Question about Sewing Machines
How to thread a consew cn-2230 - Sewing Machines
I am having trouble threading the bobbin on a consew cp 206R. I can't figure out what to do with the thread to anchor it in order to load the bobbin. I usually use an origional electric Singer machine that...
If I understand your trouble, I put the bobbin on the machine ready to be loaded with thread. I feed the thread from the inside of the bobbin through one of the holes to exit on the outside. I hold tight onto the thread and start up the bobbin feed drive. once it is covered by several layers of thread, you can let go since the thread will not slip out.
If I did not understand your question, here are a few sites that show how to thread the Consew CP 206R as well as how to "reset" the timing if you happen to get a jam while sewing. http://www.youtube.com/watch?v=PIKml4yGLSc
https://www.google.com/search?q=consew+cp+206R.&oq=consew+cp+206R.&aqs=chrome..69i57&sourceid=chrome&es_sm=0&ie=UTF-8
http://www.youtube.com/watch?v=H-pL2vISk2k
If you want to download a manual: http://www.devicemanuals.com/productsupport/Consew_CP206R_manual.html
Good Luck and Happy Sewing!
May 18, 2014 | Singer 3116 Simple
How to thread Consew Industrial Sewing Machine 206RB
Every machine is a little different, but the basics are the same. Our 7th grade Home Eco. teacher taught us the first day...
"...Start at the thread spool, thread guide, thread guide, tension, take up lever, thread guide, thread guide, needle. Learn this and you can thread any sewing machine"
she was right, As this hold true for my kenmore, juki, singer and new home machines. Same basics for industrial machines too.
Hope this helps.
Sep 16, 2012 | Consew 206RB5 Sewing Machine
Need a threading diagram for a consew694ex
I found two things for your consew, but neither of them have threading information. Generally, you thread a serger like this. Upper Looper, Lower looper, needles from right to left. If you ever break a thread... remove all other threads and begin again from the upper looper thread. (I know... it's a pain) Here's a video that is NOT your machine but explains pretty well.
http://www.youtube.com/watch?v=zt8G9kw-U_s&feature=related
I included the documents I found in case you need them.
Parts Info (keep for future reference) http://consew.marginspluslive.com/images/products/parts%20books/693ex.pdf
maintenance info (keep) http://consew.marginspluslive.com/images/products/instruction%20manuals/694.pdf
Aug 23, 2012 | Sewing Machines
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
How to thread a consew 7360R
There is below the link to the Instruction Manual for your Consew 7360R sewing machins.
Enjoy!
http://consew.marginspluslive.com/images/products/pdf10/7360r-rh-rbboth.pdf
Sep 02, 2011 | Consew 7360R-1 Mechanical Sewing Machine
I need a manual for a model 230 consew, I recently bought it from a friend, I want to learn how to thread it, and wind my bobbins, can you help me, unable to find one
You can go to the consew official website and download the PDF file for the 210 model. It's the same as the 230 r-1 (which i have). I found this information by calling the consew headquarters. You can also download a PDF with the full parts list for the 230 model specifically. This link may help http://www.consew.com/default.aspx?pageId=4
Apr 06, 2011 | Sewing Machines
The thead keeps jumping out of the thread controller on my consew 226. Any idea how to fix the problem? Thanks
I had a sewing machine that the thread would jump off the thread guide & it had to be bent just a little with small plyers to keep the thread from jumping off constantly
hope this helps
Jul 27, 2010 | Consew 206RB
Consew 230 continually breaks top thread at needle
What size thread are you using? With thicker fabrics, you should be using at least a size 50. Even a 30 would be better.
Oct 18, 2009 | Consew Sewing Machines
Thread tension for Brother XL 2230.
If you have pattern dials set correctly then I might guess that one or more sets may have been missed when the thread was being set up in the machine. most of these models show either arrows or numbers for each or way the thread needs to be routed.
Apr 26, 2009 | Brother XL-2230 Mechanical Sewing Machine
Sewing Machines Logo
116 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
