Question about Electric Demolition Jackhammer
Baumer ag jack hammer
Can not remove the internal gears
  • dawilson249
    dawilson249 Feb 25, 2012
    The gears concerned are listed as counter gear and final gear, I have tried using a gear puller but they seem very tight.
  • Electric Master
  • 1,806 Answers
This is what kind of tools you are missing for to do it without damage some parts by some brands a bearing press .. to press out the gears out of the bearings but beware in some cases there can be uses a forelock and the bearing of the gear can sitting behind a locking ring. allways use the right service manual before decide to. and use safety glasses if using a bearing press
Posted on Apr 17, 2016
I'm looking for a replacement carby for a 72cc Baumer ag chainsaw, I've replaced the coil, filters etc, still no joy, stops after a while. Thanks merv
itm will be available from e-bay site
chainsaw and other small engines use just a few manufacturers of carbies so you will find one listed for your machine
Jun 19, 2017 | Garden
Baumr ag User Manual Needed
http://baumr-ag.com.au/where-buy-baumr-ag
  • There should if available for your model type a maintenance kit neccesary for your model or all the used o-rings and sometimes special tools because there are special buna-n or nbr o-rings used sometimes braun or green colored on some parts and gaskets, seals and rings used and allways if your tool is leaking then replace the impact bold in front of the spindle if you have find the right drawing for your model type
  • The right lubrication is very important in combination of the o-rings because of the heat building release by rotating and hammering and a leaking tool has oft made all o-rings hardenet because of the failed pneumatic working loose of lubrication dried out principal it becomes very dry internal on some places and much to hot .
Sep 05, 2014 | Drills
Hr 3000
Frequently the problem for this is a plastic ring that has three pins in it. Normally the pins break through the bottom of the ring.
You need to take covers off. Strip SDS chuck. Remove plastic cap from end of drill then remove large internal retaining ring. Tap end of drill with mallet and eventually the tool holder will come out.
At the bottom of the tool holder there is a thin O ring (all this does is keeps a plastic gear and springs on the tool holder.) Remove this ring gear and springs can now be removed. You should now see the plastic ring (approx. 30mm long) Examine ring and pins, probably need to replace ring. This is usually the cause of not hammering, I have found changing seals works for weak hammering. Although having stripped the drill to this point I normally change the O rings on the hammer and piston. Rebuild is reverse of stripping be careful with the thin O ring not to snap it.
Mar 15, 2014 | Makita Drills
Baumer AG Power Head for 4 in 1 combo wont start. Has fuel, spark etc.
Does fuel get to the carburettor?
Does the cylinder have compression?
Oct 13, 2013 | Garden
Where do i find pull start parts for the baumr-ag 62
Email agrmachinery@gmail.com This is the main seller of Baumer-AG machinery on ebay .. I know that he has a fair assortment of parts as I had to change my startr when it fell to bits.
Regards, Bob.
Aug 09, 2010 | Garden
How do I drain the gear oil from a Bosch Brute Jack Hammer
Brute hammer uses special grease sold as service kit. This kit contains enough grease to lube hammer and replacement bolts that hold springs along the bottom. Check www.toolpartsdirect.com for parts and kit. Remove the lower half (tube) of hammer, also remove three bolts that hold springs and remove assembly from tube. Wash out old grease. Grease will be oil-like only when hammer is very hot, otherwise grease is paste-like. Good luck.
Jun 22, 2010 | Bosch Brute Breaker Hammer 11304
Reparation for subwoofer jack out
there a internal jack, you can open case, and try put back, but you can replace for a new one. You find-it on Electronics Components Shop.
Jan 17, 2010 | Teac AG-10D Receiver
No hammer
i have 900 kango jack hammer motor work but don't jack in sacramento any repair dose work on the jack hammer can you give info who work in sac thanks jim
Jul 01, 2009 | Dewalt D25330K 2KG Sds Plus Demolition...
Front wheel excel
Get out the axle cotter pin on the axle nut. Loosen the Axle nut while the car is on ground. Loosen wheel nuts. Jack up car and place jack stands underneath. Go underneath car and turn the wheel till you can see the pin through the inner part of the axle, which connects to gear box. you have to take out that pin carefully. hammer pin out from unchamfered side.
Take off wheel remove the axle nut the plain washer and the conical washer.
Now if you don't want to remove the ball joint remove the bolt from the suspension arm, to locate it look at the arm to which the ball joint is connected and trace it to its pivot point.
Pull the complete hub axle assembly in a straight direction, which would remove the inner joint from the gear box. Take a rubber mallet and carefully hammer the axle out from the hub. Please remember that when axle is removed the hub and disc may fall off so be careful.
Please use new axle nut, plain washer, conical washer and cotter pin during reinstall
Aug 07, 2008 | 1992 Subaru Justy
Electric Demolition Jackhammer Logo
352 people viewed this question
Top Electric Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Dan Webster
Dan Webster
Are you an Electric Hammering Expert? Answer questions, earn points and help others
