Question about Carrier Heating & Cooling
Cf appears after shutdown of aircon
Shutdown then cf appears
  • 499 Answers
Check filter if its running ok.
Posted on Feb 25, 2012
How do I get into the BIOS?
- Start / Restart
- At the Panasonic velcome screen, press the [F2] to enter the BIOS Set Up Utility
http://datasourcemobility.com/photos/CF-74_Care_and_Maintenance.pdf
Apr 05, 2015 | Panasonic Toughbook CF-74 (CF-74HCDAZBM)...
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • Mar 10, 2014 | Panasonic Toughbook CF-30K (CF-30K3PAQAM)...
    Chart details not appearing after removal.
    Same problem I had. After resetting unit and checking CF on another unit, Raymarine tech. said, the reader is not working. All pins seems to be OK on first look. I opened unit by removing several screws in front, gasket and the whole chassis from the case. Simple repositioning of pushed down pins from inside into the Compact Flash corrected contact problem of reader. Since then, I never removed CF. It seemed, after several reinsertions of CF, I pushed down two pins in CF slot.
    Jul 26, 2010 | Raymarine C120 GPS Receiver
    Problem with the CF card
    Do both of these CF cards still function when you connect them to the computer?
    Inspect the CF connector on the camera using a flashlight (torch). It's possible that one or more pins on the connector may have been damaged, somehow. If this is the case, the camera will need to be repaired.
    Can you still operate the menus after the error message appears? If so, use the menus to reformat the card (see the manual for instructions).
    Aug 08, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
    I am getting an error cf..tried to format card and get error 99
    I Googled the error code you're getting, and found a list of things to try and steps to attempt directly from Canon. Try out some of the stuff below, it should help.
    To isolate the cause of the issue, we suggest that you do the following:
    1. Turn off the camera.
    2. Remove the lens, battery, and CF card.
    3. Allow the camera to sit without power for approximately 20 minutes.
    4. Insert a fully charged battery, and turn on the camera.
    5. Depress the shutter button as you would to take a picture.
    Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
    2. Insert the CF card.
    3. Turn on the camera.
    4. Format the CF card in the camera.
    Does the “ERR 99′ message appear? If so, then the CF card is the most
    likely source of the issue. Try using a different card.
    If the message does not appear, please complete the following steps:
    2. Clean the lens contacts by gently rubbing them with a pencil eraser
    or soft cloth. Be careful that you do not let any debris fall into the
    camera body.
    3. Reattach your lens.
    4. Turn on the camera.
    If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
    If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
    Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
    Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
    Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
    To isolate the cause of the issue, do the following: -
    4. Insert only a fully charged battery, and turn on the camera.
    Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
    Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
    2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
    If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
    Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
    Err 99 & err cF in my canon 350d camera
    had the same problem before
    found this guide online
    camera body.
    Jan 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
    My camera say err CF
    These are steps to Fix Err 99's, have a go and see if resolves your other problem too.
    Dec 28, 2008 | Canon Rebel XT / EOS 350D Digital Camera
    No CF card
    The camera body has a tiny switch marked "CF" in one position and Sony's "memory stick" symbol in the other. Apparently I accidentally reset the switch from "memory stick" to "CF" while slipping the camera body into (or out of) its carrying-case. Once I had set this switch from "CF" back to the "memory stick" position, everything worked fine. Solution:  read the user's manual more carefully next time!!
    May 08, 2008 | Sony Cyber-Shot DSC-V3 Digital Camera
    Does not shut off
    Hi here are so links that may help you troubleshoot your shutdown issues... www.dove.co.nz/support/win98se-fix1.html support.microsoft.com/kb/238096 209.167.114.38/support/techsupport/tsbs/all/-TSB000739.htm This used to be a nightmare problem.. waaayyyy back..
    Aug 14, 2007 | Panasonic Toughbook CF-27 Notebook
    Heating & Cooling Logo
    1,171 people viewed this question
    Top Carrier Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Donni Steen
    Bill Long
    Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
