Question about HP vp6320 Multimedia Projector
My projector won't come on.
My project has two little lights that blink.. One looks like a heat and one a bulb light. I purchased a new bulb, replaced it, and it still does the same thing. The power comes on, the big blue power button is lit up, but the light never shines. The store I purchased it from, no longer sells them. What else could be the problem?
  • HP Expert Dec 01, 2008
    Instead of trying to get paid can you tell us how to fix it and what parts we need?
    Problem Solver:
  • 18 Answers
I answered this question many times. This is caused by a failed color wheel sensor. It faile gradually, first the lamp flickers, sometimes go dim for no good reason. Finally the lamp will not strike and you will get two red warning lights. I am factory trained and I stock the redesigned senor.
Posted on Nov 30, 2008
Status light blinks seven times
the lamp timer is failing
lamp timer chip is on the lamp housing,is a little chip
you need to reset the timer chip by using a Programmer
select a date of 0 hour..
Our company supply this chip with 0 hours USD15
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 31, 2014 | NEC MultiSync MT1065 Multimedia Projector
WHEN POWER ON PROJECTOR DOES NOT ON WORK
Do you get lights? are they blinking? The number of blinks will tell you what is wrong if you go to the manufactures site and pull up the manual. (It may be a combination of lights instead of blinking lights)
Check for:
Bad bulb-check to see if the little wire inside is whole, just like in a lightbulb, look for cracks near the base, or any other sign of breakage.
bulb- inserted improperly?
All panels and doors must be on, and the screws in, for most projectors to do anything..
Check the cord, you should get at least one light if the cord is good.
Jul 05, 2010 | NEC LT 260 Multimedia Projector
NEC VT595 Projector - Status light blinks red constantly
We had this same problem. In our case it turned out that a little bit of plastic broke off of a tab on the inside of the plastic lamp cover. Without that piece it was not pressing against the sensor that tells the projector that the lamp cover is closed. Without that, it doesn't start. We got it working again by drilling a little hole and sticking a screw through that spot to replace the missing plastic, but I'd rather replace the cover if I could. Really dumb that a little piece of plastic can mess up thousands of dollars worth of equipment (Smartboard 2000i).
May 26, 2010 | NEC VT595 LCD Projector
Have a KDF 60Wf 655 will not turn on. Green light comes on then red light with 7 blinks any suggestions? Took bulb out but the bulb light never lit and the bulb doesn't look blown.
Wether it looks blown or not replace it and dont put oil from your fingers on the bulb. Also clean the cooling fans for the bulb and projector (which may mean taking the back off and taking apart projector). Dirt in the projector fans can cause a fault not allowing for the unit to turn on. All the cooling work ins conjunction with a good bulb.
Apr 24, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Light bulb not working after colorwheel replaced
Same thing happened to me (By jschmidbauer on Jan 14, 2010). How did you fix it????
Jan 14, 2010 | Samsung - Projection TV replacement lamp...
No light projects.
Try resetting the projector by pressing and hold the two Keystone buttons, then turn ON projector. Hold down the two Keystone buttons for 15 seconds, then turn OFF projector.
Turn ON projector, the new lamp should strike.
Mar 11, 2009 | InFocus ScreenPlay 4805 Multimedia...
Blinking Temp and bulb light on HP VP6310
The color wheel sensor is dead. This is a common problem.
Jan 30, 2009 | HP VP6310 Multimedia Projector
4805 w/less than 300-400 hours has blinking red light
Yikes. I bet the bearing is bad in the fan and/or the fan is rubbing up against something. It might be an fix.
Jul 16, 2008 | InFocus ScreenPlay 4805 Multimedia...
Bulb failures
I experienced the same thing, only to discover it was the ballast that powers the lamp. I believe INFOCUS repairs for $390.00 per the technician that I spoke with on the phone at INFOCUS.
Jun 29, 2008 | InFocus IN72 Multimedia Projector
HP vp6320 Multimedia Projector Logo
315 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
