Question about Yamaha RX-V596 Receiver
Broken Speaker Wire Connector
One of the wire connectors (not the RCA) for the rear speakers was always iffy, and finally broke the other day. In doing so, it has apparently shorted out the channel so when I run the test and it gets to that speaker, it shuts off. Out of test mode, it works at low volume but when I give it any volume at all it will also shut off. I need to replace the connector (it opens and closes with a little plastic tab). Is this doable by a reasonably competent fixer? Where would I find the part and what is it called?
  • 24 Answers
You can try Bogue Engineering and you can find them at www.BogueEngineering.com they carry every type and your system will need the 4,2mm size connector. Hope this helps, Gary
Posted on Jul 23, 2009
How do i correctly install the radio in a 2000 kia sephia
Here are the radio connector wiring colors and what they do.
2000 Kia Sephia Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/Red
Car Radio Ignition Switched 12V+ Wire: Blue/Black
Car Radio Ground Wire: Black
Car Stereo Illumination Wire: Red/Black
Left Front Speaker Wire (+): Black/Yellow
Left Front Speaker Wire (-): Blue/Orange
Right Front Speaker Wire (+): Blue/Green
Right Front Speaker Wire (-): Light Green
Left Rear Speaker Wire (+): Green/Red
Left Rear Speaker Wire (-): Green/Black
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Red/Blue
Jun 28, 2012 | 2000 Kia Sephia
Broken connector in subwoofer connection on receiver
The only thing you do is to open your receivers,then locate the output connector if you see the female RCA jack ,then push it out the broken piece ,that's it
Jul 27, 2008 | Audio Players & Recorders
Replacing oem car radio/CD (Clarion PN-2165M I) from 2002 Nissan Sentra GXE. I ordered Scosche Car Stereo Connector to avoid cutting OEM connector. Im confused about the OEM Radio/CD wiring colors as to...
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
May 25, 2011 | Clarion Car Audio & Video
I have a 96 escort with no radio ;the wires are there,but i want to install a new radio.i don't know what wires hook up to the new radio
Hi, if the connector is still there, it is easiest to purchase a ford wiring adapter. The adapter will match the factory wires to an aftermarket stereo. If the connector is gone, see your factory wire colors below. Please let me know if you need additional help or have any questions, and thanks for using FixYa.
1996 Ford Escort Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Illumination Wire: Red/Black
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Blue/White
Right Front Speaker Negative Wire (-): White
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Red/Blue
Right Rear Speaker Positive Wire (+): White/Green
Right Rear Speaker Negative Wire (-): Blue
Apr 18, 2011 | Ford Escort Cars & Trucks
Im lookin fer the radio wiring diagram for my 1996 geo prizm because someone cut the standard clip for the stock radio out
Under the center console/dash you should has two connectors.
LARGER CONNECTOR
A Right Front Speaker (+) Green Gray
B Left Front Speaker (+) Pink White
C Right Front Speaker (-) Blue Gray w/ Black Stripe
D Left Front Speaker (-) Purple White w/ Black Stripe
E Ground Wire Black Black
F +12 Volt Ignition Wire Gray Red
G Power Antenna Wire 1 Blue (join wires 1 & 2
H Power Antenna Wire 2 together to this blue wire)
I Do Not Use
SMALLER CONNECTOR
J Right Rear Speaker (+) Red Purple
K Right Rear Speaker (-) White Purple w/ Black Stripe
L +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow
M Left Rear Speaker (+) Black Green
N Left Rear Speaker (-) Yellow Green w/ Black Stripe
Dec 02, 2009 | 1996 Geo Prizm
I need help I don't know what color wires go to what wires on my sterio deck
I have a radio wire connector on a 1994 Toyota Camary and the color don' match your list, here is my list.
2 reds, one silver dot, one double silver dot.
2 blacks, same as above,
2 greens, same as above.
2 whites, same as above.
2 browns, same as above,
1 white w/green stripe, two silver dots
1 black w/red stripe, one silver dot.
1 yellow, two silver dots.
1 blue, two silver dots.
the numbers on the connector are A02 16 14 11264 9 8.
I'm clueless which wire are which.
Oct 30, 2009 | 1994 Toyota Camry
I need the diagram for the audio cables
do u mean the radio connector? if so here it is.
Radio Constant 12V+ Wire: Blue/White
Radio Switched 12V+ Wire: Yellow/Red
Radio Dimmer Wire: n/a
Front Speaker Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speaker Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Sep 16, 2009 | 1997 Honda Civic
I Need the Wiring guide
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Stereo Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
May 21, 2009 | 1992 Saturn SL2
Im sittin here with the wiring harness for my 99 altima, and the wiring thing from the back of my pioneer deh p6700MP, i have no clue which ones to match with the other one?
Here's the manual for the Pioneer -->LINK<--.
This is the 2 options of install wiring on a 97 Altima, I'm not sure if it's exactly the same, I suggest that you don't trust these pinout if yours differ at all.
Radio Constant 12V+ Wire: Pink
Radio Switched 12V+ Wire: Blue
Radio Dimmer Wire: Red/Yellow
Antenna Trigger Wire: Green/White
Front Speaker Size: 4′ x 6′
Front Speaker Location: Doors
Left Front Speaker Wire (+): Brown
Left Front Speaker Wire (-): Black/Red
Right Front Speaker Wire (-): Black/Yellow
Rear Speaker Size: 6 1/2′
Rear Speaker Location: Rear Deck
Left Rear Speaker Wire (+): Orange
Left Rear Speaker Wire (-): Black/Pink
Right Rear Speaker Wire (-): Black/White
THERE IS AN ALTERNATE WIRING COLOR CODE
THERE IS NO CONTACT PIN OR EXISTING WIRE THAT IS GROUND !!!!! (some really strange things happen to aftermarket radios if you think the Red/yellow wire on pin 9 of the 10-pin connector is ground”!!!!!
Large 10-Pin Connector:
Constant Hot (Memory or Clock) =RED wire pin8
Switched (Ignition) Hor = Blue wire pin4
Left Front Speaker + = Blue/white pin1
Left Front Speaker - = Blue/yellow pin5
Right Front Speaker + = Brown pin2
Right Front Speaker - = Brown/white pin6
The Smaller (6-pin) connector is only for the rear Speaker:
Left Rear + = Red pin5
Left Rear - = Green pin4
Right Rear + = Blue pin2
Right Rear - = Pink pin6
Regards
Philip
Jul 21, 2008 | Car Audio & Video
Yamaha RX-V596 Receiver Logo
418 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
