Question about Sport & Outdoor - Others
My 1997 mxz 670 quit while riding across the lake. Have spark but seems like it isnt getting any fuel. Any clue to what the problem could be
5 Suggested Answers
  • 51 Answers
SOURCE: 1997 sunfire won`t start
are you getting continuous spark? bad electronic module? check spark first. should be continuous. do you have oil pressure...some vehicles won't run if oil pressure is not there.
Posted on Jul 13, 2009
rjpoirier_nb
  • 166 Answers
SOURCE: I have a craftman 17 hp riding mower. it will
Remove the bottom bowl of the carberator and replace the needle-valve and float - cleaning this area as you do so.  Sounds like the float has a hole in it or the needle valve in the carb is sticking.  Use some fuel stabilizer prior to storing for winter next time, if not the old gas turns to shellac and makes things stick.
Posted on Jun 12, 2010
snowghost1
  • 784 Answers
SOURCE: I have a 1989 polaris indy 500 was riding on the
I don't know where you live -- but up here in Alaska ( where it is very cold ) we have problems with water getting into the fuel of just about everything ( condensation from sitting )and the snowmobiles I have here I have to drain the carbs every now and then to drain out the little bit of water that finds its way to the carb bowl. ( just a thought ).
could also be a blocked/dirty jet in the carb, to cover all bases I would remove the bowl from the carburetor and spray down all parts with carb cleaner and then re-install and then try and run the sled. ( 9 times out of 10 the problems are carburetor related ).
c...
Posted on Jan 23, 2011
j_allsbrook6
  • 79 Answers
SOURCE: I have a 98 mxz 670 what should my rpms be at when im cruising at 60 mine is at 7000 it seems like thats to high of rpm
normal 4-6 cyl cars rpm is 2100-3800get ur trans serviced
Posted on Mar 02, 2015
My king quad just quit when I was riding yesterday no sputter just died won't start fuel pump still works seems like no spark?? not sure I am mechanically challenged HELP
Pull plug hook it to wire and test for spark...place against bare metal and turn motor over,look at plug if u see spark ?? your good there if not try new plug could just be fouled., Then work your way through fuel system....
Dec 27, 2016 | ATVs
I have MXZ 600 Sport carb it dose not the power on top end that it should have top speed is only about 80 mph. Changed spring on secondary clutch and still no top end power. what else could cause this?
Ensure carb and all circuits are cleaned. Ensure float drop is correct. Ensure carb bowl is staying full (check clean or replace fuel filter). Check spark plugs, to ensure they are clean and called for by manufacturer. Check to make sure spark plug wires and boot are not losing spark ( run in a dark place and see if fire is noticeable with everything hooked up properly). Ensure gas is fresh and correct octane rating.
Feb 22, 2015 | 2015 Ski-Doo MXZ Sport 600 Carb
My 2000 harley sporster 1200 just quit, seem to be turning over but wont start, im thinking its not getting spark or something any sugestions?
I had the same prob with my sporty. Did you recently have it on reserve? If so check to lake sure it "clicked" back into run when you turned it back. Did you pull your plugs ? They should be grayish. Chech wires for spark
Jan 01, 2013 | 2000 Harley Davidson XL 1200 C Sportster...
97 K1500 5.7 liter Engine quit running. I checked timing, spark & fuel. All good but high mileage made me think wear on timing chain. I replaced timing gears, chain & distributor drive gear. I put...
need to get back to basics, first check engine compression-you say that it's high mileage, so I'd start there-If you have uniform compression across the board, move on to fuel pressure at the top rail-if that is good, with spark it has to run, but make sure your distributor is properly installed (not out 180 degrees).
May 29, 2011 | 1997 Chevrolet K1500
I have a craftman 17 hp riding mower. It will start and run but Then it will die like it isnt getting gas. Replaced the fuel filter and spark plug.i can let it idle for a few minutes and it seems fine. I...
Jun 12, 2010 | Garden
Jul 12, 2009 | 1997 Pontiac Sunfire
Engine coughs and stops after about 15 min. of cutting
check the vacuum line from pump to crank case fo leaks
Apr 25, 2009 | Garden
1997 cb500 won't start
finally sorted when I replaced both plugs. I've never come across one failing instantly before in 30 years of motorcycling (maybe that's because I ride old bm's!)
Feb 03, 2009 | 1997 Honda CB 500 S
97 jimmy wont start
Check for a bad distributor cap and or rotor..........a bad cap and or rotor can caues firing (cross fire)across the terminals and introduce spark to the wrong cylinders at the wrong time.......
hope this helps.....good luck!
Dec 14, 2008 | 1997 GMC Jimmy
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
