Question about Radio Communications
Definitions of police scanner 10 codes
Police 10 code meanings
  • julie lester Feb 23, 2012
    police scanner 10 codes like what is a 10-97?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
10-97 is "Check (test) signal".
For the rest, see my response to your other post.
Posted on Feb 23, 2012
SOURCE: police scanner codes
i need help to find the auburn ny police codes can someone help me please
thank you bill
Posted on Nov 28, 2008
Mechanic688
  • 204 Answers
Hi, if they told you to find your freq's online then this a good starting spot.
http://www.radioreference.com/apps/db/
Just click on your state, then county, and it'll list sheriff, local police, fire and so on. I hope this helps you,, Mechanic
Posted on Jan 23, 2008
sir fixalot
  • 146 Answers
SOURCE: police frequencies codes
Here is a great link for you guys out in scanner land:
Posted on Jan 04, 2008
SOURCE: need codes to program my police scanner
here is a few sites that can head you in the right direction.www.radio reference.com,www.scannermaster.com,www.bearcat1.com.hope these help
Posted on Dec 04, 2008
BillB-SA
  • 2761 Answers
SOURCE: I need to reprogram my Realistic Pro-2023 police
PROGRAMMING YOUR SCANNER
For a a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
SETTING THE VOLUME AND SQUELCH CONTROLS
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
transmissions.
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
stops.
SCANNING THE CHANNELS
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
features.
USING THE DELAY FEATURE
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
LOCKING OUT CHANNELS
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
USING THE PRIORITY FEATURE
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
activity.
MANUALLY SELECTING A CHANNEL
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
LISTENING TO THE WEATHER BAND
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Posted on Feb 21, 2010
Enjoy listening to my scanner but need to know what 911 scanner codes mean
You can find the 10- and 11- codes here:
http://www.radiolabs.com/police-codes.html
Mar 17, 2017 | Radio Communications
Police code 1015
Police Scanner Codes - RadioLabs
  1. Cached
  2. Similar
The following is a list of police, fire and emergency codes listed in numerical order. If you notice ... Police Scanner 10 Codes. Police ... 10-15 Prisoner in custodyATS-909X ClearMod · ‎Kaito Voyager KA500 · ‎Radios
police code 1015 Google Search
Mar 10, 2017 | Radio Communications
Petaluma police codes
these are generic "ten codes" just google police ten codes any specialized codes you will have to figure out locally as they can be made up any time the department chooses.
Feb 20, 2015 | Radio Communications
What are the meanings of the police 10 codes?
You use to be able to go to Radio Shack and they would give you a sheet of the codes for free and their meanings. But i don't know if they still do it for free or not.
May 18, 2014 | Uniden Bearcat 350a...
List of police 10-codes for a home scanner
Start here.
Page 8 of this document has the original 1940 list. Another list is here.
Feb 23, 2012 | Radio Communications
How do i find scanner codes for my local area?
I assume you mean local fire and police and if so then here is a great site
http://www.police-scanner.info/police-scanner-frequencies.htm
if not then i am unsure to what you mean by scanner code
Mar 15, 2010 | Audio Players & Recorders
Hello, i just got my scanner working and need to know what everyone is talking about. How do I find all the codes for san joaquin count california? so, pd, fire, etc? thank you My scanner is not the one...
Congrats on entering the scanner world. Two different points of information you'll need:
1. Local municipal services' radio frequencies
2. Download a "10-code" definition list
If you google search San Joaquin County and "radio frequencies" you get a list of all the local radio frequencies that the local services in your area are broadcasting on. Then you can program them into your scanner... sorry if you already figured this part out..
Secondly, you can download a police call 10-code definition list and you be up and running. Print out your code list and you'll have alot of them memorized real quick. Also you'll get used to the local abbreviations being used in your area... for example in my area, "ECR" means El Camino Real.. a main street near here.
Have a blast..
Oct 17, 2009 | Radio Shack Pro-2096 Base Scanner
Scanner codes
Here is a website with all the alabama frequencies...Click here
for what the "10-codes' ,mean... click here
May 15, 2009 | Uniden BC340CRS Base Scanner
Police 10 codes
Sent an e-mail your way,, Hope it helps,, Mechanic
Oct 26, 2008 | Uniden BC72XLT Handheld Scanner
Police coads @ what they mean
Hi..
Code some vary from city to city. Local Radio Shacks have been helpful..Google "scanner codes" and add the city or closest city to you ie>scanner codes chicago, IL or police codes chicage IL.
Scroll down and see what type of codes you want.
Good Luck.
Squipps
Feb 06, 2008 | Radio Communications
Radio Communications Logo
256 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
