Electric heating my air works fine, but when I turn the heat on nothing happens at all. No heat and the fan doesn't blow. The breaker is on, so i'm not sure. if the fuse is blown, how do I know and is that something I can easily fix on my own? Thanks
    New Friend:
  • 30 Answers
There are heat relays in the furnce. one of them is probably bad.
Posted on Oct 30, 2008
Eb20b/ electric furnance/ blower wont shut-off after heat kicks out, got to kill breaker , runs all the time, installed new thermostat, no change?????? Its cold??????
Check the thermostat and make sure the fan switch is set on "Auto". If it is set on "ON" the blower will run constantly.
Jan 31, 2015 | Heating & Cooling
I have a rudd UHLA-3617JA high achiever air handeler, works fine except the electric heater will not come fan starts normally, is this a fuse/breaker or failed electric element problem, how can i tell
It is either the element, sequencer (or contactor/relay), or power to the switching element. 5KW Elements normally Ohm out @ around 10 Ohms when they are good. Everything you need to check requires a multimeter.
Jan 21, 2015 | Heating & Cooling
Hi. I am not getting any heat. I have a White-Rodgers manual mercury thermostat model 1F56-501 and natural gas heat with GOODMAN packaged gas/electric model PGB024050-1 Before I call a service rep, I...
Hello,Good job with description.Something is keeping the condenser off(saftey).Do you have an emergency heat setting on the therm.It will run electric heat strips only until service can check it out.Very rare that the disconnect switch (black box) is it.Need electrical meter to prove it out.
Dec 01, 2010 | Goodman Heating & Cooling
I have a intertherm mobile home furnace. When i turn on the heat the circuit breaker in the funace heats up and blows the breaker. this only happens when i turn on the heat if i turn on the fan it is...
you said it yourself. when an electrical device is running it produces amps, with every amp is a unit of heat. breakers are heat sensitive as well. so you might want to consider a new breaker. newer breakers are made out of better materials that are able to displace heat more efficiently. or check to make sure the screws on the terminals where the wires go in are tight. if there is a loose connection that will increase the units of heat traveling through the termination. or, worse case scenario, like when all hope is lost. splice in some more wire, correctly, emphasis on correctly, and relocate the breaker. perhaps use insulation around the breaker, non flammable of course.
Nov 11, 2010 | Electric Electrical Supplies
Energy Knight heat pump refuses to blow!
Does this problem happen when the temperature is below 30 degrees? When it gets about that cold outside, the air outside is too cold for the heat pump to "steal" heat from. On the thermostat you'll find a switch labeled aux or emergency heat. Turning this switch on will operate a traditional coil heater inside the system, providing you with heat. The only downfall to this is that it uses more energy to heat this way. Try turning the fan switch from "auto" to "on". If the fan comes on, then we can rule that out. If the aux heat switch is NOT on, set the thermostat such that the system will try to heat. If the outside unit is running, the problem is either it being too cold like I said earlier, or there's a problem with the heat pump's mechanical system that needs to be serviced by a professional. If the outside unit doesn't run but it should be, check it's breakers at the panel, the breaker inside the electrical box that feeds it, and look to see if there's a reset button on the unit itself. Finally, check the air handler (part of the system inside with the fan in it) to see if there's any circuit breakers or fuses on this unit. Make sure they're not tripped/blown. If none of this helps, you definitely want to get a pro to work on your system.
Feb 27, 2010 | Heating & Cooling
Jenn Air cooktop JED8430ADB not heating, fan & knob lights work?
Some times a breaker can be partially tripped and not visible . You should try turning the breaker off and on several times.
always unplug electricity before attempting to repair on any electrical appliance
Sep 09, 2017 | Jenn-Air JED8430 Electric Cooktop
I'm having a problem with my heating and air system, my heat only works on emergency heat ( and run 24/7) if i turn it to regular heat it only blows cold air. i dont think my outside unit fan is turning( i...
If your Heatpump's fan isn't running but your compressor is, your fan motor is out. If nothings happening at all ensure your getting power to heatpump (ex: breaker tripped, fuses blown on outside power switch, or fuses blown in breaker box?)
Dec 04, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
