SOURCE: Royal 1280 MX green light turns red, does not run
The 1280mx has a circuit that detects the high current when the motor is jammed. The 5 watt, 0.5 ohm resistor/fuse (marked as R1) that is part of this circuit blew on my unit. No visible signs of failure, you have to remove it from the circuit board to test it. When R1 fails more current than normal passes through the R2-1k ohm resistor; need to check if it also failed.
SOURCE: Shreder works in reverse but not in forward.
Check in opening and see if paper switch is stuck.
SOURCE: royal 1200mx confetti cut shredder : wont turn on
If its dead...no lights, nothing, then the pcb inside has probably gone. Give Royal a call at 1-800-524-0799 for parts and prices.
