Question about Samsung N145JP02 Netbook
Error screen comes up after start up.
When i start my samsung N145 notebook up on battery power most times it will load windows then go to this blue screen saying an error has occerred and then switches to the black screen that askes if you want to start windows in safe mode or normal mode. sometimes it does this once and the notebook will be fine but other times i may do it 3 or more times in a row, But it hasn't happened when main power in connected.
  • j
    j Feb 23, 2012
    i forgot to mention i took the notebook back to where i bought it and told them the problem, they took the notebook and put a new hardrive in but problem still there.
  • 669 Answers
Must have been the guys in the blue shirts....Blue screen issues are normally caused by memory problems. If you are somewhat computer savy and know how to add or remove memory, try this. Take out one the memory chips, see if you get the blue screen any more. Then swap and do the same test on the other chip. If one has the issue and the other does not, replace the suspected bad chip.
Hope this helps.
p.s. If the computer is still under Samsungs warrenty (1year), contact them directly, you will have better luck with repairs than where you purchased the computer from.
Posted on Feb 23, 2012
  • j
    j Mar 18, 2012
    Hi Jeffrey, Thank you for your help, i'm going to try this. I'll report back if it does or doesn't work. Thank you again very much for your help.
Why would a samsung n145 plus notebook suddenly stop working?
Could be a bad DC jack so may not be charging the battery at all. Or you bought a charger that was the correct voltage and not the correct amperage.
Jul 18, 2014 | Samsung N145 Plus 10.1 inch Netbook -...
My laptop turns on, you can put in the password but it won't load and the blue screen comes on and then it restarts itself. It's a Samsung 530. Please HELP. Thank you!!!
i have had one of these myself... this pc suffers from various problems, mostly motherboard. Your specific problem has happened to a couple of friends, both filled their drives up so much that it "blue screened" We all know blue screen is often terminal. Your machine is getting on now. clear your drive up from DOS and windows ( delete unneeded files at start up, not through windows if possible.
Nov 21, 2012 | Samsung R530 Notebook
Samsung n145 battery is not working
allright,battery not charging right? it's might be that the battery itself working properly,but the system doesn't indicate that the battery is charging,because of error in the battery management software,in order to fix the software,you need to reinstall the software by using device manager,to Open device manager,right click on My Computer,and select Properties,when the Properties windows appear,click on the Hardware tab,and you will see Device Manager button,click it and Device Manager window will appear,or you can go to Start,and type Device,then select Device Manager
Expand the Battery category,and right click on Microsoft ACPI Compliant Control Method Battery listing,and select Uninstall
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
On the Device Manager taskbar, click Scan for hardware changes .
Aug 27, 2012 | Samsung N145-JP01US Netbook
Samsung n145 will not power up
Related to a Samsung Np-n145 Notebook PC:
Plug the laptop into power for 24 hours. See if the Battery charges up.
Next test, or have tested, the AC adapter (Charger) See if it is putting out 19 Volts -> DC.
Know someone with a multimeter? I can guide you in testing.
AC adapter is good? Things go downhill rapidly here.
The next problem could be a DC Power Jack.
The DC Power jack is the jack on the laptop, that you plug the AC adapter into,
1) The DC Power jack may be broken
2) The solder joints holding it to the motherboard may be cracked. Poor connection to motherboard.
The DC Power jack can be replaced, or it's solder joints re-soldered.
DC Power jack proves to be okay?
Power MOSFET's have gone bad. The next link, is an article that deals with bad Power MOSFET's in an HP laptop. Used for an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Let's hope it's a bad AC adapter
Regards,
joecoolvette
Jul 18, 2012 | Samsung Notebook Np-n145 10.1" Laptop...
My Samsung N145 Battery does not power the notebook
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 27, 2012 | Samsung NP-N145-JP02US NETBOOK
My Samsung R530 won't boot, just shows blue screen of death on startup, states "A problem has been detected and Windows has shut down to prevent damage blah blah blah Unmountable_boot...
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jul 12, 2011 | Samsung R530 Notebook
I get blue screen when starting up it says cant find windows
Most of the time when you get this kind of error, you have a bad hard drive. Good luck.
If this was helpful, please rate it high. Thanks.
Apr 21, 2011 | Samsung N145-JP01US Netbook
Blue screen error and hard disk could not detected in first boot
Tap alt gr + F10 at the same time as soon as the system turns on before it loads windows , it will give recovery console, you can restore to factory defaults which will wipe everything in the system
Jul 01, 2010 | Acer Aspire One PC Notebook
Crash and blue screen with error message
You would first need to make sure Windows does not restart automatically when a blue screen error appears. Then you can analyze the problem and fix the cause.
Have a look at BSDO error fixing.
Feb 22, 2009 | Samsung NC10-14GW Notebook
Samsung N145JP02 Netbook Logo
208 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
