Question about Thermador Ovens
I'm getting an error code of F37 on a Thermador Double Oven
I'm getting an error code of F37 on a Termador Electric Double oven. Model C301-C302 or C271-C272 any ideas?
4 Suggested Answers
  • 5 Answers
SOURCE: thermador c302 door hinges
487746 is the part number for the 30 inch model and
487747 is the part number for the 27 inch model if this is the parts you recieved then the should fit there should not be much difference
Posted on Jan 15, 2009
tunde007
  • 2382 Answers
SOURCE: I am getting an F64
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Posted on Jan 05, 2011
reyjoshua07
  • 1157 Answers
SOURCE: I have a thermador double
Hi awadsworth,
The "F33" fault code description is a faulty temperature sensor also indicates as an "upper oven over temperature while cooking". The easiest way to correct this error is by checking the sensor harness and harness connection between oven sensor and oven control. If wiring is ok you need to replace the oven temperature sensor. Your options are limited unfortunately. It is something that a technician will need to replace for you. You may have a technician come in and check it over.
The original Thermador part number is 35-00-306 and available at on-line supplier "repairclinic.com" for approx $125USD. You may also double check the specific model number of your machine, it is located behind the grill by the door latch.
Hope it helps.
Thank you for using FixYa.
Posted on May 06, 2011
Have a "CAL" error code. Reset fuse box breaker. No code, but nothing is operable.
try rebooting; unplug or switch off the circuit breaker for 90 seconds
Mar 26, 2016 | Thermador C272 Electric Double Oven
Why do I have error code F25 on my Thermador oven error codes
clean the touchpad control panel. Make sure the oven door closes properly to prevent excessive heating of the touchpad. If these don't resolve it, it calls for a replacement of BOTH the touchpad AND the relay board. EXPENSIVE!
Aug 23, 2014 | Thermador SC272T Electric Double Oven
Flashing F33 error code thermador double oven
either a bad oven sensor or a bad power relay board.
Feb 10, 2014 | Thermador SC272T Electric Double Oven
Unit shuts off when using broiler
can't broil with door open with these models. If closed, most likely an air flow issue with the cooling fan above in the control panel.
Nov 15, 2013 | Thermador C272 Electric Double Oven
Rbd305pdb14 error code F5
Dear Valued Consumer, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Dear Valued Consumer), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 23, 2017 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
48 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
