Question about Goodman Heating & Cooling
Goodman PGB030050-1b fun run non-stop even with themastst off
  • Steve Hack Feb 23, 2012
    typo ment to pu fan runs non-stop
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
Radiator fun running non stop
sounds like the fan motor relay switch its attached to the fan housing unit, or your thermostat is stuck open. refer to you car bible for instructions on how to test your termostat to see if it functioning properly. Hope this was helpful.
Mar 20, 2013 | 1998 Toyota Corolla
Radiator fan running nonstop
Hi Bro, Have you check one single wire to switch temperature, if this unplugged the fan will run nonstop, even without your engine start and your key is in "ON" position, it's exactly what happen to my 1994 corolla
Mar 20, 2013 | 1990 Toyota Corolla
Goodman ck30-1l, outside fan trun on doesn't speed up and stops, what is wrong any ideas?
Your most likely issue is a bad run capacitor. It a small silver can that is usually located in the controls area of your condenser. If the fan has been replaced it could be mounted somewhere around the fan. It helps motors run and when they fail they will run half speed,
Jul 08, 2012 | Goodman CKL49AR49 Air Conditioner
Need location of the themastst on 06 sedona
Follow the upper hose on the radiator to the engine (it's the big black one). Where the hose stops, there will be a hose clamp that holds the hose to the thermostat housing. Remove that housing and the thermostat is right there.
Feb 25, 2010 | 2006 Kia Sedona
I cannot tune my goodmans gtvl19w17hd tv
If you have sound, then your tv doesn't need tuning. Shine a bright light onto the screen, can you see a very dim picture? If so, your backlight has stopped working. This is almost always due to the inverters failing and can be repaired.
Jan 26, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
Goodman heater blower runs on own won't stop after flame shuts of
bad blower relay or timer. replace board.
shorted thermostat wires. check.
Feb 19, 2009 | Goodman GMS90703BXA Heater
Laptop fan running non stop
you need to go into the bios and disable the always on setting for the fan
Dec 16, 2008 | Computers & Internet
Led keep on flashing
What is the model #. Sounds like your polarity is reversed. Do you know how to check for this.
Nov 13, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
