Question about Hitachi Televison & Video
I have a Hitachi tv, with dish satellite and recently it seems the picture is projecting too large and cutting off subtitled movies, tops of peoples heads, etc. How do I change the settings so this does not happen?
    Sergeant:
  • 195 Answers
Try to restore factory default setting on menu..
Posted on Feb 23, 2012
4 Suggested Answers
  • 4090 Answers
SOURCE: The picture is too large for the screen and cuts
change the reolution Consult the manual for thios or go to setting and choose display and select a different resolution until you find the right one you have not included a screen size or model here try anything higher than 800x600 or panavison
Posted on Aug 01, 2009
  • 94 Answers
SOURCE: Picture too large for screen
The aspect ratio is zoomed in. Change the aspect ratio and the picture will go back to normal.
Posted on May 28, 2010
SOURCE: screen cuts off top of heads
Check the menu settings for the picture. You may be expanding the image to fill the sides, in the process, cutting the top and bottom.
Posted on Jun 01, 2010
Expanded screen
If it only does it via the coax or cable fitting it may not be the set.
Does it do the same thing when playing a DVD etc?
If problem is on all inputs it is a deflection problem in the set which for whatever reason has over scanned the picture to tall---it suggests a problem in the Vertical deflection circuit of the set (top to bottom is vertical deflection).
SD TECH
May 02, 2010 | Hitachi 57F500 57" Rear Projection...
Picture on Olevia lcd is too large for screen.
If you are on a cable or dish box, check aspect setting from you box, TV needs to be 16-9 or full, set TV first then change setting on box.
Aug 09, 2009 | Olevia LT32HVM 32 in. LCD Television
HITACHI WAS HIT BY LIGHTING.LIGHTING CAME THROUGH
i have a 52" that has the same problem just wondering if u have found a solution yet ????????/
Mar 02, 2009 | Hitachi 51F510 51" Rear Projection...
Mitsubishi WS-55513 55 in. - Picture to latge for scheen
Change your Display Format (widescreen mode) . You're using ZOOM. Press FORMAT on the TV remote control to cycle through the available display formats.
Feb 09, 2009 | Mitsubishi WS-55513 55" Rear Projection...
My tv zooms in and changes the format.
This is normal - you are zooming in on the picture. Most people use the zoom feature to "stretch" a widescreen movie so it will fit the screen.
Dec 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sanyo 42" 1080p, picture doesn't fit on screen
this is normal and this feature is for wide screen programs! normal shows and games will lose part of the top of the screen sides and bottem because it zooms in on whats in the middle of screen! hope this helps
Dec 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture jumps
you might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Can't view entire screen
make sure that you tv is set to the "standard" format and then try changing the aspect ratio on the cable box.
Jan 26, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
