My Epson ME32 printer has no power after i reset the ink cartridge. How can i fix this problem?
cns assoc
  • 677 Answers
SOURCE: My printer will not recognise non epson cartridges
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!! How you were able to use generic is amazing. I was not able to do that!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
TRYING PURCHASING GENUINE, and see what happens? This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Jan 31, 2010
cns assoc
  • 677 Answers
SOURCE: Epson TX100 won't recognise ink cartridges.
Yes, Genuine Ink Cartridges.
Did you use Epson Genuine Cartridges?
That sounds like your problem.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
Posted on Feb 05, 2010
Testimonial: "Thanks for your help. I have started using generic cartridges as I did with my Canon for years. Your help is much appreciated."
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Posted on Mar 24, 2010
SOURCE: printer epson R230X both light blinking catridge not running
reinstall your printer driver.
Posted on May 02, 2010
  • 4 Answers
SOURCE: Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
Posted on Oct 25, 2010
How do I reset my Epson T200XL ink cartridges?
Resetting the Epson Ink Cartridge Chip With Software A freeware program called SSC Service Utility enables users to download and install software that helps to manage their Epson printer. The software offers several functions, one of which is resetting the ink cartridge chip. Other settings allow users to freeze the internal ink counters or to reset the internal ink counters. It supports over 100 Epson printer models, but some printers may not respond to the commands from the software.
Using a Cartridge Reset Tool A cartridge reset tool is a small plastic piece that fits against the cartridge. The contacts on the reset tool correspond to the contacts on the printer's ink cartridge. When connected to the ink cartridge, the cartridge reset tool indicates the resetting of the ink cartridge with a green LED light. The reset tool is beneficial not just for resetting the chip, but also for allowing the printer to use all of the ink in the cartridge.
Troubleshooting Issues With the Reset Tool
Buyers should be sure to check the description for each reset tool carefully to determine whether they can reset their Epson printer cartridge with the tool. If the wrong cartridge is attempted or the reset tool is simply unable to reset the cartridge, users see either a red LED light or no light at all. In some cases, they simply cannot reset the chip any further. Before disposing of a reset tool, always test it on multiple ink cartridges.
Apr 07, 2016 | Epson Office Equipment & Supplies
My epson stylus tx121 cannot recognize my cyan ink cartridge. it cannot print any documents with blue colors. i tried to remove and replace the ink cartridge, turned the unit on and off but to no avail,...
All you need to do is to reset your device using the software resetter
this link :http://www.4shared.com/get/Tct88J0Z/ME320-TX121.html;jsessionid=915B4C7E4E51E44E0A13252FEA1C0E4F.dc516
Download the software run the program,accept the condition given and select the particular adjustment or do this steps;
1. Download the ME32 T121X RESETTER, extract it to your designated folder.
2. Run the Adjustment program and click ACCEPT to continue.
3. Click model name ..there are two options.ME 32 or T121X .
4. Click DESTINATION or location at present then click ok.
5. Click PARTICULAR ADJUSTMENT MODE then select WASTE INK PAD COUNTER.Then click OK.
6. Check two boxes the MAIN PAD COUNTER and FL BOX COUNTER then Click INITIALIZATION.
7. Icon box prompt and you to turn on and of the printer device>>then its all DONE>>>
Aug 03, 2011 | Epson Stylus C86 InkJet Printer
How to refill ink cartridge of Epson me32?
Follow these steps:
1.
Buy an Epson ink refill kit. A refill kit gives you all the tools you need to refill Epson ink cartridges. Kits typically include a syringe, rivets, ink, and instructions on how to refill the cartridge. You can find Epson ink refill kits on the Printer Filling Station along with instructions for each specific model (see Resources).
2.
Cover your workspace with a paper towel and fill up the syringe with the ink color you need. Epson refill kits will either include black ink or the color combination cyan, yellow and magenta. On average, you'll need 10 ml of black ink or 5 ml of color ink for Epson ink cartridges.
3.
Find the rubber seals on the back of the Epson ink cartridge. Insert the rivets into each seal.
4.
Empty the contents of the syringe into the Epson ink cartridge. You'll want to perform this action slowly in order to avoid spilling or overfilling the cartridge.
5.
Remove the rivets. Use tape to cover the holes you made in the ink cartridge. Return the ink cartridge to the printer. Allow the printer to go through several print cycles in order to ensure that the Epson printer operates properly.
In case of any additional help please revert back
Jun 12, 2011 | Office Equipment & Supplies
Epson Stylus NX415 does not recognize ink cartridges. Cartridges are Epson 88's. Worked for awhile, and then stopped recognizing them. Tried powering down the printer, cleaning the cartridges, turning...
Epson Printers are sensitive in terms of Ink Cartridges.. The latest Epson Printers does not have ink reseter.. Ink reseter are already built-in on the ink cartridges.. The problem on this printer is when you have a cartridge on your printer, let say, 30% of the ink level, even though your ink is new, and you change it without using the right ink replacement method, it will recognize your ink as a 30% ink level. When your ink level drops to 0%, but you have remaining 70% of the ink, it does not recognize it anymore. The chip on the ink cartridge is already registered as an empty cartridge.
May 28, 2011 | Epson Stylus NX400 InkJet Printer
Both lights are blinking on printer Epson stylus r230
I suggest you run this tool to fix that problem
It will allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
http://www.ssclg.com/download/sscserve.exe.
Jan 11, 2011 | Epson Office Equipment & Supplies
How to reset or repair epson T13 by manual the epson T13 printer dican not print anymore, what should we do?
try the procedure in this link
http://pcmediks.blogspot.com/2010/09/epson-t13-and-me32-resetter.html
Jan 06, 2011 | Epson Office Equipment & Supplies
How can i reset ink pad in epson T13
here is the instruction and free resetter for your printer
Dec 18, 2010 | Epson Stylus Photo R300 InkJet Printer
Reset epson T13
visit this link on how to reset epson t13 printer
Nov 03, 2010 | Epson Office Equipment & Supplies
My epson R260 says Service Required how can I fix this?
Many of the Epson printers ink cartridges have a sensor that allow the printer and the associated software know when to replace the printer ink cartridges (even when the cartridges have ink within them) and/or when the printer needs to be cleaned. In some cases you can bypass this message by following either of the below steps.
Use printer buttons to reset
Use the printer buttons to reset the printer by pressing and holding the "Stop", "Maintenance", and "Power" buttons all at the same time.
Sep 25, 2010 | Epson Stylus Photo R260 InkJet Printer
402 people viewed this question
k24674
