Question about KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher
Where is water sensor located - KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher
Code f 24 washer wil not start
The "F24" fault code indicates a water temperature sensor error. The temperature sensor could be faulty; the wire connection may have vibrated loose or off the sensor or a possible heater or control board failure. I would begin by
disconnecting the power cord from the power source
and remove the rear panel from the back of the washer. The temperature sensor (key#24) is located at the bottom of the back of the tub. I added an image below to reference the location and a temperature sensor chart. If you do not find the sensor wires disconnected, disconnect the wires and you will need an Ohm meter to measure the resistance of the sensor. At 86 degrees or room temperature, the sensor should measure approximately 9.7K Ohms. Disregard the information in the image about the heating element; your specific model does not have a heating element to heat water. The water temperature is dependent on the temperature of the hot water entering the washer.
NOTE: Be sure the washer is empty of water before removing the sensor.
If you find the temperature sensor faulty; the
temperature sensor for model WFW8410SW01 washer is part #8181705
which can be ordered from Sears Parts Direct.
May 24, 2015 | Washing Machines
Replaced water pump but cant find where to plug sensor back in
You didn't say what sensor, or whether it is 4 or 6 cylinder. Assuming you are talking about the water temperature sensor, it is located (from standing over the front bumper) on the top, right side of the lower intake manifold. You will see it by looking under the bulge of the upper half of the intake manifold, the part with the air passages. It mates onto the lower intake manifold, which has water cooling passages, making it an ideal location for the water temperature sensor.
Mar 13, 2015 | 2001 Oldsmobile Alero
Why is my water sensor open
Do you mean your heater is saying water sensor open? Or your control?
Whichever one it is , simply replace the sensor, if it's the system giving you this msg the. Find a probe with a bandclamp on your plumbing and replace it .
If it's the heater giving the code then depending on what type heater you have, the temp sensor is located around the header area
Mar 07, 2015 | Jandy Aqualink Rs4 One Touch Control...
I need the location of water sensor on a1991 ford f150 5.o
Temp switch - Under hood, center, upper engine area, front of intake manifold, driver side of distributor, mounted in engine block,
Coolant temp sensor - Under hood, center, front engine area, passenger side of distributor, mounted in intake manifold,
There is no water sensor
Feb 14, 2015 | 1991 Ford F150
Model C0330SA-1A sump temp sensor failure
Sump temp sensor is not reading water temperature of water running over evaporator plate.This sensor is located in the water supply tube that runs up to the top of the evaporator plate. just pull the sensor out of the tube and replace it.
Jul 10, 2014 | Scotsman C0330SA-1A 350 Lb Half Size Cube...
Where is sensor located
where is fan sensor located
Jan 13, 2014 | 2008 Skoda Octavia 1.9
Getting an f-24 code, saw the solution page but it doesn't describe where the part is located or how to replace it. I am wondering if there is a way to reset the machine by unplugging or a reset button...
Hi, F24 error code a water temperature sensor error or enought hot water to the washer.
check to see you have both valves are turned on. Also, the water inlet valve on the washer has a screen and it is known to get clogged and restrict water flow. Turn off the hot water valve. Pull the hot water hose off where it attaches to the back of the washer.
Even if you are getting good hot water flow, inadequate water temperature can cause an F24 error code. Check the temperature setting on your hot water heater. It should be set at 120 F. You should reach this hot water temperature at your washer within about 1 minute.
If you are getting a good hot water flow, you may one of the following failures:
1 loose or dirty connection at the temperature sensor or control board.
2 The temperature sensor could be out of range. Bad or shorted sensor
3 Control board failure.
The temperature sensor should have a resistance reading of 6.6k ohms at 104 degrees F and should drop in Ohms as temperature rises,
The temperature sensor is located at the back lower section of the tub with 2 small black wires. It would require a ohm meter to measure the resistance of the sensor.
Oct 02, 2010 | Kenmore HE2 Plus Front Load Washer
Location of cam sensor
Cam Sensor is on the top of the Water pump located on the Front Timing cover. the Crank sensor is located rear the engine almost on the flywheel.
May 15, 2010 | 2000 Land Rover Range Rover
Washer only has cold water. Hot water is good to machine but only cold water enters machine on warm cycle, no water ar all on hot cycle.
Hello there
The Water System temperature sensor is normally what is wrong with these units with this condition that you are experiencing
The water system consists of the hot and cold water inlet valves, a water temperature sensor, a water
flowmeter and control and the dispenser distribution system along with a traditional pressure switch.
Water Inlet Valves -
The hot and cold water inlet valves are located at the back of the washer. These valves receive a control
signal from the Central Control Unit to manage the temperature of incoming water. The temperatures
are determined by the specific wash cycle selected and a temperature sensor located in the wash tub.
To improve cleaning of heavily soiled clothing and to provide a sanitizing feature, the water temperature
can be increased through the use of a heating element located in the bottom of the tub
Dec 25, 2009 | Maytag LAT3600A Top Load Washer
Cooling fan wont work
The water temp sensor is located near the thermostat housing. This sensor is what tells the ECM to turn the fan on/off. The water temp sending unit is located near the same area. You know you have the correct sensor is because the water temp sensor has a 2 prong plug. The water temp sending unit only has 1 prong.
Sep 26, 2008 | 1998 Chevrolet Cavalier
KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher Logo
52 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
