Question about Kenmore 24032\24036 Top Load Washer
Water Dripping Water is dripping from where the water comes out to fill the tub
    Sergeant:
    Champion:
  • 324 Answers
You need a new fill valve, even if you ulplug the washer does it still drip? If yes then you do need a new fill valve. Just turn water off at the wall so your machine don't overfill.
Posted on Nov 03, 2008
After wash cycle is finished I lift the tub lid and water is dripping into tub.
You may be looking at residual water dripping down from the rim. If the drip is located near where the water fills from, then you may have a water valve (could be either hot or cold side) that is not able to close completely. The valves are typically replaced, but sometimes cleaning can help for short term. Consult your user manual for removal / replacement instructions.
Aug 18, 2010 | Maytag Washing Machines
Water dripping into the tub. Whirlpool top loading washer
You just need to replace the water vale.
The valve is not closing all the way when its off.
Sep 05, 2009 | Whirlpool Washing Machines
GE WHDSR315 washer randomly drips still after done filling
you looking for a new water valve assembly...not very hard to replace..maybe a lil' messy
Aug 28, 2009 | Washing Machines
Water Level and Water continues to drip after cycle has ended.
The water dripping into the tub is caused by the fill valve solenoid not closing completely. The fix is to replace the fill valve. The overfilling of the washer is caused by the pressure switch. Over time the diaphram within the pressure switch becomes fatiqued & fails. The fix for this is to replace it as well... Hope this helps... Bill
May 18, 2009 | Maytag MER5775Q Electric Kitchen Range
Dripping shower head
If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
Jan 25, 2009 | Grohe Aquatower 3000 Shower Tower...
Water leaking from water output at top of washer
soundsas if you have a faulty, inlet water valve. your model is notshowing up on my part look ups, but definatly replace the valve( your water hoses are connected to it. in mean time make sure to turn off water inbetween loads
Dec 11, 2008 | Whirlpool GSC9455 Top Load Washer
I HAVE WATER DRIPPING INTO THE TUB FROM THE RINSE SPROCKETT
hot or cold? the water inlet valve may be cracked or lose...not that hard if you are a handy person!
Dec 05, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool washing machine, extra large capacity Plus. Water drips from the top back of the washing tub into the spun-dry clothes after doing a load. Dripping water source is higher and slightly to the...
it sounds is if you have a possible crack in the water supply area. if the hoses are good, tight and dry, inspect the housing base they screw into.
Aug 16, 2008 | Washing Machines
Washer tub slowly fills with water
Is your problem a SLOW FILL problem, or a problem with WATER DRIPPING FROM THE RUBBER DOOR SEAL - or BOTH? If you have a slow fill problem, this is generally caused by a bad fill valve, which can be attributed to hard water deposits or well water mineral deposits. Sometimes the fill valve can be removed, cleaned and reinstalled, but most of the time a new fill valve is required. If you are experiencing water leaking from the rubber door seal (bellow), it may be time to replace it. Sometimes the seal can develop a wrinkle or crease where it meets the glass, which can cause leaks. Water dripping from the door when you open after washing a load is normal. Water dripping during a load is NOT. The bellow may also have started to rip or tear inside the door which may not be noticeable until you pull the folds of the bellow back and look underneath it. I hope this helps.
Jan 17, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
128 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
