Question about Mitsubishi WS-55513 55" Rear Projection HDTV
T V broke
The other day try to turn on the tv the green light came on and after a short while it started to flash and will not come on try unplug it and left it unplug for a couple of days still does the same thing tryed to press system reset button still no fix also tryed holding down the power button still nothing
  • kingsnots Feb 21, 2009
    The TV will not turn on. I have a fast flashing green light on the front panel. I pulled the power plug for two days. That did not work. I pushed the reset button, that did not work. What is the likly problem for this Model of TV. WS-55513 Rear Projection HDTV.
  • 3 Answers
Dude I have a ws-55859 and its doing the same thing I had a repair man look at it and said they are know for doing this, it is the digital transiters and the parts are cheap only a couple of bucks a peice ( I have 7 in mine), but he want 175 to 200 to put them in, they are all on the same board.
Posted on Feb 20, 2009
    Problem Solver:
  • 12 Answers
4 caps in the stand up shielded module get bulges on top....replace them. Seen it several times.
Posted on Oct 10, 2006
The tv will flash a green light and will turn off, it doesnt turn on either when you power it on
if the green light is a flash on screen with retrace lines most likely the video driver ic on the green crt board , just take the speaker grill .
theair should be a way to get to crts. the one in the center is the green crt. the green video driver ic is an inline 24 pin ic.
to test unplug the video drive plug leading to green crt board turn tv on .if it comes up its a bad ic.
if not unplug the crt socket ,and try to turn it on if it comes up
bad crt internal short hope this helps, butler
Oct 02, 2016 | Televison & Video
TV won't turn on
you need to replace the lamp in your tv, it is easy and you can do it. Look on the sides of the set for a door labled lamp, with the set unplugged open it up and remove the lamp, if the bulb is out it will have lots of glass in the lens
Jul 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Akia 27 inch tv wont turn on
Power packs can be repaired, and most time it is simply capacitors. I don't charge an arm and a leg
Mar 26, 2009 | Akai LCT2715 27 in. LCD Television
Red and green lights flashing intermittently when we turn it on.
take it back to place purchased /with receipt demand new one
Dec 24, 2017 | Sharp Aquos LC-19D45U 19 in. LCD TV
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65513 Flashing green light
Good Day, charliek1;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 10, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
103 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
