Question about Boating
Waterpump impeller 15 hp yamaha 2 stroke how hard to renew
It is not going to be hard at all. You will have to pull the lower unit which with a 15 horse motor will not be that hard, so you could probably do it by yourself. Mine is a 150 horse mercury and i normally have one other person help me.
Posted on Feb 27, 2012
5 Suggested Answers
  • 677 Answers
SOURCE: how tough is it to change water pump impeller on 15hp johnson
There is no special tricks.Unbolt the gearshift linkage that has access through the side of the leg.Usually a small plate.Unbolt the lower g/box.4 bolts I think.The box should then drop.If not,use a rubber hammer and be patient.Put the lower skeg of the g/box in a vice to make things easier.NOW.When you lift the housing of the w/pump take a note of which way the impellar pump lobes are curled.DON'T put the new impellar in the wrong way.It's probably worth putting in a new seal whilst it's apart.You spin the housing or imp. as you put it together.Use a small bit of grease for the initiall dry start-up.Put some very good grease on the top splines on the driveshaft.It goes straight into the crankshaft.If it corrodes,nothing comes apart.As you put the g/box back on,spin the prop so the splines go back in.There is no special alignment.Gearchange linkage and you go fishing.(take the prop off and regrease the splines on the shaft of it)Hope this helps
Posted on Jul 22, 2010
  • 97 Answers
SOURCE: what is the maximum rpm for 50 yamaha 2 stroke
max operating rpm 4500-5500 see www.broadwaterboating.com.au/outboards/335_Yamaha_50hp_Mid_Range_2-Stroke.php for complete specifications. Hope this helps
Posted on Aug 06, 2009
SOURCE: hard starting outboard
Remove the starter and have it tested at a marine dealer or autoparts store. If it is dragging and taking too much voltage it will not start.Dragging starter also will keep the engine from spinning the speed needed to start.
Posted on Nov 23, 2009
fishdoctorfi
  • 178 Answers
SOURCE: idleling only 2 of the 3 cyl. working if you open
I had one.....make sure the linkage is hooked correct. If it works when you do it by hand the linkage may not be working...??
Posted on Dec 19, 2009
Hard starting on Yamaha 130 2 stroke. Always starts easily with ether. Choke works well.
This can have some reasons:
1 clogged carburettors. Too less fuel means a hard start.
2 Worn spark plugs
3 Loss of compression... On a 2-stroke, measuring compression is not an exact science. Have throttle wide open. No spark plugs, check compression on all cylinders. They should be all within 1bar from eachother...
Aug 02, 2017 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
1982 55 yamaha outboard ,water not coming out the water pump hole in strenght
First thing to check: Disconnect the tiny hose between the check outlet and the engine. Disconnect it at the engine side.
With an airgun, blow in the check hole from outside to engine side.
With an airgun, blow out the engine connection.
Start the engine, check waterflow out of the engine connector. If water, reconnect the hose and check the water at the checkpoint.
If still no water at the engine connection: replace the impeller!
Mar 28, 2013 | Clymer Marine Maintenance and Repair...
I have a 2005 yz85 that is gettin water in the oil an leakin water out of the hole on bottom of waterpump what do I need to fix this problem?
water in oil generally means head gasket gone. cylinder pressure will leak into water system causing other gaskets to go, 2 stroke head gasket is not to hard a job
Feb 15, 2013 | 2005 Yamaha yZ 85
Model identification of Yamaha 15 four stroke
YAMAHA MODEL
YEAR GUIDE
EXAMPLE:
"F15MLHW" would
be a
Four Stroke, 15 HP,
Manual Tilt/
Manual Start, 20"
Shaft, Tiller Steer,
1998 model
THESE CODES ARE
GOOD FOR USA
MODELS ONLY
If you are outside
the USA we can
only help if you
have original
Yamaha part
numbers.
Please contact
Yamaha in your
area to buy a parts
catalog for your
motor.
Jan 27, 2013 | Boating
Water flow
you will have to strip the bottom end and renew the water pump impeller ,not a easy job if the bolts have corroded up with the sea water ,soak then in engine oil for a day or so before you try
Dec 17, 2011 | Clymer Marine Maintenance and Repair...
15 hp outboard 2 stroke running with water muffs on,there is no water coming out of the **** tube? Check the impeller? where is it? Just bought the the motor.
Impeller is at the bottom in the housing. it may take a few mins for the water to come out of the tell tale hole. Ensure that your muffs are on properly and wait for a bit. Also insure that the hole is not plugged.
Sep 07, 2009 | Boating
Impeller replacing on 1999 merc. 25hp 2 stroke
Should not be that hard. Tape up the ends so you can hold it with out getting cut, (if its ragged or sharp from damage). should be one nut holding the impeller on. If its to tight to hold try air or electric Impact wrench. If its bad you can tap with a hammer to help in removing the old one. If it turned on the shaft you will need to rent a puller. Repost if you need more help.
Jul 04, 2009 | 1999 Honda XR 600 R
Boating Logo
272 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
