Question about NetGear FS516 16x10/100 Mbps Networking Switch
Netgear fs516 fan
Noisy fans
How to fix a noisy evaporator fan in a frost free refrigerator
The ice usually makes a fan noisy by filling the cavity it needs to move the blades in. check if this is the case, if there is no obstruction and the fan motor itself is noisy it needs to be replaced or serviced, servicing parts is trickier to find than the little motor it self.
To clear the ice just let the fridge stand for a few hours and to help the process speed up you can spray the evaporator with luke warm water.
Feb 26, 2015 | Frigidaire Refrigerators
Netgear fs516 default ip address
switches do not normally have ip addresses as they are layer 2 network devices. They work on the MAC address of each network card attached to it to direct the network packets of data to the correct Network card.
Cisco Switches have an IP address but it is a virtual ip address used to remotely log into a Cisco Switch via IP but has nothing to do with the switching function however this is not a cisco switch.
Routers have IP addresses and use them to switch IP addressed packets to other Networks that have Routers connected to Switches.
Jun 30, 2014 | NetGear FS516 Networking Switch
Noisy fan on n6010 life book
fujtsu lifebook's tend to have a noisy fan
Dec 20, 2011 | Fujitsu LifeBook N6010 Notebook
How do I fix a noisy fan for a 2008 Altima.
You will probably have to replace a noisy fan. Trying to fix a noisy fan will can tricky.
Jan 26, 2011 | Nissan Altima Cars & Trucks
Creda Cordialle fan assisted oven is so noisy what can I do?
If it is the fan that is noisy, check for loose fan or the fan blades catching the cover, if all o/k, then it will probably be a worn fan bearing, only solution would be to replace the fan motor.
Nov 07, 2010 | Hotpoint Ovens
How to connect netgear fs108 to cable modem
leeb..... switches cannot be connected to the Cable modem.... because NAT will not be enabled in cable modem....so there wont be any DHCP server present in the cable modem....
Nat will be enabled only in DSL modem like AT&T verizon etc....So DHCP server will be present inside DSL modem...that is the reason why switches can be connected only to the DSL modem....
With NAT enabled modem, switch will work as a switch.... With NAT disabled modem, switch will work as a hub.... This is the difference....
Any doubts further ? please clarify with me.... I am ready to help you....
May 09, 2010 | NetGear FS108 8-Port Ethernet Switch
Noisy evaporator fan
A noisy fan is caused by several things. The fan can have the blade touching something behind the shroud (the back wall in front of the fan). It could be the bearings on the fan are no good - try oiling with Triflow oil. The fan blade could be out of balance. Try cleaning any dirt or grime off the blade. Fans are cheap (relatively). Tried a new one?
Some fans are just noisy. Try thin rubber between the fan and the screws that mount it (bicycle tire patches work good for this).
Mar 28, 2010 | Kenmore Refrigerators
No power light on FS516. Fuse Ok. No obvious signs of any internal burn-outs
Hi replace the power adapter and check if it helps. If the issue persists and the unit is under warranty then please log a complaint with netgear using the below address my.netgear.com
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 12, 2009 | NetGear Computers & Internet
I HAVE 2 NETGEAR FS516 SWITCHES. BOTH NEED A NEW POWER SUPPLY.
Replace capacitor C3 47uf@25V. It will fix that ADP20KP 90% of the time.
Mar 05, 2009 | NetGear FS516 Networking Switch
NetGear FS516 16x10/100 Mbps Networking Switch Logo
77 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
