Question about HP Compaq Presario V2000 Notebook
To access recovery options log on as a local user
System recovery options- to acess the command promt as well log on using an administrator account
  • 741 Answers
Command prompt: click on start>run then type in "cmd"
admin accout: click on start>control panel>administrator accout
Don't forget to rate this solution before you log off
Posted on Jan 26, 2009
Can't get logged in on windows 8
Follow the steps:
Requirements:
1 ) Windows Vista or 7 DVD
1. Insert the Windows Vista DVD into the DVD drive and then restart the computer.
2. Change Boot Options 1st Priority to Optical Drive.
3. When system booting up, if the message "Press any key to boot from cd" appears, immediately press Enter.
4. On Language Settings, Time and Currency and Keyboard Layout screen, just choose the correct settings then click Next.
5. On Install Now screen, click Repair. Note: Click No just in case you get the message: Windows found problems with your computer's startup options.
6. On the System Recovery Options screen, under Operating System, click Windows Vista then click Next. Then select Command Prompt.
7. At the command prompt windows, type the following command then press Enter after typing each command:
c:
cd windows\system32
echo ~takeown /f %1 /r /d y > TakeControlOf.cmd
echo ~icacls %1 /grant administrators:F /t
ren Magnify.exe Magnify.old
ren cmd.exe Magnify.exe
8. Restart the computer.
9. On the Welcome Screen, click the Ease button.
10. Check Make items on the screen larger then click OK.
11. At the prompt, type the command then press Enter.
net user Administrator /active:yes
exit
12. Restart the computer.
13.
At the welcome screen, logon using the local administrator account.
14. Access Control Panel then click User Accounts. Select the username of the account you can't login to then remove the password.
15. Log off on the current local administrator account your are logon to.
16. Check if you can logon to your user account now.
17. Open c:\windows\system32.
18. Right click on Magnify.exe, select Properties -> Security -> Advanced -> Owner -> Edit -> Administrators then click OK.
19. Select Edit -> Administrators -> Full Control then click Apply then OK.
20. Rename Magnify.old to Magnify.exe
21. Open command prompt then type the command then press Enter.
net user Administrator /active: no
To create a new user :
Net user username/add
Windows XP/2003, Vista and Windows 7.
To add a new user account to the local computer from command line:
net user username password /ADD
Example: To add a new user account with the loginid John and with password fadf24as
net user John fadf24as /ADD
To add a new user account to the domain:
>net user username password /ADD /DOMAIN
Note that we do not need to specify the domain name here.
Example:
net user John fadf24as /ADD /DOMAIN
Rename a user account from windows command line
We can use below wmic command to rename a user account from command line.
wmic useraccount where "name='username' " rename new_username
Ex: To rename the user account techblogger as win7techblogger
wmic useraccount where "name='techblogger' " rename win7techblogger
Net use command does not have any switches to rename a user account.
Few more Advanced uses of net user command.
To specify user full name while creating the user account
net user username userpasswd /ADD /FULLNAME:"User_Fullname"
To specify that the user is allowed to change the password
net user username userpasswd /ADD /PASSWORDCHG:Yes
To restrict user not to change the password:
net user username userpasswd /ADD /PASSWORDCHG:NO
To specify when the account expires we can use /EXPIRES switch.
To specify if the user must have a password set we can use /PASSWORDREQ switch.
How to create a new administrator account from command line?
An administrator account can't be created directly from command line. We first need to create a user account and then add the user to the administrators group.
Errors:
If you don't have privileges to add new user account to the system, you would get an error like below.C:\>net user John /add
System error 5 has occurred.
Access is denied.
C: \>
if cant able underatand send me your mail id..
Nov 10, 2013 | Computers & Internet
Tip
Enable / Disable the Local (Hidden) Administrator Account in Windows 7
Ways to Enable / Disable the Built-In Windows 7 Admin Account Many people familiar with prior versions of Windows are curious what happened to the Local Administrator account that was always created by default. Does this account still exist, and how can you access it?<br /> Recently I ran into an awkward situation where after disjoining a Windows 7 client machine from the domain, I was unable to log in to the computer. This was not because I had forgotten the local administrator password, but because the local administrator account was disabled (which is the default behavior in Windows 7). Like in Windows Vista, in Windows 7 the built-in Administrator's account is disabled by default. Furthermore, this account is not associated with any password. After doing some research, I found the following procedure that worked really well.<br /> <a href="http://www.windowspasswordsrecovery.com/enable-disable-local-administrator-account-win7.htm">Enable Built-in Administrator Account</a><br /> Basically there are 4 ways in order to activate the account:<br /> A) Command Prompt To enable the built-in Administrator's account by using the Command Prompt please follow these steps:<br /> 1. First you'll need to open a command prompt in administrator mode by right-clicking and choosing "Run as administrator" (or use the Ctrl+Shift+Enter shortcut from the search box)<br /> <img src="run-command-prompt-as-administrator.jpg" /> 2. After that you only need to enter the simple command below to activate it.<br /> <b><i>net user administrator /active:yes</i></b><br /> <img src="enable-hidden-administrator-account.png" /> 3. You should see a message that the command completed successfully. Log out, and you'll now see the Administrator account as a choice.<br /> <img src="built-in-windows-7-administrator-account.png" /> You'll note that there's no password for this account, so if you want to leave it enabled you should change the password.<br /> B) Local Security Policy Another way of activating the administrator account in Windows 7 is via Local Security Policy.<br /> 1. Type secpol.msc in the search bar and hit enter.<br /> <img src="secpol.png" /> 2. After the Local Security Policy pops up, navigate to Local Policies-&gt; Security Options where you can see an entry that reads Accounts: Administrator account. Double click the entry to enable it.<br /> <img src="local-security-policy.png" /><br /> <img src="administrator-account-status.png" /> C) Using the Local Users and Groups Snap-in To enable the built-in Administrator's account by using the Local Users and Groups snap-in please follow these steps:<br /> 1. Open Local Users and Groups. You can do so by typing lusrmgr.msc in the Start search box or in the Run command and pressing ENTER. Or, you could open Computer Management by right-clicking Computer in the Start menu and selecting Manage.<br /> 2. Expand System Tools &gt; Local Users and Groups &gt; Users.<br /> 3. Right-click the Administrator account and select "Set Password".<br /> 4. In the"Set Password for Administrator" click "Proceed".<br /> 5. In the"Set Password for Administrator" enter the Administrator's desired password twice, and click "Ok".<br /> 6. Next, enable the Administrator's account. Right-click the Administrator's account and select "Properties".<br /> 7. Un-chek the "Account is disabled" check-box. Click on the "Ok" button.<br /> Administrator's account is now enabled and configured with a password.<br /> D) During the Installation Process There is a 3rd method which advanced users can use. This method can be used during the installation process itself.<br /> 1. During the installation, after being prompted to configure the new user account, you will be able to set the new account's password.<br /> 2. At that phase, press SHIFT and F10 keys together. A Command Prompt window will appear.<br /> 3. In the Command Prompt window, type:<br /> <b><i>net user</i></b><br /> Note how the Administrator account is there, yet the new user account has not been yet created.<br /> 4. To set the Administrator's account password:<br /> <b><i>net user *</i></b><br /> 5. Then enter the required password and confirm it.<br /> 6. To enable the Administrator's accoun:<br /> <b><i>net user administrator /active:yes</i></b><br /> 7. Close the Command Prompt window and continue with the installation process.<br /> If you log off you will now see the Administrator's account as a valid logon option.<br /> Disable Built-in Administrator Account Make sure you are logged on as your regular user account, and then open an administrator mode command prompt as above. Type the following command:<br /> <b><i>net user administrator /active:no</i></b><br /> <img src="disable-local-admin-account.png" /> The administrator account will now be disabled, and shouldn't show up on the login screen anymore.<br /> <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Trial.exe">Hack into Windows 7 Administrator Account </a> [Free Trial] Article source: http://www.windowspasswordsrecovery.com/enable-disable-local-administrator-account-win7.htm<br />
on May 23, 2011 | Computers & Internet
Tip
Enable / Disable the Local (Hidden, Built-In) Administrator Account in Windows 7
Ways to Enable / Disable the Built-In Windows 7 Admin Account Many people familiar with prior versions of Windows are curious what happened to the Local Administrator account that was always created by default. Does this account still exist, and how can you access it?<br /> Recently I ran into an awkward situation where after disjoining a Windows 7 client machine from the domain, I was unable to log in to the computer. This was not because I had forgotten the local administrator password, but because the local administrator account was disabled (which is the default behavior in Windows 7). Like in Windows Vista, in Windows 7 the built-in Administrator's account is disabled by default. Furthermore, this account is not associated with any password. After doing some research, I found the following procedure that worked really well.<br /> <a href="http://www.windowspasswordsrecovery.com/enable-disable-local-administrator-account-win7.htm">Enable Built-in Administrator Account</a> Basically there are 4 ways in order to activate the account:<br /> A) Command Prompt To enable the built-in Administrator's account by using the Command Prompt please follow these steps:<br /> 1. First you'll need to open a command prompt in administrator mode by right-clicking and choosing "Run as administrator" (or use the Ctrl+Shift+Enter shortcut from the search box)<br /><img src="run-command-prompt-as-administrator.jpg" /> 2. After that you only need to enter the simple command below to activate it.<br /> <b><i>net user administrator /active:yes</i></b> <br /><img src="enable-hidden-administrator-account.png" /> 3. You should see a message that the command completed successfully. Log out, and you'll now see the Administrator account as a choice.<br /><img src="built-in-windows-7-administrator-account.png" /> You'll note that there's no password for this account, so if you want to leave it enabled you should change the password.<br /> B) Local Security Policy Another way of activating the administrator account in Windows 7 is via Local Security Policy. <br /> 1. Type secpol.msc in the search bar and hit enter. <br /><img src="secpol.png" /> 2. After the Local Security Policy pops up, navigate to Local Policies-&gt; Security Options where you can see an entry that reads Accounts: Administrator account. Double click the entry to enable it.<br /><img src="local-security-policy.png" /><br /><img src="administrator-account-status.png" /> C) Using the Local Users and Groups Snap-in To enable the built-in Administrator's account by using the Local Users and Groups snap-in please follow these steps:<br /> 1. Open Local Users and Groups. You can do so by typing lusrmgr.msc in the Start search box or in the Run command and pressing ENTER. Or, you could open Computer Management by right-clicking Computer in the Start menu and selecting Manage.<br /> 2. Expand System Tools &gt; Local Users and Groups &gt; Users.<br /> 3. Right-click the Administrator account and select "Set Password".<br /> 4. In the"Set Password for Administrator" click "Proceed".<br /> 5. In the"Set Password for Administrator" enter the Administrator's desired password twice, and click "Ok".<br /> 6. Next, enable the Administrator's account. Right-click the Administrator's account and select "Properties".<br /> 7. Un-chek the "Account is disabled" check-box. Click on the "Ok" button.<br /> Administrator's account is now enabled and configured with a password.<br /> D) During the Installation Process There is a 3rd method which advanced users can use. This method can be used during the installation process itself.<br /> 1. During the installation, after being prompted to configure the new user account, you will be able to set the new account's password.<br /> 2. At that phase, press SHIFT and F10 keys together. A Command Prompt window will appear.<br /> 3. In the Command Prompt window, type:<br /> <b><i>net user</i></b><br /> Note how the Administrator account is there, yet the new user account has not been yet created.<br /> 4. To set the Administrator's account password:<br /> <b><i>net user *</i></b><br /> 5. Then enter the required password and confirm it.<br /> 6. To enable the Administrator's accoun:<br /> <b><i>net user administrator /active:yes</i></b><br /> 7. Close the Command Prompt window and continue with the installation process.<br /> If you log off you will now see the Administrator's account as a valid logon option.<br /> Disable Built-in Administrator Account Make sure you are logged on as your regular user account, and then open an administrator mode command prompt as above. Type the following command:<br /> <b><i>net user administrator /active:no</i></b><br /><img src="disable-local-admin-account.png" /> The administrator account will now be disabled, and shouldn&iexcl;&macr;t show up on the login screen anymore.<br /> <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Trial.exe">Hack into Windows 7 Administrator Account </a> [Free Trial]
on May 03, 2011 | Computers & Internet
Why do i have to change my paswort all the time?
You might have it set to change at certain intervals
IE: at log in or after each restart .......
Disable password log in
On both PC and Mac computers, you can set up your system to automatically log in to a certain user account.
As a result, this setting will allow you to bypass the password login that is typically required.
You should only enable automatic login on your computer if it cannot be easily accessed by other people.
Open the Start menu and click on "Run."
Type "control userpasswords2" (no quote marks) into the dialog box and press the Enter key.
Uncheck the box next to "Users must enter a username and password" and click on the "Apply" button.
Enter the username of the account you want to automatically log in with and then type that account's password twice to finish setting up automatic login.
Click "OK." Password login has now been disabled.
Mac Instructions
Open System Preferences by clicking on the Dock icon.
Go to the "Accounts" control panel under the "System" heading.
Click on the "Login Options" button at the bottom of the window.
Select the account that you want to automatically log in with from the "Automatic login" drop-down menu.
also
Depending on what operating system you have, there are several steps you must take in order to disable the administrator account and password on your computer.
Most often, the administrator account and password are disabled in order to minimize security risks on your computer.
This account is often the target of attack if your system is compromised, as it allows access to all of the data and programs on the computer.
In order to disable the administrator account and password, follow the steps below that are outlined for the major operating systems.
If you are using Windows XP, you must be logged on as the administrator in order to disable the account settings.
Microsoft suggests that you set up another account with administrator permissions in the event that you may need to reverse this process.
Otherwise, you won't be able to.
Right-click on the My Computer icon on your desktop and select manage.
Click Users under Local Users and Groups in the left pane, which will bring up all users on the computer.
Double-click Administrator and on the General tab, check Account is disabled.
This will disable the Administrator account and password for Windows XP users.
In Windows 2000, go to Start, select Programs and go to Administrative Tools.
Click on Local Security Policy.
Next, click on User Rights Assignment under the Local Policies option in the left panel.
Double-click Deny access to this computer from the network and then click Add under Local Security Policy Setting.
Click Administrator account under Users and Groups, then click Add.
Click OK to complete the disabling of the Administrator account and password.
In Windows Vista, the Administrator account is automatically disabled.
However, if you have enabled it, you will need to open a command prompt.
Go to Start Menu, click All Programs, select Accessories and right-click on Command Prompt and click run as Administrator.
Open the command box and type net user administrator/active:no. Press enter and you should receive a prompt stating the command was completed successfully.
If you are running a Mac, the Administrator account is enabled by default.
To disable the account and password, go to the Apple menu, click System Preferences.
Choose Accounts from the View menu and click the lock to authenticate with the administrator account password.
Click login options, click edit, and after clicking the lock in the Directory Utility window, click Disable Root User from the Edit menu.
Aug 04, 2013 | Computers & Internet
I have forgotten my password
If you have forgotten the password of your user account there are only two options which can be used.
1)If you have two or more user account on the this computer you can try to access other user account of other user and access user accounts in control panel.
Remove your user account password and log off and try to access your account.
2)If you don't have any other user account then only option is to perform the system recovery.
** you can access recovery manager from the F11 option or Use the recovery cds.
while performing the recovery you will get the option to back up your data please back up your data before performing the recovery or you will loose all your files.
this will resolve your issue.
Thanks.
Aug 20, 2010 | Compaq Presario CQ60-220US PC Laptop
Tip
Lost Windows 7 Password, How to Get in Your Password Protected PC in Safe Mode?
Lost Windows 7 password, what will you do to get in your password protected computer? In fact, there are lots of ways for you to regain access to the locked computer? In addition to use a password reset disk to reset Windows 7 password, you can still log on your PC in safe mode to change the lost Windows 7 password. It is very simple. Just three steps. You could follow the below guide.
Step 1: Enter safe mode in Windows 7 operating system
1. Start or restart your Windows 7 machine.
2. Press the F8 key to enter Advanced Boot Options just before the Windows 7 loading screen appears.
3. Use arrows to choose Safe Mode when you can see the Advanced Boot Options screen.
4. Press Enter and wait for Windows 7 files to load.
5. Log on with an administrator account when you can see the log on screen.
Step 2: Change lost Windows 7 password
Now you are logged into Windows 7 in safe mode. You diagnose and solve some serious problems under it, especially when starting Windows normally is impossible. To reset Windows 7 password, just do as follows:
1. Click Start button and input lusrmgr.msc into the Search box.
2. In the coming Local Users and Groups screen, double-click Local Users and Groups, and then click Users.
3. Right-click the account that you need to reset the password for, and then click Set Password.
4. Type and confirm the new password.
Note: you can also go to Local Users and Groups screen by right-clicking Computer to select Manage on desktop.
Step 3: Log on your computer with the new password
You have successfully perform Windows 7 password reset. Now you can easily access to your compute with the new password. Please note that you must log on with an account that has administrator permissions.
More information:
When you are presented with Advanced Boot Options screen, there are 3 variations of Windows 7 Safe Mode.
Safe Mode - This is the default option and is usually the best choice. This mode will load only the absolute minimum processes necessary to start Windows 7.
Safe Mode with Networking - This option loads the same processes as Safe Mode but also includes those that allow the networking functions in Windows 7 to work. You should choose this option if you think you may need to access the Internet or your local network while troubleshooting in Safe Mode.
Safe Mode with Command Prompt - This version of Safe Mode also loads a minimum set of processes but will allow immediate access to the Command Prompt. This is a valuable option if more advanced troubleshooting is necessary.
Actually, the 3 options are available for you. I only take Safe Mode as an example. But if you choose Safe Mode with Command Prompt, you'll need to input related to command prompt to change the lost Windows 7 password.
If you cannot log on Windows with an account that has administrator permissions, you will be not able to enter Windows safe mode. In that case, I'm afraid you'll need third party software Windows Login Recovery to help to bypass your lost Windows 7 password and get back in your protected computer. Windows Login Recovery allows you to reset lost Windows password with a bootable CD/DVD or USB flash drive. It takes you take less than 5 minutes.
on Oct 25, 2010 | Computers & Internet
My avent 7109b laptop was asking for password when it boots up but cant remeberwat it is after 3 try it say system diabled and the code 036501 can anyone help me please
You can reset the password of Windows 7 and Windows Vista. These steps are not provided as troubleshooting. I m jus curious to help you out with my experience.
insert the disc and boot to WinRE
Boot to Win RE
Click Command Prompt option.
C:
CD Windows\system32
ren cmd.exe cmd.old
ren magnify.exe cmd.exe
ren cmd.old magnify.exe
Restart computer
Click on Easy of Access centre left side bottom ? Choose Magnify option ? Command prompt opens up
Type: net user administrator /active:yes
Logon on administrator account and then using User Account page, remove password for the other account
Search for Magnify.exe in start search and click on it
Type: net user administrator /active:no
Boot to winRE
Type the following:
C:
CD Windows\system32
ren magnify.exe cmd.old
ren cmd.exe magnify.exe
ren cmd.old cmd.exe
exit
Restart the computer – system logs on to the User account without asking for password provided there is only one user account.
Mar 07, 2010 | Computers & Internet
Fiinding and reseeting administrator password in windows vista
hi,
If you don't remember the administrator password then login to the user account who has administrator acess. After logging into that users account you would be able to change the Administrator password. After logging into user account follow this steps to change password.
Click start--> go to Run--> Type "compmgmt.msc" without inverted codes--> select "local users and groups" there you select "users" in right hand side you can see "Administrator" select that option "right click" there you will get an option as "Set password" select that and change a new password.
Thanks,
Appereciate to rate as "FixYa"
May 23, 2009 | eMachines T5274 Desktop PC
I have read that the default password is 6 zero's.
Aug 07, 2008 | Acer Aspire 3680 Laptop
Aip ssm password recovery
The following password recovery options exist:
If another Administrator account exists, the other Administrator can change the password.
If a Service account exists, you can log in to the service account and switch to user root using the command su - root.
Use the password command to change the CLI Administrator account's password.
For example, if the Administrator username is "adminu," the command is password adminu. You are prompted to enter the new password twice.
You can also reimage the sensor using either the recovery partition or a system image file. This will default the device.
Mar 13, 2008 | Computers & Internet
HP Compaq Presario V2000 Notebook Logo
1,137 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
