Question about Coffee Makers & Espresso Machines
Delonghi ESAM 3500 Milk Container
My milk container for my Delonghi espresso maker is not properly connecting, when inserted and as a result causes a very low milk flow when steaming. I have to forcefully hold the container pushing inwards in order for it to get a good flow. I am not sure if anyone else has this problem.
4 Suggested Answers
SOURCE: Milk container doesn't heat milk..only the steam is released.
I was told this was a problem with the O rings on the machine (you need to keep these clean or replace them (if necessary) to keep the milk container working properly).
I did this and still had the same problem. Turns out the top on the milk container needed to be replaced. It's $20 from Delonghi but at the time of this writing is out of stock (I have waited three seeks so far and Delonghi is supposed to be escalating my request).
I finally got frustrated with the whole thing and completely disassembled the milk container top (there are a total of 5 screws and you need to remove the froth control slider to get to one of them) and gave everything a good cleaning. Pay attention to the small orifice on the inside of the chrome tube that the milk comes out of. Using a dental gum cleaning brush or similar sized brush and some hot soapy water should get the dried milk residue out. Inside the top is also a rubber piece that the froth regulator inserts into. Reomve this rubber piece and clean thoroughly. Make sure and clean all other areas inside the top with hot soapy water. Make sure to look the top over well as you disassemble to be sure note all component positions for reassembly. Make sure when reassembling that the cleaning button and its spring are reassembled correctly. The small red O ring on the end of the cleaning button's rod should be cleaned well and the small tube into which it inserts should be free of any milk residue. One last item to check is the rubber bushing that rubber milk uptake tube inserts into is clean and making a good seal. Note that this bushing should make a good seal on both sides (the side the rubber uptake insrts into and the side the upper side of the top inserts into. Make sure all parts are reassembled correctly. In general if you clean and rejuvinate all areas that need to make a tight seal you should get good results. I have no experience here but it would be my observation that even with a good thorough cleaning job the results may not last a real long time as it seems that parts in the top show wear after about a year and a half of daily use. In my oppinion the purchase of a new $20 top makes sense, but if you can get one or don't want to wait you can spend the 30 minutes to do the above cleaning. Because of apparent backorder issues at Delonghi this may also be a good idea to buy upfront. Make sure to include the 5 O rings in the order ($1 each) to avoid paying two shipping fees. I have found one of the O rings at Lowe but was unable to find a few of the sizes (smaller than Lowes sells).
Posted on Aug 30, 2009
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Posted on Jan 10, 2010
SOURCE: I have a DeLonghi Prima
Maybe youare not pushing the milk-container sufficiently in. Mine has been increasinglyhard to fit. After speaking with DeLonghi service, they suggested lubricatingthe o-rings on the nozzles on the machine. I asked if cooking oil would be ok,to which they agreed. To I took a cottonstick and dipped it in ordinary cookingoil, and swept it over the inside of the two nozzles on the milk-container,since the o-rings on the machine itself were hard to get to. Now it workssmoothly. I was reluctant to try that out before speaking with DeLonghiservice, since they are so set on only using original stuff for the machine,and I did not think a machine this expensive would need this type of 'help'. Useat your own risk :-)
Flemming.
Posted on Jan 18, 2011
Delonghi esam 5600 will not froth milk
Here is the manual:
http://www.delonghi.com/Global/InstructionManuals/EN/ESAM5600%20Intro%20EN.pdf
Two causes from the troubleshooting section:
The froth regulator is incorrectly adjusted. • Adjust following the instructions in the section on preparing drinks with milk.
The milk container lid is dirty. • Clean the milkcontainer lidasdescribedin the section "Cleaning the milk container".
Feb 19, 2015 | DeLonghi Coffee Makers & Espresso Machines
How can i attach the milk container
Add a little Petrol-Gel Food Grade Sanitary Lubricant to the two O-Rings on the machine were the milk container connects. If you do not have that available, wet your fingers with water and rub on O-Rings prior to inserting milk container. O-Rings dry out and go bad, they need lubricant. You can get Petrol-Gel at a restaurant wholesaler or Amazon.
O-O
Jun 25, 2014 | DeLonghi ESAM5500
Magnifica ESAM 3500 milk temperature low
This is factory preset and cannot be altered. You do need to use the "clean" function on the milk frother unit to ensure the boiler and pipes heat up enough also.
May 15, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
Changing the Magnifica ESAM 3500 milk temperature
This is preset and cannot be altered.. Do ensure you preheat the milk frother before use.. by activating the "clean" button on the frother jug
May 15, 2014 | DeLonghi ESAM3500 Espresso Machine &...
I have a DeLonghi Prima Donna coffee machine which is 6 months old. When I plug the milk container nozzle into the machine it is not recognised by the machine. A message on the screen is saying...
Flemming.
Nov 09, 2010 | DeLonghi Prima Donna Avante ESAM6700...
DeLonghi EAM3500 ..milk wont come properley
We had a similar problem and it required a replacement coupling block. Part No-111 on the Delonghi part breakdown pdf
Jun 18, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Aug 08, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica 3500 not frothing
use cold low fat milk and keep the milk container in the frig.
Make certain that when washing water come out of both holes.
Jul 09, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
My delonghi magnifica is having a problem with milk..steam is coming through but no milk..can you suggest what the problem may be?
There are 'o' rings on the pipes (on machine - not milk container) where the milk container fits into. replace or clean them - should work like new.
Jun 21, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Milk container won't fit onto front of machine
We had the same problem & worked out that it's because the actual milk container is too cold & has contracted from being in a cold part of the fridge. We moved the milk container to the door of the fridge ( it's a little warmer than the rest of the fridge) & it slotted in perfectly the next morning!
May 02, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
48 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
