Virus suspected.. netygxbqx.dll
Rundll32 and many others want netygxbqx,dll and give error message that it is not there (I deleted it!). What will clean it out of my registry of load commands?
Just did a re-install, found no reference to the netygxbqx.dll that I removed but was still searched for... it stuck in load from many other apps... could not find where it tied in? Suspect a randomly generated name not in virus databases...
Posted on Apr 15, 2012
5 Suggested Answers
yashrajsen
  • 61 Answers
SOURCE: virus deleted
try to use kaspersky antivirus and uninstall other anti viruses and scan the system.
If no changes takes place then better format the system again to work on command
Posted on Jul 10, 2009
SOURCE: I have a virus in my Registry which I must delete.
Why don't you try a system restore first, may work, and will be less work?
Posted on Feb 15, 2010
marketex
  • 371 Answers
SOURCE: I have a virus lodged in Drive C. I have tried to
NOT time for a new computer, unless the virus is in the memory and the bios and elsewhere such as graphics memory.
Contact Microsoft by phone and let them know that you need to use the C(ertificate) O(f) A(uthenticity) on a brand new hard drive to which you will install windows after the removal of your suspect drive.
If you are comfortable doing this, you already have enough info from me on the process and if you are not comfortable with the process, turn it over to a nerd near you.
Posted on Apr 24, 2009
jim4984
  • 797 Answers
SOURCE: Is there a safe way to get rid of this? What is it
If you have the correct spelling (the posting does not contain the \\) then you most likely have a virus or other malware. There is now listing for Saxibagog.dll on the Internet which means that is is most likely a random name used to help prevent removal. i.e everytime you delete the file, it will replicate with a new name. You should run a full scan of the computer with an up2date anti-virus
Posted on Mar 13, 2010
Testimonial: "Awesome..."
Error rundll32
at pc? more info? i think wrong section ^_^
What is rundll32.exe (rundll32.exe error)?
rundll32.exe (rundll32.exe error) Description: Rundll32.exe is a program which would have been on your pc since the day you purchased your pc. Always verify the exact disk location as many virus and spyware writers will attempt to fool you by using a similiar name or same name in a different location. This file is part of the Microsoft Windows operating system. Rundll32.exe will actually execute functions in DLLs. If you are deleting files on your computer as a spyware removal protection method, then note that this is a required system file. Note that rundll32.exe can also be running many different other DLL or EXE programs, so you may want to check the programs listed after it in your startup list also, as these may be executed by it. Rundll32.exeis considered safe and is not spyware, adware, or virus related and does not need to be removed.
rundll32.exe error: rundll32.exe error. Be sure to always double check your spelling if you are concerned about spyware, as often spyware will use a very similiar spelling of system processes or other common tasks. rundll32.exe error
Click here to remove rundll32.exe virus
remove rundll32.exe virus: Remove rundll32.exe virus. Remember that although many files are always in default file locations, some files can easily be moved to different locations or change names like many spyware, adware, or popup programs do. If you suspect you have spyware or adware, check to see if you see a similiar names stored elsewhere. It always helps to check your tasklist also to see what is currently running on your computer. You can always view the tasklist on your computer by pressing ctrl-alt-del to view your "task manager", and then click the "processes" tab. This will show you all tasks running on your computer. Dll files will NOT show on your computer tasklist, as dll files are actually part of other processes. You may see similiar program names running if spyware or adware is on your computer, for example, ati2evxx.exe may be slightly misspelled to keep you from finding it, or spyware and adware may be named very similiar to a system file. Make sure always check the location of tasks or processes if you are concerned.Remove rundll32.exe virus
rundll32.exe Common Path(s): This will be found in your windows\system32 folder. You will see it starting up programs like: RUNDLL32.EXE C:\WINNT\System32\NvCpl.dll,NvStartup
^_^
Apr 20, 2014 | Nokia Asha 201 Blue Unlocked Dual-Band GSM...
Tip
How do I fix rundll32.exe on Windows XP?
Rundll32.exe is an important process for the Windows operating system. The process rundll32.exe take the dll file and put their libraries in the system memory. Without this process, the computer should be unstable and very slow.<br /><br />The process runs from your system directory C: \ Windows \ system32. If it executes or runs from elsewhere is most likely a virus or a Trojan. You should scan your computer immediately with a virus scanner. Viruses using the name rundll32.exe are W32.Miroot.Worm. Backdoor.Lastdoor and Trojan.StartPage (among others).<br /><br /><span style="font-weight: bold;">Fix rundll32.exe</span><br /><br />If a virus, such as Netsky, destroys rundll32.exe or, if for any reason, your rundll32.exe is corrupt or is accidentally removed, you must do the following:<br /><br style="font-weight: bold;" /><span style="font-weight: bold;">Find rundll32.exe DC system</span><br /><br />Check if you find a copy of rundll32.exe in the folder C: \ Windows \ system32 \ dllcache or in C: \ Windows \ Service Pack Files \ i386. If yes, go ahead and copy rundll32.exe to the system directory C: \ Windows \ system32<br /><br />If you can not find a copy on your system, try to locate the file on your Windows installation disc. Finally, you just reinstall Windows. It would be time consuming, and you may lose all your data. So what would be the last resort.<br /><br /><span style="font-weight: bold;">First, run a system repair tool to fix rundll32.exe</span><br /><br />There are various tools on the Internet that scan, analyze and fix your computer. In addition to solving your rundll32.exe these tools to remove all registry errors, remove invalid shortcuts and duplicate files, repair DLL files, and remove the errors start-up and running.<br /><br />
on Mar 07, 2011 | Computers & Internet
Emachine will not run anything
Rundll32.exe errors typically occur in response to the inability of Windows to access an application, program or file as the result of a corrupted or missing DLL (Dynamic Link Library) file or in response to a rundll32.exe virus that has been designed to look like a normal Windows process.
Here are the easiest ways to fix rundll32.exe errors.
Click "Ctrl + Alt + Delete" on your computer's keyboard to open the Task Manager window.
Click the "Processes" tab and search for a rundll32.exe program.
If one is running and appears to be accessing a lot of your system's resources, click "End Process" as it is likely a malicious program and not a true Windows program.
Run software to seek out, detain and remove viruses, malware, spyware and adware. Often these malicious programs corrupt DLL files or cause them to be deleted or moved and, as mentioned, some rundll32.exe programs may in fact be viruses on your system.
Reboot your computer to update any changes you may have made recently to your files and programs.
Many programs and applications require a reboot for successful installation.
Uninstall a recently installed or changed program or application and then reinstall it using the default settings.
An installed program may not have loaded properly, an installation via the Internet may have been interrupted enough to create errors or the program may have a bug.
If you uninstalled a program and see a rundll32.exe error, reinstall the program and then uninstall once more.
Retain the services of a Microsoft certified technician, if all else fails, to review and fix your system's Registry.
Dec 01, 2013 | E-Machines Computers & Internet
Deleted dll called from everywhere
system restore is a good idea for this. it may be a virus. backup your data with cautious. i would connect the hard disk to another PC with antivirus installed and copy the files I need over.
Mar 01, 2012 | Microsoft XP Computers & Internet
When trying to scan, my scanner software program comes up with "twain_32.dll" not found. My HP PSC 1350 Printer/Scanner has always worked before.
http://www.fix-all-dll-errors.com/twain_32.dll/
Just visit this site...this will help in case of missing or downloading dll's , also if dll's are corrupted or errors in dll's..!
I also registered few dll's from this site...worked in my case. :)
Dec 24, 2010 | HP PSC 1350 All-In-One Thermal Printer
Windows XP boot after an error, it can not find the file shfolder.dll, and is included in the Windows folder. What do I do?
http://www.fix-all-dll-errors.com/shfolder.dll/
This will fix the issue without any botheration.find that dll here :)
Dec 15, 2010 | Microsoft Computers & Internet
Cant get automatic updates from mirosoft.cant down load .cant find rundill 32 exe.cant find help suport .
What is rundll32.exe? Is rundll32.exe spyware or a virus?
This program is part of Windows, and is used to run program code in DLL files as if they were within the actual program. However, many viruses also use this name or similar ones. This file is also commonly used by spyware to launch its own malicious code.
Note: The rundll32.exe file is located in the folder C:\Windows\System32. In other cases, rundll32.exe is a virus, spyware, trojan or worm!
If you don't have this file in System32 then you have other problems. Possibly a virus is onboard.
Oct 06, 2010 | HP Computers & Internet
Is there a safe way to get rid of this? What is it in any case? Someone suggested that i go to the registry editor and delete it there. I'm here looking for a second opinion thank you. O4 - HKLM..Run:...
Mar 13, 2010 | Microsoft Windows XP Professional SP2
What is rundll 32 and how do i get rid of it
rundll32 is a program that windows uses in order to launch dll (library) files.
Deleting it will adversly effect your computer. (you won't be able to launch many programs)
There are some viruses that infect run32dll, if you are having virus issues I'd suggest running a scanner. If this is just something you've noticed taking up a lot of system resources and running in the background it's not something you want to delete.
Mar 18, 2009 | Toshiba Satellite L25-S119 Notebook
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
