol is to pause
square is stop.
double arrows left is rewind
doubble arrows right is fast forward.
arrow up with a base is eject.
Nov 13, 2009 | Emerson PD6810 CD Boombox
Putting a needle in my nr303tt
the needle should slide on and off. you should consult your owners manual or if you do not have one, you can download and print one from the emerson web site.
Replacment needles can be purchaced from the only authorized distributor of emerson parts(Fox International LTD. , Inc.) (800) 321-6993. Don't forget to provide your model number.
Mar 06, 2009 | Emerson NR303TT CD Shelf System
70 people viewed this question
