Question about Kenmore 24032\24036 Top Load Washer
Kenmore washing machine
My washer machine will wash the clothes, but does not empty or will it rinse or spin.
  • 172 Answers
Hi heatherrosco,
If your washing machine will wash but not pump out or spin then you have a bad lid switch. The lid switch can be checked by poking a ink pen down into the hole on the top of the tub while the machine is turned on and in the spin setting. If you poke the switch and it does not spin or pump out the water the switch is bad. If the machine will not wash or spin and will only fill and pump out then you have a bad motor to trasmission coupling. These can be purchased at any appliance repair center for about $15.00 The coupling will go between the motor and the transmission and act as a shock absorber. It is a fairly simple repair for either part, please let me know what you find and I will be happy to tell you how to complete the repair. If you need the parts I can also ship it straight to your door and give you advise over the phone while you install. Good luck on your repair and remember I am here to help. Please dont forget to rate me also.
Mike Anderson ( Owner )
Anderson Appliance Repair
(865)945-3808
Posted on Oct 28, 2008
My clothes are coming out dirty. dirt is settling on my clothes from the rinse.
Put a cup of vinegar in an empty washing machine fill with water and wash without clothing in it. Should sort the grime caused by fabric softner.
Feb 04, 2016 | Kenmore 24032\24036 Top Load Washer
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Have a Kenmore 20902 top loading washer. Does aggitate in wash cycle, but wont spin in rinse. With drum empty, it will spin. Removed cloths, rung dry by hand and returned to drum. Still would not spin, but...
Your drum is in a sense sitting on a barring , it sounds like your barring is going out. Works with no weight, and if helping as you said. Normally means barring is worn out and can not handle any weight.
May 08, 2011 | Kenmore 22422 Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Kenmore Washing Machine doesn't rinse
The drain line is probably clogged. Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. Check as well that pump spins and clean from any clogged. Good luck!
Oct 08, 2006 | Kenmore 43042 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
52 people viewed this question
Sal De
fordexpert
Robert Rankin
