Question about Pioneer SD-P55A3-K 55" Rear Projection Television
No picture on my pioneer TV model SD-582hd5
I have sound but no picture on my TV. I do have picture on all input items. So I think a setting has been changed that i cant find.
  • Deneen Lewis
    Deneen Lewis Feb 23, 2012
    is this a new install?could there have been a power surge in the home?
  • John G Feb 23, 2012
    no, i think it is in a remote setting
    Sergeant:
  • 195 Answers
The problem is on lamp try to replace it to get back the picture..
Posted on Feb 23, 2012
ladywinn
  • 5138 Answers
SOURCE: pioneer projection tv model sd-p404
In menu go to cable/then press auto programming see if this fixes your set.
Posted on Jan 31, 2008
likha
  • 790 Answers
SOURCE: 2 fuses blow on power up
HI
Good day sir! if you have knowledge in electronic trouble shooting, ican give an instructions to fixed this trouble!
But if you have no experience in electronic trouble shooting much better to call a qualified technician in this site near you! just type www.fixya.com then go to find repairman.
Posted on Nov 15, 2007
SOURCE: Pioneer 58" SD-582HD5 1080i -Rear Proj TV
Like most problems with this model, check and re-solder the connections on the power supply board on the right rear of the tv, just behind where the main power cord goes in. Most problems are around the upper left corner where the white connectors E-12 and others. Check all of them from loose and cold solder solder connections on the board. Hope this helps.
Posted on Jun 28, 2008
  • 136 Answers
SOURCE: Power problem (switches to standby)
its the problem of the ics on the main power supply board
Do the IC heat sinks get warm??
If they do not, check fuses F852 - 2AMP, F853 - 1.25AMP, F850 & F851 - ALL 5AMP on the power deflection pcb. THESE ARE NOT GLASS FUSES. They are usually about the size of a 1 watt resistor and either green or orange in color. They are soldered in. The nomenclature is printed on the component side of the board. They are all about centered on the opposite edge of the PCB as the high voltage transformer.
If you have cleaned up the mess you describe you most likely have one of these fuses blown.
if dont have any technical knowledge its advisable to call a technician as it is worth getting it fixed.
thanks.
Posted on Oct 12, 2008
SOURCE: pioneer sd-582hd5 shuts off while watching
Had the same thing happen, cleaned everything in the back out as it was real dusty, have had no problem since
Posted on Sep 10, 2009
THE TV STAYS OFF
If the sound keeps working your probably just need a new lamp, if the sound does not stay on, you probably to get someone to fix the power supply.
Sep 02, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-582HD5 Picture looks 3D with red and blue copies of images seperated on the screen..
Replace BOTH of your convergence ICs they are big black ICs will have part number on them if 110s use 180s.
Feb 18, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-582HD5 - screen went black, no sound, Poor remote feed
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
Dec 20, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Jun 02, 2008 | Pioneer SD-582HD5 58" Rear Projection...
My sd-582hd5 picture goes black
May 08, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Component video issue
You have a component not up to specs in your input 2 circuitry possibly a capacior. You would need a service manual to locate which item that isnt up to its rating. you can purchase the service manual for your set for 12.99 at the following link. They will emal it if you send them an email requesting it.
http://servicemanuals.vstore.ca/
Jan 04, 2008 | Pioneer SD-582HD5 58" Rear Projection...
How to open pioneer sd-582hd5
from back good luck most problems are cold solder connections and i some models you have to replace three small caps in the video circuit
Oct 31, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-P55A3-K 55" Rear Projection Television Logo
135 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
