Question about Nikon D40 6.1MP Digital SLR Camera Digital Camera with 18-55mm f/3.5-5.6G ED II AF-S DX and 55-200mm f/4.5-5.6G ED ... Lens
NIKON D40 SQ BASE PLATE UNIT
My camera is 2 stops under exposing whenever I want to take a photo. I did a bit of search and seems like it's very common issue for this model. I got advised to buy SQ BASE PLATE UNIT . I was wondering if I buy this unit is there any easy suggestion to replace the part. Thanks very much..
    New Friend:
Aperture issue is related to SQ Base Unit and this part must be replaced. I found this vendor on ebay ;
http://www.ebay.co.uk/itm/NIKON-D40-D40x-D60-SQ-SEQUENCE-APERTURE-CONTROL-MOTOR-BASE-PLATE-UNIT-GENUINE-/330808880495?pt=Digital_Camera_Accessories&hash=item4d05beed6f#shId
Posted on Dec 17, 2012
5 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: my camera (Nikon D40) is doing a long click
F-stop or lens flash rate
Posted on Aug 07, 2009
  • 138 Answers
SOURCE: Nikon D40 stopped working
try using a different usb port. might be the pc just can't detect your cam.
Posted on Feb 07, 2009
skidzy
  • 65 Answers
SOURCE: Just bought a Nikon D40 Camera and sometimes when
Your pictures are most probably distorted because of camera shake.
If you invest in a Nikon lens with VR = vibration reduction or a Sigma hsm os = optical stabilization, this will allow you to shoot at slower speeds and will reduce camera shake.
The most obvious problem will be shooting in low light conditions without vr or os...this will give blurred images.You will need to up the iso and shutter speed with a wide aperture to achieve more stable images.
Bear in mind, when you raise the iso, you will get noiser images and the Nikon D40 does not handle noise very well - but can be eliminated with software.
Hope this helps.
Posted on Nov 05, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: flash witeout
Hi there, you mentioned continuous shooting right. Your mean Sequence mode? One click and 7- 12 continue image sequence wise? If its then the problem is, your camera battery is not good now. He is not able to give required power supply to you camera flash. When few snaps done after the he loss his battery power & flash power going under(-) & your camera motor going slow, that's why shutter not open and close proper time. And the final result is whiter & whiter images. Hope you understand, what i am saying. So change the battery & buy a new original battery.
Thanks & waiting for your feedback.
Posted on Feb 15, 2010
Testimonial: "thank you very much for the prompt reply.., i will try to change my battry later..."
Initialization Error on my nikon d40
This is usually caused by a failure of the motor in the SQ unit on the side of the mirror box. It raises and lowers the mirror, ***** the shutter, and operates the aperture mechanism.
Oct 11, 2012 | Nikon D40 Digital Camera with G-II 18-55mm...
Sca 346/2AF M don't recognized on Nikon D40 like TTL
Film Cameras were NIKON TTL Nikon Digital Cameras are I-TTL. These two systems are not compatible. Film cameras did the metering in real time. When enough light struck the film the flash was turned off. With I-TTL the flash fires a quick flash and the image is quickly analyzed and the flash fires again to take the photo. With digital it is delayed and it is NOT in real time. The camera only looks at a few pixels to make the analysis fast. I hope this helps
Sep 22, 2017 | Nikon Cameras
My nikon d40 has a problem, on the lcd it says shutter error
hi
even if camera says shutter error, most of case are defective sequence unit (SQ unit). however shutter problem or sq unit would be charged around $75 to 235 depend on what your local repair shop want to charge.
usuallly nikon would charge more on general problem. it is batter to bring to local repair shop like those type of problem.
Thanks and best regard!
May 23, 2011 | Nikon Cameras
Mirror is stuck open on a D40
Hello dear brockhoffman, your camera has damaged the motor sequence and the unit should be replaced (SQ base plate unit), for that should bring your camera to Nikon.
Regards
Mar 09, 2011 | Nikon Cameras
How to repair my Nikon D60 error"Press shutter release button again"?
Dear sir, your camera has a failure in the sequence (motor sequence does not work).
To repair you must change the SQ BASE PLATE UNIT.
Greetings
Mar 04, 2011 | Nikon D60 Digital Camera
My camera is showing this message: Error. Press shutter release button again. When I press it, nothing happens. Any ideas?
Hello, your camera have a bad sequence motor.You need to replace the SQ base plate unit. Contact Nikon service to solve.
Regards
Mar 02, 2011 | Nikon D60 Digital Camera
Nikon D40
That is the highlight warning, the part flashing is overposed. while viewing the photos, press the up button to scroll to another view setting.
Aug 01, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 6.1MP Digital SLR Camera Digital Camera with 18-55mm f/3.5-5.6G ED II AF-S DX and 55-200mm f/4.5-5.6G ED ... Lens Logo
259 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
