My Scott TV S/N 607607752 turns of while watching it. How do I keep it on?
My Scott tv turn off automatically whiling I looking at it. I have to press the button to turn it back on. It will stay on a few more minutes and go back off. What can I do? I have called the cable people and it is not the cable.
    Sergeant:
  • 195 Answers
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
My Scott TV  S/N 607607752 turns of while  watchin - power%281%29.jpg2_23_2012_11_31_16_am.png
After replacing blown capacMy Scott TV S/N 607607752 turns of while watchin - caps%281%29%281%29.jpg again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Posted on Feb 23, 2012
Turn off while watching
Main board fault. Shorted component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 07, 2014 | Dynex 55 Class LCD 1080p 120Hz HDTV
My Scott LCT37SHA TV will not turn on. I am
IF THE TV NO TURN ON THE FRONT LED IN RED CHANGE ALL 470 MF& 1000MF CAP IN POWER SUPPLY, FUSE AND VARISTOR DOWN THE BOARD. IF THE FRONT LED TURN ON IN RED ONLY CHANGE THE CAPACITORS.
Apr 04, 2010 | Scott LCT37SHA TV
First tv kept tuning on in middle of night now its kepts tuning off while ur watching
I don't know what might have been making it turn on in the middle of the night. It it keeps turning off while you are watching, you might want to check if:
1) someone is accidentially hitting the SLEEP button on the remote. The TV will turn off automatically 30, 60 or 90 minutes after the sleep button is hit. It can also get hit if you set the remote between seat cushions on the couch and someone moves, etc.
2) Does the TV get enough ventilation to allow heat in the TV to circulate away from the set? Drapes, tight cabinet, etc. The temperature sensor may turn the TV off automatically to protect the TV.
3) Your power cord is not well plugged into the wall or you might have some issues with the wall outlet - expecially if it is an older home (before 1980). Any wiggle of the cord may cause it to disconnect for a very short time - the TV will shut off.
4) This Brand is only available through BEST BUY and this model has a 1-year warrentee. The manual says to call 1-888-BESTBUY for service.
Good luck.
Please rate me.
Nov 23, 2009 | Dinex DX-LCD26-09 26 in. HD-Ready LCD TV
My brand new 40" SONY Bravia LCD TV picture goes darker or brighter while watching DVD movie automatically. It does not happen while watching regular TV. What setting should I turn off ?
This is a characteristic of the dynamic backlight used on this set.Turn off the dynamic contrast in the customer menu this should solve your problem.
Oct 15, 2009 | Sony BRAVIA KDL-40SL14098 40 in. HDTV LCD...
TV turns on and off while watching.
re solder the Electronic semiconductor , IC Specialy in power supply side. cold solder might the cause.
Jun 07, 2009 | RCA 27V520T 27" TV
New 42inch plasma turned off while watching, can't turn on
Panasonic requires an authorization number first from them. Our parts suppliers require that before we can even order the part. I recommend calling a svc co. to have it looked at, preferably an authorized panasonic service center, it will be much faster.
May 31, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
ILO sound quality
Had a similar issue and turns out I had accidentally switched my language pref to SAP rather than English. As soon as I changed it back, everything was fine...
Aug 10, 2008 | iLO 3200 32 in. LCD Television
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
