Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Screechy sound on 50" Samsung
Any thoughts on what would suddenly start our Samsung making a high pitched, screechy sound (even with the mute button on!)
  • Anonymous Oct 30, 2008
    squilling noise while on a progrm but its gone on a black screen
  • Samsung Master
  • 8,617 Answers
Bearings in the color wheel are most likely the problem, you will need to replace the color wheel
Posted on Oct 31, 2008
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Nissan Almera Tino 2004 - built-in radio is quiet or screeches
with the proper wire harness you can retrofit any aftermarket indash you want call any car audio shop they will be happy to set you up with exactly what you need
Mar 10, 2010 | Car Audio & Video
Screen suddenly turned off, makes an odd high pitched noise when it tries to turn back on. power button flashes orange
Sounds like there is a power problem if the neutral (return) wire on the power supply has become high impedance (or even disconnected) then you will get a high pitched sound coming from the TV PSU also the voltage that is presented will not be 240V which will give you the same problem.
The orange power button means standby if you fix the PSU then the TV might work again but it may have been damaged by the PSU.
Jan 07, 2010 | Panasonic PT-50LCX63 50" Rear Projection...
2006 grand vitara, making sudden loud screechy sound, & lost power steering, when a/c is off, power steering is restored..
Sounds like the serpentine belt is slipping and perhaps struggling to turn pullies.. this would result in horrid squealling noises especially in cold damp weather and loss of power steering ability when A/C is on
(A/C on equals extra strain on the belts grip, when turned off the A/C pulley spins freely hence less strain)
Dec 08, 2009 | 2006 Suzuki Grand Vitara
Hi. We have a screechy noise coming from front,
I raised the right-hand end of the long component with rotating vanes in it by wedging a piece of folded floor vinyl under it . I assume that this has put renewed tension onto the drive belt at the other end. Now I am seeking a new part in order to make a permanent repair.
Oct 01, 2009 | Refrigerators
Screechy noise when starting 2001 Impala
Does this noise occur as the engine is cranking over to start, and as it just start up? It's probably the belt slipping on the pulleys. If the belt is original, or showing any cracks and splits, replace it. Keep the starter. countrycurt0
Aug 12, 2008 | 2001 Chevrolet Impala
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
48 people viewed this question
Henry  Thomas
Henry Thomas
