Question about Water Heaters
Changing boiler programmer
Wiring diagram required to change the thorn programmer in a myson apollo 40s boiler to a potterton myson EP 3002 programmer. A diagram for the thorn programmer would help.
  • 104 Answers
Take digital pictures - label all wires and reconnect - you do not need manual.
Posted on Oct 31, 2008
How do I fix a problem with my boiler not coming on?
Ive just resolved this issue on my own boiler...... Its the programmer ,replace it as the micro switch has gone , when it comes on the lights only come on the internal switch does not ,so no sognal to boiler , replace programmer
Aug 01, 2016 | Water Heaters
Lost manual for towerstat RF
try googling "towerstat rf"
Sep 21, 2014 | Water Heaters
Puma 80 potterton hot water on and off
Boiler compartment ventilation will not stop you getting hot water . Its sounds like you have problems with a sensor or the water section on the boiler .
Apr 20, 2017 | Water Heaters
New sime e comfort 25HE boiler problems
It not wired in right that why its coming on when it is off The boiler is over riding the programmer when it is off .
The boiler should call for heat if programme is on it sounds like boiler is wired into the 24hr mode or over ride mode that why it is coming on . google wiring for y plan heating system. this will help you fault find on this . changing vales and thermostats will not help you . Hope this helps .
Mar 05, 2017 | Water Heaters
My potterton boiler ignites itself after turning it on then goes out
Assuming this is a combi boiler and you mean that the main gas burner comes on then off:-
How long after - 5-20 secs check overheat thermostat Check the wires to it are firmly in place i.e. making a connection. If Ok? then you can short this out by joining the wires together - do with boiler OFF at mains electricity
Longer - say 1-2 mins check secondary heat exchanger for blockage - usually furred up inside & only solution is replacement
Dec 22, 2009 | Water Heaters
Potterton Profile 60e doesn't start first time
could be fan speed or air pressure switch-is case seal sealing properly also check grommets under boiler for blowing.
YOU CAN ONLY WORK ON BOILER IF YOU ARE GAS SAFE REGISTERED.
Apr 04, 2009 | Water Heaters
Alpha boiler - wireless programmer failing
it sounds like the problem may be in the boiler and not the controller itself. Do you kno which is are the two wores that are the r-w for the thermostat take and purt them together and see if the boiler stays on or shuts off like it does with the thermostat. If it does then replace the reciever. If it doesn't then you have another problem. Good Luck
Jan 05, 2009 | Water Heaters
Water Heaters Logo
499 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
