Question about Hitachi Televison & Video
HITACHI PROJECTION TV HAS WAVEY LINES ON IT THEN SCREAN GOES BLACK
IF I UNPLUG TV FOR A LITTLE WHILE IT COMES BACK ON AND AFTER SHORT PERIOD WAVEY LINES COME BACK AND EVENTUALLY SCREAN GOES BLACK AGAIN
    Sergeant:
  • 195 Answers
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
HITACHI PROJECTION TV HAS WAVEY LINES ON IT THEN S - power%281%29.jpg2_23_2012_11_31_16_am.png
After replacing blown capacHITACHI PROJECTION TV HAS WAVEY LINES ON IT THEN S - caps%281%29%281%29.jpg again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Posted on Feb 23, 2012
5 Suggested Answers
  • 1153 Answers
SOURCE: hitachi projection tv picture just wnt out
Give me the model number!
Posted on Dec 25, 2007
NJ Logan
  • 31 Answers
SOURCE: horizontal wavey lines in projection TV picture
what brand? could be a ground problem or bad crt
Posted on Aug 27, 2009
SD Tech
  • 14553 Answers
SOURCE: 2002 projection Hitachi TV color problem
This model uses two of the STK-392-110 CHIPS for convergence---two versions of this set---one has as you look from the back of the set a circuit board on the far right that has the chips and other parts.
I am going to attach 3 photos of this board--the first two show the board from either side and the third one shows the protection resistors--if you look close at that picture you will see two resistors burnt in the middle.
The other version of this set does not have a removable board like the one in the picture--entire chassis has to come up and replacement is done that way.
If you have the first one like in the photos--3 screws and a number of plugs and it comes right out--three of the plugs for that board are identical and you need to mark them carefully if you remove the board.
The two chips on the far right side (photo attached) can be purchased on EBAY for about 12 dollars--total parts cost if you can solder should be under 30 dollars.
I can tell you the seller there and if you decide to do it you can upgrade the parts by using stk-392-150 chips---same part but longer lasting.
If you want to do it let me know and I will give you a list of what you need---if you have the removable board it is a pretty easy set to fix.
SEE ATTACHED PHOTOS and if you have questions let me know.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 26, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Phillips 60" projection screen tv. Wavey lines at
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 15, 2010
TV periodically goes black and the lamp and temp lights start flashing then it comes back on after about a minute.
call sears they only charge $99 to come out and free estimates. mine cost $300 to fix works great
Dec 19, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 52" projection tv went black. when i
if this is a DLP it seems your lamp burned out and needs replaced , if so search ebay with model # for replacement, you can purchase a buld or lamp assembly
Nov 28, 2010 | Hitachi Televison & Video
Hitachi 50ux19k model that will power on and powers right off.
Replace Both of your STK ICs that will fix this they are big black ICs will have part number on them STK392-110 use 180s Mats Electronics has them 1-800-628-1118
Mar 22, 2010 | Hitachi 50UX57B 50" Rear Projection...
Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Jul 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Have Westinghouse 32"LCD TV. When its very hot and humid after being on for approximately 30 minutes black, heavy vertical wavey lines appear on the screen. Sometimers I can make the lines disappear...
I had the same problem these LCD TV's are designed poorly and have very little ventilation my warranty was up so i took it apart and installed cooling fan have no problems what so ever now.
Jul 17, 2008 | Televison & Video
Hitachi 60ux58b projection tv
If there is no power indicator, you could have gotten lucky and only the main fuse insiude the set blew. You can unplug the TV set, take off the back of the TV. Then where the line cord comes out of the TV set and plugs into the wall, look where the line cord enters the set and look for a glass type cylinder fuse. If it is black, most likely there is a short inside the TV set. If it is not black, try replacing the fuse with ONLY the type that is stamped on the side of the fuse. If the set still does not work, or if the fuse blows again, you will need to have the set serviced by a pro. Good Luck
Aug 18, 2007 | Hitachi 55FX48B 55" Rear Projection...
Open Questions:
Televison & Video Logo
55 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
