Question about Philips Televison & Video
Ambient lights went out
Side lights work top lights went out
    Sergeant:
  • 195 Answers
Try to replace inverter board..
Posted on Feb 23, 2012
Lights don't work automatically like before????? This is on a 1999 Oldsmobile 88 LS Not sure if I put this on last time I asked the Question
What light's ? Headlamps ?
The lamp control module (LCM) monitors the ambient light conditions through the ambient light sensor. The ambient light sensor is a variable resistor whose resistance changes as the surrounding ambient light level changes. As the ambient light decreases, the resistance of the ambient light sensor increases. The LCM measures the resistance across the ambient light sensor and determines whether it is day or night.
Does the vehicle have DRL - daytime running lamps - Twilight Sentinel ?????
Apr 28, 2018 | Oldsmobile Cars & Trucks
Locate the ambient light sensor
Automatic Headlamps- Vehicles with the automatic headlamps option are equipped with a unique headlamp switch that includes an A (Automatic) position and have a sun load sensor located on the top of the instrument panel to sense ambient light levels. When the A position of the headlamp switch is selected while the engine is running, the headlamps are turned ON and OFF automatically as ambient light levels dictate.
Feb 08, 2015 | Cars & Trucks
Multifunction Switch Short in Pontiac Grand Prix
Do you know how to do automotive electrical testing , checking B+ power and ground circuits , using voltage drop ? Do you know how to read a wiring diagram ? Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Electric Testing Techniques You Need to Know
How to read an electrical diagram Lesson 1
http://www.bbbind.com/free_tsb.html find wiring diagrams here !
The day time running lights module , ambient light sensor , would be a good guess but that's all it would be .Do you know what these are ? Really don't think there is a short in the multifunction switch . Maybe it's time to take to a qualified repair shop , dealer ! Cadillac or Buick .
Daytime Running Lamps (DRL)
The Daytime Running Lamps (DRL) control module is designed to automatically operate the exterior lights depending on the outside light conditions.
The DRL control module operates in 2 modes:
• The day mode
In the day mode, the DRL control module turns ON the low beam headlamps at a reduced intensity when the DRL ambient light sensor detects daylight under the following conditions:
- The ignition switch is in the RUN position.
- The headlamps are OFF.
- The park brake is OFF.
• The low light mode
In the low light mode, the DRL ambient light sensor detects darkness, turning ON the low beam headlamps to full intensity through CKT 10.
Additionally, the DRL ambient light sensor turns ON the following lamps through CKT 9:
- The park lamps
- The side marker lamps
- The license lamps
- The tail lamps
Mar 25, 2017 | 1998 Pontiac Grand Prix
Replace dimmer switch
The headlamps ( high an low ) are controlled by the LCM lamp control module .
Headlamp Dimmer Switch
Under the left side of the IP, on the base of the steering column
Headlights Circuit Description (Buick)
Battery positive voltage (B+) is supplied at all times to the lamp control module (LCM) through the LH underhood fuse block LCM/HDLP circuit breaker via CKT 242 (RED). When the headlamp switch is placed in the ON position, the headlamp switch input to the LCM is grounded via CKT 103 (WHT). The LCM then supplies battery positive voltage (B+) via CKT 12 (TAN) to the following components:
• Left low beam headlamp
• Right low beam headlamp
When the headlamp dimmer switch is placed in the HIGH position, the LCM removes battery positive voltage (B+) from the low beam headlamps. The LCM supplies battery positive voltage (B+) via CKT 11 (LT GRN) to the following components:
• Left high beam headlamp
• Right high beam headlamp
The LCM provides battery positive voltage (B+) to the appropriate headlamps under the following conditions:
• The ignition switch is in the RUN position.
• The ambient light sensor indicates darkness.
Search from over 10 Million Auto Parts
Do you know how to test automotive electrical circuits ? Check power in an power out . Videos on youtube on basic automotive electrical testing .
Mar 08, 2017 | Buick LeSabre Cars & Trucks
Ambient sensor gauge stopped working correctly at the same time the AC quit
The ambient temp sensor is related to the AC function, if the HVAC system thinks the outside temp is too low, the AC will not be turned on. You probably have a defective temp. sensor. It is easy to change and relatively inexpensive. It is located on the underside of the top radiator support almost in the center (just to the drivers side of center).
The car dying at a stop light can probably be solved by cleaning the throttle body. Make sure that both the front and rear sides of the throttle body are cleaned. And also disconnect the battery during the cleaning process, this will reset the computer and allow it to relearn to the cleaned throttle body.
The compass issue is another separate issue and may just require a recalibration. I don't know what the procedure is but try Googling the subject.
Jul 25, 2012 | 2004 Chevrolet TrailBlazer
Daytime running light module location 2001 impala
The daytime running lamps in your 2001 Chevrolet Impala are controlled by the Body Control Module (BCM) Here is a description of how the system works:
The ambient light sensor is a light-sensitive transistor that varies its voltage signal to the Body Control Module (BCM) in response to changes in the outside (ambient) light level. When the BCM receives this signal, the BCM turns ON either the DRL or the headlamp relay for auto headlamp operation. Any function or condition that turns ON the headlamps will cancel the DRL operation.
Thirty seconds after you start the ignition with the headlamp switch set in the OFF position, the DRL will perform one of two actions:
Illuminate the high beam headlights at a reduced intensity in daylight conditions
Illuminate the low beam headlights in low light conditions
The DRL/EXT lamps fuse in the top of the engine fuse block supplies battery positive voltage to both the DRL switch contacts and to the DRL relay coil. When the BCM energizes the DRL relay coil, current flows through the right high beam lamp, to the left hand high beam lamp, to the energized DRL relay switch contacts, to ground G101.
The high beam headlamps are now in series, and split the voltage so that the headlamps illuminate at halt intensity. The DRL operates when the ignition switch is in the RUN position, and the parking brake is not set or the transmission is not in park. When these conditions have been met and the ambient light sensor indicates daytime conditions, the DRL will illuminate.
Oct 10, 2011 | 2001 Chevrolet Impala
2000 Pontiac Grand Am SE Remove Ambient Light Sensor
Actually, just wipe it off with a soft clean cloth. Shouldn't get too dirty, maybe dusty with road grime as the other parts of the interior.
Perhaps there is a problem with the circuit.
Jul 04, 2010 | 2000 Pontiac Grand Am GT
Where is daylight sensor on 1999 gmc safari
on the dashboards top section near the drivers side
Jan 14, 2010 | 2003 GMC Safari
My ambinent light is blinking on my hp touchsmart. the button on the left on the computer turns the light on and off and has three settings. currently, it blinks through all three settings then turns off...
sounds like either the switch controlling the light is not working or the or the abient light is burnt out causing a short. If under warranty Have this check out by an Hp Tech.
Apr 01, 2009 | HP TouchSmart IQ770 PC Desktop
The screen on my Apple Powerbook G4 goes dim and sometimes out.
How long before it goes dim?
Does it start strong, then dims right away?
Feb 27, 2009 | Apple iMac G4 Desktop
Televison & Video Logo
22 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
