Question about SNK Magnavox 32MF338B27 32 in. LCD TV
No power fuse blew
No power changed fuse on power panel pluged in and the fuse blew agian
    Sergeant:
  • 195 Answers
It means you have shorted regulator transistor on power supply..
It is usually fit in heat sink..
Try to replace it and the fuse again also check any fusible resistor near that transistor..
Posted on Feb 23, 2012
I pluged in a small car vac in the power outlet , after ten minutes it blew. Owners manual dosen't say there is a fuse for it.
There should be a cig lighter-accessory relay in the box near the battery. It is powered by a 9amp fuse and a 20amp fuse. The 20amp fuse is in the same box with the relay.
These fuses and relay power the front and rear outlets.
Dec 21, 2012 | 1999 Dodge Caravan
Not powering up
It could be the fuse in your power plug box. My fuse blew in mine when I went to Switzerland I just bought a cheap one on ebay for around 9 bucks at the time that'll work over seas as well. If you have a friend with a wii try their power cord on yours.
Oct 31, 2012 | Nintendo Wii Console
My kenwood reciever kr-a4070 keeps blowing a fuse
have you tried a different outlet? something my be wrong internally
Jul 31, 2012 | Kenwood Audio Players & Recorders
Dri have 26 inch flat screen tv and what the problem is that it will just shut off and it will take a day or to power up even the red ligt to let u no that its pluged in dosent even light up but leaving it...
its easy fix if you can use a soldering iron.....
needs new caops on the power supply board.........
if you cant use s/i ...
obtain replacement p/s/b from ebay..........
cheers
Apr 11, 2011 | Element Electronics Televison & Video
Toshiba 62hm94 pluged in but getting no power at all. No green or red light on.
Hi:
CHeck for open line fuse you may of had a surge that blew the fuse especially when there is no power indication at all. IF no fuses are blown on the power supply then suspect a faulty power supply circuit.
Aug 24, 2010 | Toshiba TheaterWide 62HM94 62" Rear...
Polaroid flm2011 hit by lighting won't turn on
I was wondering if you figured out what was wrong with your tv. I have the same problem.
Sep 10, 2009 | Polaroid FLM-3732 Television
My honda worked until i had my two fridges pluged in then i turned a light on it blew the light now it worked power anything it runs good but like i said it wont give power to anything would there be a...
yes there should be. there should be a circuit breaker, try to reset that. then find the circuit protectors and check those. without model# I dont know locations but probably around the control panel.
Jul 30, 2009 | Electrical Supplies
Engine cut off and cant start
If the fuse blew at once, then you have an electrical short. Try disconnecting power lead to start, cover with insulating tape/electrical tape, put new fuse in place, and attempt to "start". if fuse does not blow then the starter motor has an internal fault, replace starter and enjoy. Keep me posted as you perform these tests.
Dec 19, 2008 | 1998 Toyota Celica
Ilp iwt3206 32" sdtv
Next best guess is the larger filter capacitors in the power supply are bad and shorted out, you can check with an ohm meter across capacitor leads (with power unplugged)
Apr 21, 2008 | iLO 3200 32 in. LCD Television
It blowing main fuse
that set will need some trouble shooting you have a short in the power supply. Could be alot of different things.
Apr 05, 2008 | RCA D52W19 52" Rear Projection Television
SNK Magnavox 32MF338B27 32 in. LCD TV Logo
135 people viewed this question
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
