Question about Lakewood Oil-Filled Electric Radiator Heater
The heater shorted out, sparks, electrical smoke. Is it salvagable or should I replace?
We've had this heater for 18 years. I assume it died of old age. We use it almost every day in the winter months to heat a small room for exercise. It is used about 4 hours per day. We run it on high with full power. It was working fine just this morning. Then in the afternoon once it was totally hot it just sparked and smoked....
  • Lakewood Master
  • 2,515 Answers
Yes you could say it has died 18 years has been very good time to look for new . I don't think you will get parts for it now .
Posted on Feb 23, 2012
Testimonial: "thanks for your advice. It's good to know the life span of this heater and that we got our money's worth for sure. will buy a new one...........much appreciated....todd"
Hi, I have a nice master B150D that ran flawlessly last season,brought it out this year replaced nozzle,spark plug,new fuel. Fired it up ran for 30 sec. pop's the circuit breaker,reset,runs 20 sec....
if a circuit breaker pops i assume its an RCELD or is it a MCB type
it is some leakage to earth somewhere in the electrics
if it runs and pops the breaker
and you can plug it in and it will sit there
then i assume its something do do with the fan system
or ignitor . driver system
look for sources of leakage to earth
and you could measure the peek current it uses with a multimeter inline
set to AC amps
anyway its defo not a gonner just some bad electrics
Dec 09, 2014 | Heating & Cooling
GS550 Electrical Problems.
try carefully shorting a screw driver accross solenoid the two big nuts with ignition on . try a meter on continuity starter casing to earth
Jul 18, 2013 | 1980 Suzuki Gs 550 L
Coleman heater 3500a820 lots of smoke and now only blower works no heat
I am not sure about the heater type, but likely the heater element controller shorted out or the heater elements shorted - hence the black around where the wires go into the electric box. If you're lucky, the wires shorted to the side of the box. With the power off, open up the electrical box, mark which wires go where, remove them from the board, remove the wires from the electric box, then using electrical tape, tape up the exposed ends of the wires. Spread them out so they do not touch each other. Turn on the 60 amp breaker - if it trips, then your wires are bad and need replaced. If it does not trip, then the problem is with the heater. Do not let anyone near the wires when testing them! Don't forget to turn off the breaker if it does not trip. Again, turn off the breaker if it did not trip.
Oct 18, 2012 | Coleman Heating & Cooling
95 Park Avenue Ultra dies for no reason I can find, I've replaced the crank sensor, cam ssensor, spark module, fuel filter, I've had the injectors tested, fuel pump tested, plugs & wires t
As you have probably figured out by now, you will have to treat it as a no start and troubleshoot it when it fails to start. Until you figure out if you are loosing spark or fuel to the injectors when the engine dies you have no direction to go in.
Aug 20, 2012 | Buick Cars & Trucks
The charger that comes with Homelite 24v mower is crappy. I've gone thru 3 of them. What's a better alternative?
I have used a DieHard portable battery charger (model 200.71222) for several years to recharge my 24-volt, 18-year old Craftsman mulcher, model 315.370270. This is after the on-board charger died. I just disconnect the link between the two 12-volt batteries and remove all other battery connections. Then connect the charger leads to the positive and negative terminals on one of the batteries before plugging in the charger. I put the settings on the charger at conventional low maintenance and 2 amps. Charge one battery and then the other (assuming you have two 12-volt sealed lead acid batteries like my mower). I use binder clips 530-t.jpgfrom an office supply store to hold the battery wires on the terminals when I'm mowing...makes it simpler to remove and reattach for charging instead of the nut-and-bolt connectors that came with the mower.
May 14, 2012 | Garden
Lakewood Oil-Filled Electric Radiator Heater Logo
255 people viewed this question
Top Lakewood Heating & Cooling Experts
Mack Baxter
paulcarew
jdthefixer
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
