Question about MSI Computers & Internet
Vcc data gnd connector. Also have USB cable. All from front panel.
MSI P67A-GD 53. Have a cable from the front panel labeled USB. Assume goes to USB Red Marked socket. Also have a vcc data+ data- gnd cable. Dont know where this 4 pin connector should go.
copper7op
  • 30 Answers
SOURCE: case wire two mother board
Here is your front Audio guide:
http://www.fixya.com/uploads/images/3C3CD07.jpg
Here is your USB guide:
http://www.marnscda.com/Guide/USBPinMB.jpg
And here is your front Panel guide:
http://www.elhvb.com/mboards/intel/pinout-OEM-Intel-2x9pin.jpg
Let me know how that works out. The front panel guide is rotated 180 degrees however.
Posted on May 02, 2009
  • 336 Answers
SOURCE: Need SPDIF pinouts identified.
When looking at the board, bottom towards you assuming that the 3 pins are parallel to the pci/e slots, the left pin should be the +5V vcc the middle pin is the spdif out and the right pin is the ground. Also the 3 pins are probably not exactly the same distance from each other (equally spaced) the 2 pins that are closest together are the spdif and the ground, spdif is always the middle pin. This info is based on 2 different asus motherboard install guides. I hope this helps you.
Posted on Aug 12, 2009
map9966
  • 2351 Answers
SOURCE: USB wiring on KT4AV MS-6712 Ver 10A motherboard
Open the link provided; http://www.directron.com/installusb.html
You will need to scroll down until you see, Intel Standard USB header Layout. Also see: Common USB case header connectors.
Hope this is what you're looking for.
Cheers'
Mike
Posted on Feb 07, 2010
Testimonial: "Many thanks, I have now also found the MB manual on MSI's site and your useful info confirms and clarifies. Kind regards, Mike"
olwork
  • 237 Answers
SOURCE: got mixup with 7 wires cable connection
The 144 page manual for your motherboard, with all diagrams to answer your questions, may be downloaded at the following link direct from the manufacturer.
Download Here
If you find this solution helpful, then please take a moment to rate this post. - Thanks.
Posted on Jun 03, 2010
  • 88 Answers
SOURCE: I have a MSI NVIDIA
hi friend..!!!!!!1
you can checkout your problem on this link
http://www.youtube.com/watch?v=BDMK6yQMDxA&feature=related
hope this will help you..
please give me rating. this will encourage me to give more free ans.
regard
sany
Posted on Sep 04, 2011
MX46-633V CONNECTING FRONT USB
I believe you're referring to the AOpen MX46-533V
The Front Panel USB header is Blue in color, and located in-between the white No.3 PCI expansion slot, and bottom edge of the motherboard;
http://www.ebay.com/itm/AOpen-Model-MX46-533V-Socket-478-Desktop-System-Motherboard-/130774572519?pt=Motherboards&hash=item1e72c59de7
With the motherboard in the installed position;
5 pins across the Top row, 4 pins across the Bottom row.
Pins across the Top row are numbered EVEN
Pins across the Bottom row are numbered ODD
Starting on the Left side coming across to the Right, Top row;
Pins 2, 4, 6, 8, and 10
Bottom row;
Pins 1, 3, 5, and 7
There are TWO USB connectors supported off of this USB front panel header.
For one of the USB front panel connectors;
A) Pin 1 is USB PWR 0
Goes to the VCC contact pin on the USB connector.
B) Pin 3 is USB_FP_P0-
Goes to the D- pin on the USB connector.
(Data - )
C) Pin 5 is USB_FP_P0+
Goes to the D+ pin on the USB connector
(Data +)
D) Pin 7 is Ground (GND)
Goes to the Ground (GND) pin on the USB connector
E) No pin 9
F) Pin 2 is USB PWR 0
For the other Front Panel USB connector;
A) Pin 2 is USB PWR 0
Goes to the VCC pin on the USB connector
B) Pin 4 is USB_FP_P1-
C) Pin 6 is USB FP P1+
D) Pin 8 is GND
E) Pin 8 is USB_FP_OC0
Leave unconnected
This is more information on a standard USB connector pinout,
http://en.wikipedia.org/wiki/USB
( A USB connector, and a USB plug are not wired the same.
The plug is wired backwards from what a connector is.
Otherwise you would have power and signal going to the wrong pins, and burn the USB Front Panel header out on the motherboard )
AOpen MX46-533V motherboard manual, but it is in Japanese.
May be one in English out there.
The Front Panel header pinout, USB header pinout, etc, is easily cross identified,
http://global.aopen.com/products_download.aspx?sDropDownProd=52
Manual / Japanese manual for MX46533V / Japanese / 1/28/2006
Go to the far right, and click on the Floppy Drive icon above -
3701.1 KB
On the next page click on the mirror server website that is closest to your country.
This is a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the country server name it may take up to 30 seconds, before the first page comes up.
(File is downloading in background)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 19, 2012 | ASUS P5PE-VM Motherboard
Do you have any user manual for front panel usb
http://www.msi.com/product/mb/PM8M-V.html
(MSI PM8M-V H, is version 2.0 )
Hover your mouse cursor on the Download tab.
(Overview / Specification / Download / Support / etc.)
In the drop down list, click on - Manual
Under the subheading - Download, click on the blue -
M7104v1.0.zip
[ This is a Zip file. A Zip file is a file that is compressed, to send easier. The above manual is for the M7104v1.0
It will work for the version 2.0 also.
You need a program to 'Unzip' it. (Decompress)
If WinZip is not working on your computer, go to 7-Zip, and download for free.
If you need guidance in downloading, and unzipping, post back in a Comment ]
There are two USB headers on the motherboard for the Front Panel,
JUSB1 and JUSB2. (Junction USB 1 and Junction USB 2)
Looking along the bottom of the motherboard, FROM the Right going towards the Left;
JFP1 header; (Front Panel main wires)
Header with 4 pins on the Top row, and 5 pins on the Bottom row.
JFP2 header; (Dual color Power On LED, and Speaker)
Header with 4 pins on the Top row, {Speaker}, and 3 pins on the Bottom row.
JUSB2 header.
JUSB1 header.
EACH USB header will support TWO USB ports in the Front Panel.
JUSB1 supports two,
JUSB2 supports two.
For each USB header there are 5 pins across the Top, 4 pins across the Bottom.
The pins are numbered EVEN across the Top, and ODD across the Bottom.
Starting from the LEFT side going across to the RIGHT side;
on the TOP row for JUSB2 and JUSB1;
Pins 2, 4, 6, 8 and 10.
on the BOTTOM row for JUSB1 and JUSB2;
Pins 1, 3, 5, and 7. There is NO pin 9.
A) Pin 2 is VCC
B) Pin 4 is USB1-
C) Pin 6 is USB1+
D) Pin 8 is Ground
E) Pin 10 is USBOC
Pin 10 is N/C -> Not Connected.
It is there, and Pin 9 is not there, to key which way a connector can go on. Only ONE way.
F) Pin 1 is VCC
G) Pin 3 is USB0-
H) Pin 5 is USB0+
I) Pin 7 is Ground
There is NO pin 9.
(The USB technology used is USB 2.0)
http://pinouts.ru/Slots/USB_pinout.shtml
Let's read together,
Under - USB pinout signals;
"USB is a serial bus. It uses 4 shielded wires: two for power (+5v & GND) and two for differential data signals (labeled as D+ and D- in pinout). NRZI (Non Return to Zero Invert) encoding scheme used to send data with a sync field to synchronise the host, and receiver clocks. In USB data cable Data+ and Data- signals are transmitted on a twisted pair. No termination needed. Half-duplex differential signaling helps to combat the effects of electromagnetic noise on longer lines. Contrary to popular belief, D+ and D- operate together; they are not separate simplex connections."
See the USB examples in the link above, where it labels the contact pins?
The MALE connectors are shown on the Left side.
The FEMALE connectors are shown on the Right side.
Your USB ports will be FEMALE, on the Front Panel.
They are also the A style. USB A style. The Top example to the Right.
Just noting the following in case for some reason, the wires coming from those contact pins in the female USB connector, are not color coded correctly;
Even after you have the wires sorted out, as to which contact pins they go to, DOUBLE-check again. Do NOT just go by the color code of the wires.
Why?
You do NOT want to accidentally connect the +5 Volts (VCC), to the Ground!
Explaining further;
You connect the VCC wire, (Red), of the USB port in the Front Panel, to the Ground pin on the USB header on the motherboard.
(Which means the Ground wire of the USB port, (Black), will probably also be connected to the VCC pin, on the USB header of the motherboard)
Zzzzzzap! There goes your front USB ports. Both USB front panel headers on the motherboard, will be DONE!
Make sure!
Going on;
1) VCC or Vcc, goes back relating to Transistor technology.
Just think of it as the Positive, or power wire.
It is.
It is 5 Volts DC.
2) GND is Ground. It's a DC circuit, and you have a Positive, and a Negative, or Ground.
3) USB1-
That is -> Data-
USB0 is for one USB port in the Front Panel.
USB1 is for another USB port in the Front Panel.
[ Each USB header on the motherboard can be connected, to TWO USB ports on the Front Panel.
Therefore for the two JUSB1 and JUSB2, you can connect Four USB ports in the Front Panel ]
Data- on one USB port in the Front Panel, goes to USB0-
Data- on the other USB port in the Front Panel, goes to USB1-
4) Data+
Same thing.
Data+ on one of the USB ports in the Front Panel, goes to USB0+
Data+ on the other USB port in the Front Panel, goes to USB1+
EACH side of JUSB1 and JUSB2, will support one USB port on the Front Panel.
Two sides per JUSB1 and JUSB2 = 4 USB ports on the Front Panel.
For additional questions, or clarification to anything I have stated above, please post in a Comment.
Regards,
joecoolvette
Jul 20, 2012 | MSI Computers & Internet
Plugigng of wire in board
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with IntelĀ® Front Panel I/O Connectivity Design Guide.
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Hopefully this information helps.
Thank you for using FixYa.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
I need help with connecting my case wires to the motherboard
those wires are for the USB not audio,the meaning of the
writing no the wires are:
vcc=5 volts, -D=data negative, +D= data positive,GND=ground.
look in the manual for usb connection, if the mainboard has the header connection for them connect the wires to it if not just leave them out, secure them out of the way.
Mar 13, 2010 | EliteGroup ECS A780GM-A Motherboard - AMD...
How to connect the usb front panel
There are connectors on the motherboard for the usb connectors that go to the front panel. Look at you manual and connect the connectors correctly. Each connector has 4 wires, with a red(+5volts) and black on each end. Make sure plug these in correctly on the motherboard connectors since a backward connection will burn up your usb device when it's plugged into the usb port. Been there done that! It should say something like this in the manual, VCC, USB1-, USB1+, GND.
Sep 25, 2009 | MSI MS-6547 Motherboard
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Front panel connector J16 dell dimension 2350
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
Jul 15, 2009 | Computers & Internet
Case wire two mother board
May 02, 2009 | Foxconn 661FX7MF-S Motherboard
Where to connect card reader?
Easy, if you find where your front usb port is connected you'll see some odd ports that have 10 pins slots one of which has a missing pin, either in the lower left hand corner or in one of the center pin positions. Find the one that matches your generic (usb) card reader and plug her in. The card readers that come prebuilt in computers now are based on usb technology and fit into the same slots as the USB connectors. In fact if this is on a 915G it should plug into one of the JUSB1 or 2 slots.
Sep 12, 2008 | MSI 915G Combo-FR Motherboard
Asus p5pe-vm
"USB +5v" = VCC
"USB_P5-" = -D
"USB_P5+" = +D
"GND" = GND
May 15, 2008 | ASUS P5PE-VM Motherboard
Computers & Internet Logo
604 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
