Question about Emerson Televison & Video
My say this TVs does not support the output format video resolution and or refresh rate being sent by the connected device
2 Suggested Answers
SOURCE: Refresh rate at 60 Hz?
http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=02010100&model_name=LN52A630M1F
According to the Samsung website, the on-screen information is in relation to the incoming signal, not the TV settings which are being displayed.
As long as you have the 120 Hz turned on, the TV will display the picture at that refresh rate. However, the on-screen information will not reflect that.
Very ood.
Posted on Feb 13, 2010
Component input ports not working
If its only 1 month old, first try a different device in place of the XBox if it still does not work, take it back and ask for a replacement.
Dec 21, 2013 | Zenith Z50PX2D 50 in. Plasma HDTV
Tip
How to troubleshoot video issues?
Instruction:
To troubleshoot video issues, follow these steps and test your video after performing each one:
  1. Check the video signal cable connector for bent or missing pins. Check the cable for cuts.
  2. Check to see if moving the monitor connections slightly causes color changes. Tighten loose connections.
  3. In the case of systems with multiple video output connections, verify that the correct connection is being used.
    • Some systems ship with two video connectors on the back, however only one is enabled.
matrix12.jpgExample of a desktop computer equipped with 2 video output connectors.
  1. Standard on board video connection
  2. Optional video adapter connection (some models)
  1. If the monitor has multiple inputs, remove the secondary connections from the computer.
  2. Remove all signal cable extensions and Keyboard, Video, and Mouse (KVM) switch boxes.
    • Use of these devices can result in severely degraded video quality or no video symptoms.
  3. Eliminate wire bundles and magnetic fields from nearby appliances, such as those from speakers, as possible influences on color quality.
  4. If applicable, remove and reseat the video adapter card.
  5. Check to see if the display is visible and check for proper color during startup.
  6. Verify that the video is working by booting to the operating system in Safe Mode.
    • To enter Safe mode press F8 when the Windows logo first appears on the screen during system startup.
  7. Ensure that the most recent video driver has been installed.
    1. Right click on the Windows desktop.
    2. Click Properties.
    3. Click the Settings tab.
    4. Click the Advanced button.
    5. Click the Adapter tab.
    6. Click the Properties button.
    7. Click the Driver tab.
    8. Compare the Driver Version: with the current version and update if needed.
  8. Run the monitor setup program.
    • Some monitors are supplied with setup programs on CD-ROM or diskette. Follow the manufacturers directions.
    • Readability can be improved on some systems by running the Microsoft ClearType tuner.
  9. Check video quality by changing the hardware video adapter to the lowest available resolution.
    4. Use the Screen resolution sliding selector to change resolution.
      The resolution selections available should be limited to the capabilities of the video adapter.
    • Some of the selections available may exceed the monitor capabilities and result in a temporary black screen.
    1. Click OK.
    2. Compare results with other screen resolution selections.
  10. Ensure that the display being used can support the video refresh rate and screen resolution specified in display properties.
    • The manual for your monitor should list the supported refresh rates and screen resolutions.
    • Open the Display Properties dialog box to verify that the refresh rate and screen resolutions are set properly:
      1. In the Properties window, click Settings.
      2. Click Advanced.
      3. Select the Monitor tab to view or change the refresh rate for the monitor.
Notes:
  • Some system boards ship with the AGP slot disabled and plugged. These slots have been disabled at the chipset level and do not work. The plugs should not be removed.
  • Some AGP adapters use a retaining clip, which must be moved to one side to prevent damage when removing the adapter.
  • Setting the video resolution to 640x480x16 colors in Device Manager is not the same as changing the hardware to a VGA adapter. You must change the adapter selection from the installed adapter, i.e. ATI, nVidia, or Matrox, to a standard VGA adapter in the Display Properties dialog box.
  • Some Intel chipsets uses Dynamic Video Memory technology (DVMT) for video memory. The initial memory count can indicate less than expected system memory count.
  • Signal cable extensions and keyboard, video, mouse (KVM) switches are not supported.
on Jan 21, 2011 | Computers & Internet
Out of Range problem with LED 19 inch viewsonic monitor
What is the source for the signal to the monitor? First, if the source is a computer, was the computer previously connected to a CRT monitor? If this was the case, you may have the wrong refresh rate as well as the wrong resolution being sent to the video port. Reconnect the computer to the old monitor (if possible) and reset the refresh rate to 60 Hz.
Next connect the monitor to the computer with both devices off. Then turn on the monitor and set it to the correct input (if needed). Then turn on the computer. Most versions of Windows should determine the best resolution for the monitor. (Some Unix versions and recent versions of the Mac OS will also automatically find the correct resolution.) If you are still getting the out of range message, you need to change the video resolution with a different monitor connected and then retry. Always turn on the monitor first.
For additional support, please add a comment with the specific monitor and source that you have. In a few cases, the video card/on-board video may not be able to output the correct resolution or lose the correct setting when the monitor or computer "sleep".
I hope this helps.
(I've seen most "out of range" messages with several TVs that were connected to computers and turned on and set to the computer input after the computer booted up.)
Aug 12, 2012 | ViewSonic Computers & Internet
We have a bang and olufsen beovision 7 40 inch tv. when we try to connect our laptop through vga port the tv appears blank without any display, tried connecting the laptop through dvi port also. The...
First, try setting your monitor refresh rate at 60Hz using a known-working monitor. (The VGA input of the Beovision 7 is recommended for 60Hz refresh rate). If this fails to produce output from the Beovision 7, it is very likely, your video driver's resolution is set too high for the Beovision 7 to display signal. If you are using the Beovision 7 as your primary monitor, first connect a known-working monitor to the computer and reduce the resolution to 1024x768. Once you have changed the resolution, try connecting the Beovision 7. If you get video signal, increase the resolution incrementally until you find the maximum resolution the Beovision 7 will handle.
IF YOU ARE USING THE BEOVISION 7 AS A SECONDARY MONITOR USING EXTENDED DESKTOP, reduce the resolution on Monitor 2 output to 1024x768. If video appears on the Beovision 7 at that resolution, incrementally increase the Monitor 2 resolution until you find the maximum resolution the Beovision 7 will accept as a secondary monitor.
Jul 14, 2011 | Televison & Video
I would like to use my Sylvania LC320ss8 Flat screen tv as a computer monitor but when I plug in the monitor plug the screen on the tv says format not supported. My operating system is Windows 7 and...
If you have connected the TV to the computer with a VGA cable, what resolution was your previous monitor using? You may need to change the resolution or refresh rate with your regular monitor attached. This TV has a native resolution of 1366 x 768 .
If you are connected via one of the HDMI ports, check the specifications for your TV. Then try using the VGA output. Not all TVs support a computer signal over HDMI. Unfortunately, I can't find the LC320ss8 at the Sylvania Support site: http://www.sylvaniaconsumerelectronics.com/ . If the model number has an error, click on Downloads and enter the correct model number.
I hope this helps.
Mar 31, 2011 | Sylvania LC320SS8 32 in. LCD Television
How do i connect my pc to my LG 32LF77SO I CAN GET SOUND AND VISION
Most HDTVs today have a 15-pin VGA input so to hookup a PC, just connect a VGA monitor cable from the PC monitor output to the HDTV VGA input port. This gives you video. For audio, you can connect a stereo audio cable (3.5mm) from the PC soundcard speaker jack (usually green) to the HDTVs audio input port next to the VGA port. Next you need to adjust the settings for video resolution and refresh rate on the PC so that the HDTV is compatible. Look in the HDTVs owner's manual for a chart showing the acceptable video screen resolutions (1024 X 768) and refresh rates and adjust the PC accordingly. You should now have video and audio on the TV. For a laptop, it depends on what outputs it has, VGA, HDMI or S-Video but this can be done as well.
Mar 26, 2011 | LG Televison & Video
When i try to connect my laptop to my rca l40fhd41, it will show for a few seconds then a message comes up on the tv "unsupported" and it wont work as a monitor.
You need to reset the laptop video screen output resolution and refresh rate to something compatible with the HDTVs acceptable parameters. Consult the TVs owner's manual for a chart showing the acceptable screen resolutions and refresh rates. You are looking for numbers like 1024 X 768 or 600 X 800 for screen resolution. Your laptop will allow you to setup different screen resolutions for output. You just have to find one the TV likes.
Mar 23, 2011 | RCA L40FHD41 40. in HDTV
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
LCD TV and VGA output
The resolution and refresh rates have to match exactly to the TV for it to work correctly with the computer.
The newer computers are using much faster refresh rates by default. Their default resolution is also different.
Consult the manual for the TV and see if the computer's external monitor output can be set to match to what the TV exactly requires. Both the refresh rate and resolution are critical.
Jerry G.
Apr 20, 2008 | Televison & Video
Televison & Video Logo
773 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
